首页 > 专业英语|国际贸易
[专业词汇] 电缆术语 中-英文(汇集)
P:2009-07-18 09:47:37
导通阻Turning-on impedance
短.断路测试short/break circuit test
耐压测试:在DC=500V,AC=300V的条件下,绝缘阻抗不小于50M ohm
withstanding voltage test: under DC=500V, AC=300V, insulation resistance ≥ 50M ohm
摇摆测试Flexing test
电缆专业英语电工术语 电缆
Electrotechnical vocabulary -Electric cables
无镀层导体:plain conductor
金属镀层导体:metal coated conductor
镀锡导体:tinned conductor
金属包覆导体:metal-clad conductor
实心导体:solid conductor
实心导体可是圆形或者非圆形
绞合导体:stranded conductor
术语strand也可表示单线
圆形同心绞合导体:concentrically stranded circular conductor
束合导体:bunched conductor
复绞导体:multiple stranded conductor
软导体:flexible conductor
成型导体:shaped conductor
扇形导体:sector shaped conductor
紧压导体:compacted conductor
分割导体:milliken conductor
空心导体:hollow conductor
铜皮导体:tinsel conductor
同心股线:concentric strand
束合股线:bunched strand
同心中性导体:concentric neutral conductor
绝缘
导体绝缘
绕包绝缘:lapped insulation
浸渍纸绝缘:impregnated paper insulation
挤包绝缘:extruded insulation
矿物绝缘:mineral insulation
热塑性绝缘:thermoplastic insulation
热固性绝缘:thermosetting insulation
交联绝缘:cross-linked insulation
电屏蔽和接地金属屏蔽
电缆屏蔽:screen
导体屏蔽:conductor screen
绝缘线芯屏蔽:core screen
接地屏蔽:shield of a cable
可剥离屏蔽:strippable screen
粘结屏蔽:bonded screen
裸屏蔽线:drain wire /continuity wire
成缆
节距:length of lay
节径比:lay ratio
绞向:direction of lay
绝缘线芯:core
在北美,电缆的绝缘线芯core已经定义为电缆统包层(如护套)内各部件的组件,用insulated conductor表示
填充物:filler
缆芯:twisted loom/cabled assembly
SZ成缆:SZ cabling
隔离层:separator
内衬层:inner covering
护套:sheath jacket(北美采用)
外护套versheath /outer sheath protective jacket(北美采用)
加强层:reinforcement
铠装层:armor
螺旋扎紧带:spiral binder tape
垫层:bedding
外被层:serving
编织层:braid
滑线:skid wire
皱纹金属套:corrugated metallic sheath
内护套:inner sheath inner jacket(北美)
防护套:barrier sheath
阻水粉末:water blocking powder/swelling powder
阻水带:water blocking tape
阻水胶:water blocking glue swelling glue
分相屏蔽电缆:individually screened cable
径向电场电缆:radial field cable
软线:cord
成套线(电线组件):cord set
接地电极:earth electrode ground electrode(美国采用)
裸接地导体 uninsulated earth conductor
管式电缆:pipe-type cable
架空绝缘电缆:aerial cable
集束架空电缆:bundle assembled aerial cable
承力索:messenger
仪表电缆:measuring cable
热点偶补偿电缆:thermocouple compensation cable
终端:termination
密封终端:sealing end
终端盒:terminal box
分线盒:dividing box /spltter box
绕包式终端:taped termination
直通接头:straight joint
屏蔽导体,回流线:shielding conductor
绕包间隙:butt gap for cables
电缆盘:cable drum/cable reel
电缆线盘:cable spool
小规格的电缆盘
筒体:barrel
护板:lagging
电缆板条:cable lag
滚轮:roller
火花试验:spark test
电力电缆周期负荷载流量:cyclic current rating for electric cables
potted joint - 封装接头,密封接头(树脂浇铸或模制) (1) 投诉
P:2009-07-18 09:50:20
中拉机 medium wire drawing machine
中拉 intermediate drawing
中拉机 intermediate wire drawing machine
中拉机、大拉机 coarse wire drawing machine
粗-细线拉线机、中拉机 coarse-fine wire drawing machine
多根拉线-退火-束线机组 multi-wire drawing-annealing-bunching line
四节距束线机 four twist bunching machine
双节距束线机 double twist buncher
双节距束线机 double-twist bunch strander
双节距[双倍]束线机 double-twist bunching machine
双节距高速束线机 double-twist laying-up machine
复合束线、复[混[合束线 compound bunch
磨光机、束线机 buffing machine v
束线、束绞 n
束线 bunch v
束线、束绞 bunch-strand
束绞铜束线 bunch-stranded copper conductor
束线、绞合线 bunched wire
