首页 > 国外线缆
[问题求助] 求UL 3499标准
P:2009-07-22 18:55:52
DHSC - double headed spin coating双头旋转涂覆 (0) 投诉
P:2009-07-23 15:13:58
Style 3499 EPDM Insulated Wire
______________________________________________________________________________
Rating 150°C, 7500 V.
*Conductor No. 8-600 kcmil solid or stranded, Pages 20, 26.
Insulation EPDM, 125 mils min avg., 112 mils min at any point wall.
(See Facing Page for Compound Designation).
Standard Test Reference Standard UL 1581 and Standard for Gas-Tube-
Sign and Ignition Cable UL 814.
Instructions Detailed examination.
to UL Physical properties (See Facing Page)
Representative Spark Test, Page 30, 12,500 V
Routine Voltage Application
Extended Voltage Application
Extended Voltage Application after Immersion
UL (4) Detailed examination.
Counter-Check (4) Physical properties (See Facing Page)
Program (2) Flame Test, Page 31.
(4) Routine Voltage Application
(4) Extended Voltage Application after Immersion
Marking General, Page 13.
Temperature marker required, Pages 18,19,20.
Use Internal wiring of appliances, where no flexing occurs,
either after installation or during servicing.
computerized process control system - 计算机化工艺控制系统 (1) 投诉
,无私啊。。。
