首页 > 矿用橡套电缆
[橡套电缆] 求助此类电缆屏蔽结构是怎样的?
P:2009-08-11 08:49:47
Description
Application
Design
Conductor
Flexible stranded tinned copper acc. DIN EN / IEC 60228 class 5
1.
Insulation
> Inner semi-conductive layer
> Elastomeric EPR rubber compound 3GI3 acc. to
DIN VDE 207 part 20
> Outer semi-conductive layer "RHEYSTRIP",
easy strip (Thermostrip)
2.
Screen
Close spinning of tinned copper wires acc. DIN VDE 0250 part 1
3.
Outer sheath
Chlorinated rubber compound 5GM5 acc. to DIN VDE 0207 part 21
4.
Marking
Options
· Pre-assembled with sealing ends upon request
· Other cross-section and voltages on request
· Festoon application with special screen on request
· Version (N)TMCGWOEUS with optimized wallthicknesses on request
Flexible high voltage cable used normally in short lengths, e.g. between
short-circuit breaker and mobile transformer
e.g. :
RHEYFIRM(SI) NTMCGCWOEUS 1 x 95/16 6/10 kV I NEXANS I year
miniature cable - 微型电缆 (0) 投诉
P:2009-08-11 08:52:38
图片传不上去,是单芯的EPR绝缘,带内外屏蔽,再外层是两层屏蔽,猜测是铜丝编织加半导电包带???外层为红色CR护套!
earth conductor - 接地导体(GB) (0) 投诉
P:2009-08-11 09:21:34
不是太详细,恐怕不好帮助
higher-order mode - 高次模 (0) 投诉
P:2009-08-11 10:55:53
我的翻译:中心导体为:绞合镀锡铜线,导体外面屏蔽一层绕包带,外挤出EPR绝缘;再屏蔽一层与内导体屏蔽材料一样的绕包带;镀锡铜丝同向编织绕包屏蔽(编织机上可以生产);最后橡胶外护套
仅供你参考!!
infra-red measuring instrument - 红外线测试仪 (0) 投诉
P:2009-08-11 14:42:50
导体:IEC 5类镀锡结构
内外半导电屏蔽
绝缘3GI3 欧洲协调型符合DIN VDE 0207 20部分
镀锡铜丝编织屏蔽DIN VDE 0250 1 部分
护套 欧洲协调型5GM5 符合DIN VDE 0207 21部分
其他要求
安装前密封
电压和横截面上的要求
花彩应用屏幕上的特殊要求
TMCGWOEUS对厚度的要求
能够短期在断路器和移动变压器之间灵活使用
RHEYFIRM(SI) NTMCGCWOEUS 1 x 95/16 6/10 kV I NEXANS I year 应该是标识 还是什么
scorch retarder - 焦烧延迟剂 (0) 投诉