束线机 buncher
束线机 bunching machine
灌注 potting
双面双层十六头纱包机 16- head double-side douoble-rosette cotton covering machine)
立式双层鼓轮 vertical double draft bull block
双层编包风雨线 weatherproof double braid
双层挤出(机)头 twin (extruder) head
双层鼓轮拉线机 twin capstan drawing machine
双头挤出、双层挤出 twin-head extrusion
双层的 twin-layer
橡皮绝缘双层编包线 rubber-covered double braided
双层环氧漆包圆铜电磁线 heavy epoxy-coated round copper magnet wire
泡沫皮绝缘、泡沫/实心双层绝缘 foam skin insulation
双层编织机 double tier type braiding machine
双层钢丝铠装 double wire armour
双层钢丝铠装电缆 double wire-armoured cable
双层挤出(机)头 double(extruder)head
双层编织的 double-braid
双层编织式外导体同轴电缆 double-braid type coaxial cable
双层鼓轮拉线机 double-capstan wire drawing machine
双层滚筒六头拉线机 double-deck 6 head type machine
双层鼓轮 double-deck bull block
双层拉线鼓轮 double-deck drawing block
双层绝缘的 double-insulated
双层的 double-layer
双层一次挤出(法) double-layer coating co-extrusion
双层挤出(机)头 double-layer extrusion head
双层纸 double-ply paper
双丝包的、双层丝绝缘 double-silk covered
双层挤出(机)头 dual (extruder) head
泡沫/实心双层绝缘、泡沫绝缘 dual expanded plastic insulation
双层挤出机 dual extruder
双层绕包头 dual lapping head
双层的 duplex
双层纸 duplex paper
双层护套、焊接的皱纹金属管护套 duplex sheath
双层绕包头 duplicate lapping head
双层铠装 double armo(u)ring
双层鼓轮 double block
双层鼓轮拉线机 double block drawing machine
双层拉线鼓轮 double deck drawing capstan
双层环氧漆包圆铜电磁线 double epoxy-coated round copper magnet wire
双层绝缘导线 double insulated condutor
双层直角挤出机头 double layer crosshead
双层钢带铠装 double layer of steel-tape armour
双层钢带铠装 d.s.t.a.(double layer of steel-tape armour)
双层护套电缆的内护套直径 DOIJ
单层纸 simplex paper
单层滚筒七头拉线机 single deck 7 heads type machine
单层环氧漆包圆铜电磁线 single epoxy-coated round copper magnet wire
单层金属编织机 single tier type wire braiding machine
单层的 single-layer
单层电缆 single-layer cable
单层绞线 single-layer strand
单层纸包圆铜电磁线 single-paper-covered round copper magnet wire
单层纸 single-ply paper
单层纸 single-wire paper
单层 monolayer
单层甲板大帆船 galley
管式绞线机、管绞机 tube strander
管式绞线机、管绞机 tubular closer
管绞机 tubular strander
管式绞线机、管绞机 tubular stranding machine
管绞机筒体 stranding rotor
高速管绞机 high speed tubular stranding machine
SPTCA - Silver plated tin-copper alloy镀银锡铜合金 (1) 投诉
P:2009-07-18 09:53:08
拉丝乳剂 drawing compounds
拉丝润滑剂 drawing lubricants
拉丝用皂 drawing soaps8
模湿式拉丝机、八模湿拉机 wet drawing machine with 8 dies
拉线、拉丝 wire drawing
拉线模、拉丝模 wire drawing die
拉丝润滑剂 wire drawing lubricant
拉线机、拉丝机 wire drawing mill
拉丝、拔丝 wire-draw
拉丝机、拉丝工 wire-drawer
拉丝架[机] wire-drawing bench
拉丝设备[车间] wire-drawing plant
拉丝、拔丝 wireddrawing
拉丝模(板) wortle
钻石拉丝模超声抛光 ultrasonic diamond die polishing
钻石拉丝模超声抛光装置 ultrasonic diamond die polishing unit
超声波拉丝模打孔机 ultrasonic drawing die drilling machine
超声波拉丝模加工机 ultrasonic drawing die working machine
超声波拉丝机 ultrasonic drawing machine
碳化钨(拉丝)模、硬质合金(拉线)模 tungsten-carbide(drawing) die
组合式辊压模、互成直角的四辊轮拉丝模装置 turks(-)head
互成直角的四辊轮拉丝模装置 turks(head) roll
串列式退火机、连续拉丝退火机 tandem annealer
滑移式拉丝[线]机 slip drawing machine
拉丝溶液 solution-drawing
单道拉丝 single draft drawing
单模拉丝机 single draft drawing machine
单道拉丝 single-pass drawing(
光纤)拉丝机 pulling machine
拉丝模孔光洁度 profiloscope
光纤拉丝塔 optical fiber drawing tower
光纤拉丝机 optical fibre drawing machine
