首页 > 国外线缆
[问题求助] 哪位有UL10368的相关资料?谢谢
P:2009-08-10 08:14:36
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 1 Page 10368 Issued: 1998-09-01
Revised: 2003-03-31
Style 10368 XLPE Insulated Wire.
______________________________________________________________________________
Rating 105°C, 300 V.
Conductor No. 40-10 AWG, solid or stranded, silver plated, tinned
or bare copper.
*Insulation Irradiated PE, 9 mils minimum average thickness, 8 mils
minimum at any point. ______________________________________________________________________________
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
*to UL Tensile Strength and Elongation of Insulation
*Representative Spark Test.
UL (4) Detailed Examination.
Counter-Check (4) Tensile Strength and Elongation of Insulation.
Program (4) Heat Shock.
(4) Deformation.
(4) Cold Bend.
(12) Horizontal Flame Test.
Marking General.
Use Internal Wiring of Appliances. Tag may indicate the following: 600 Volts Peak - For Electronic Use Only.
NTC - network terminal circuit网络终端电路 (0) 投诉
