[问题求助] high speed cable哪种对线可以达到1G的传输速度?
P:2009-07-29 14:53:37
下面是客户需求的,哪种对线可以达到1G的传输速度?
The second if for signal 1G bit so twisted pair is probably the way to go. The connector must be for cable mount or mounted on a cable and IP 65 rated. The connector must come in both a male and female type both for cable mounting. The connector must comply with CE and possibly UL or ETL/CETL or it could also be two different connecters, one for EU and one for US if the price is too high for the UL connecter
IBCN - International broadband Communication Network国际宽带通信网 (0) 投诉
P:2009-07-29 23:29:41
应该是HDMI吧,能达到1G的速率速度不会长的
elastic state - 高弹性 (0) 投诉