多头拉丝、多模拉丝 multiple drawing
多模拉丝机 multiple drawing machinen-
模连续拉丝机 n-die continuous wiredrawer
高性能拉丝生产线 high performance drawing line(
拉丝模的)研磨 grinding
光纤拉丝系统 fiber drawing system
光缆拉丝机 fiber pulling machine
光纤拉丝机 fiber-pulling machine
双列[双重]拉丝机 double row wire drawing machine
拉丝[线]机]、拔杆机 draw bench
拉丝机、拔杆机、拔管机 drawbench
拉丝(润滑液)槽 drawing batch
拉丝[线]机、拔杆机 drawing bench
拉丝润滑剂 drawing compound
拉丝塔轮、拉线鼓轮 drawing cone
拉丝设备 drawing equipment
拉丝[线]润滑液 drawing fluid
拉丝[线]润滑液 drawing oil
拉丝[线]润滑液 drawing solution
拉丝模具 drawing tool
拉丝配模、配模 dies arrangement
直接拉丝 direct drawing(
拉丝模)模座 die holder
塔轮式拉丝[线]机 cone-type drawing machine
拉丝模、拉丝机 bull block
拉丝机、拉丝模 bull-block
拉丝模、拉丝机 bullblock
防滑动拉丝机 anti-slipping drawing machine
立式单模大拉机、立式鼓轮 vertical bull block
Monosil material - 硅烷一步法交联材料(BICC和Nokia-Maillefer公司产品) (0) 投诉
P:2009-07-18 09:53:37
大拉 rod-breakdown
大拉机 large drawing mill
直线式单头大拉机 in-line bull block machine
卧式单模大拉机、卧式鼓轮 horizontal bull block
大拉机 heavy drawing machine
大拉 heavy rod drawing
大拉机 heavy rod drawing machine
拉线鼓轮、大拉机 drawing block
大拉 coarse drawing
单模大拉机 bull drawing block
大拉机 bar drawblock
小拉机 fine wire drawing
细拉 mini-drawing
细拉机 mini-drawing machine
细拉 mini-fine drawing
细拉 fine drawingvt
拉细丝、细拉 finedraw
细拉机 finishing block(
铜杆)剥皮 shave
铜杆剥皮 shaving of copper rod
铜杆的压延 rolling of copper rod
圆铜杆 round copper rod
电工用圆铜杆 round copper rod for electrical purpose
成圈铜杆放线架 pay-off stand for copper rods in coils
热轧铜杆 hot-rolled copper rod
铜杆 copper bar
铜杆、(电缆头用)铜出线梗、接线柱 copper rod
铜杆剥皮机 copper rod descaler
铜杆拉出 copper rod withdrawal
控制电缆 control cables
自动带宽控制 ABC
断线控制系统 wire break control system
线张力控制 wire tension control
线张力控制仪、紧线器 wire tensioner
电压控制 voltage contro
扭力控制装置 torsion control equipment
热液控制、液体控温(法) thermal liquid control
厚度(控制)仪、测厚仪 thickness gage
色调控制孔径 toll-control aperture
带子张力控制 tape tension control
温度控制[调节] temperature control
液体控温(法)、热液控制 temperature control by a liquid medium
温度控制仪 temperature control meter
张力控制[调节]装置 tension control device
张力控制装置 tension control unit
张力控制放线装置 tension controlled pay-off
张力控制仪 tensioner
测试线、控制[操作、监视]线 testing conductor
严格控制[检验、检查] strict control
严格控制[检验、检查] stringent test
监督、检验、检查、控制 supervision
电场控制[调整]、应力控制 stress control
应力控制带 stress control tape
应力控制管 stress control tubing
电[磁]场控制的、应力控制的 stress-controlling
严格检验[检查、控制] severe control
严格检验[检查、控制] severe test
控制线路用多芯用电缆、船用控制电缆 shipboard multicore cable for control circuits
硅管外径控制器 silica tube outer diameter controller
设定值、控制点 setpoint
严格检验[检查、控制] rigid test
严格检验[检查、控制] rigorous test
自动控制收线装置 robot take-up
垂度控制 sag control
垂度控制器 sag controller
垂度控制环 sag-control loop
调节[控制]范围 regulating range
调节[整]器、控制器 regulator
按扭控制[操纵] push-button control
质量控制[检验] quality control
质量检验[控制] quality inspection
生产过程控制、程序控制 process control
工序控制检验 process control inspection
生产过程控制 production control
程序控制 programme control
控制导线、辅助芯线 pilot
控制线芯、监视线芯 pilot conductor
导引绝缘线芯、控制线芯、监视线芯 pilot core
控制线、操作线 pilot line
压缩空气控制 pneumatic operation
放线人工控制速度 pay off manual speed control
放线自动控制微调 payoff automatic-control triment
氢氧焰温度控制器 oxyhydrogen flame temperature controller
控制板[配电盘]开关装置 panel switching equipment
操作台、操纵盘、控制板 operator panel
操作台、控制台 operator's desk
噪声控制装置 noise control equipment
非接触式线径控制仪 non-contact diameter monitor
微处理机控制话缆四线组测试仪 microprocessor telephone quad tester
监测器--电容量控制 monitor-capacitance control
监督、检验、检查、控制 monitoring
灯光显示控制 luminous control panel
生产过程控制 manufacturing control
流量控制器 mass flow controller
柔软云母材料 flexible mica material
软管;套管 sleeving(
柔软)复合材料;复合箔 combined (flexible)material
软化温度;软化点 softening temperature;softening point
软电缆 BX cable
屈服[流动、软化、击穿]点 yield point(YP)
extrusion foaming - 挤出发泡 (0) 投诉
P:2009-07-18 09:54:06
anti-slipping drawing machine - 防滑动拉线机 (0) 投诉
P:2009-07-18 09:55:09
rope-lay cable - 复绞电缆,同心螺绞电缆 (0) 投诉
P:2009-07-18 09:56:39
correction coefficient - 修正系数 (0) 投诉
P:2009-07-18 09:57:43
Ozone crack - 臭氧龟裂 (0) 投诉
P:2009-07-18 09:58:16
wire connector - 接线器 (0) 投诉
P:2009-07-18 09:58:45
pressure nozzle - 压力喷嘴 (0) 投诉
P:2009-07-18 09:59:17
pointing and pulling-in machine - 轧头穿模机 (0) 投诉
P:2009-07-18 09:59:50
individual screened - 分相屏蔽,分屏蔽 (0) 投诉
P:2009-07-18 10:00:14
flight - 螺杆螺纹 (0) 投诉
P:2009-07-18 10:00:43
medium-voltage cable - 中压电缆,中电压电缆 (0) 投诉
P:2009-07-18 10:01:08
半导体护套 semi-conducting jacket
护套剥离绳 rip cord
橡皮绝缘护套 rubber insulating blanket
橡皮护套、橡套 rubber sheath
加固型铅护套 reinforced lead sheath
增强型护套 reinforced sheathv
剥除(绝缘、护套)、拆卸 remove
铝护套电力电缆 power cable with aluminium sheath
抗压力护套 pressure-retaining sheath
护套 protective jacket
护套、护层 protective jackte
护套 protective sheath
平[光]滑护套 plain sheath
塑料护套 plastic sheath
塑料护套厚度检测装置 plastic thickness test unit
塑料[非金属]护套电缆 plastic-sheathed cable
塑料护套软线 plastic-sheathed flexible cord
氯丁橡胶护套电缆 polychloroprene sheathed cable
聚乙烯护套 polyethylene jacket
聚乙烯护套料 polyethylene jacking compound8
字形绕包聚乙烯护套 polyethylene sheath of figure-8 formation
聚乙烯护套料 polyethylene sheating compound
聚乙烯护套电缆 polyethylene-jacketed cable
铅-聚乙烯综合护套 polyethylene-protected lead sheath
聚乙烯铝膜粘接护套 polyethylene/aluminium bonded laminate sheath
聚乙烯护套电缆 polythene jacketed cable
聚乙烯绝缘聚氯乙烯护套电缆 polythene-insulated cable sheathed with PVC
聚氯乙烯绝缘及护套电缆 polyvinyl chloride insulated and sheathed cable
聚氯乙烯护套 polyvinyl chloride jacket
护套的透潮 permeation through jacket
普通塑料护套软线 ordinary plastic-sheathed flexible cord
普通聚氯乙烯护套软线 ordinary(PVC-)sheathed flexible cord
聚合物外护套 outer polymeric sheath
外护套 outer sheath
外护套 outer shell
外护套、外护层 overcoat
外护套、外护层 oversheath
耐臭氧乙丙橡胶护套 ozone-resisting ethylene propylene rubber jacket
包套、外护套 package sheathing(
油浸)纸绝缘铅护套电缆 paper-insulated lead-covered cable(
油浸)纸绝缘铅护套电缆 paper-insulated lead-sheathed cable
纸绝缘金属护套电缆 paper-insulated metal-sheathed cable
非金属护套 non-metallic sheath
非金属护套电缆 non-metallic-sheathed cable
无护套电缆 non-sheathed cable
固定布线用无护套电缆 non-sheathed cable for fixed wiring
非金属护套 nonmetallic covering
尼龙护套电缆 nylon jacketed cable
尼龙护套光纤 nylon-jacketed optical fiber
纸绝缘金属护套充油电缆 oil-filled paper-insulated metal-sheathed cable
光缆护套挤出生产线 optical cable sheathing line
多层护套(北美采用) multilayered jacket
多层护套 multilayered sheath
多层护套、层式护套 multiple sheath
physical transmission network - 物理传输网络 (0) 投诉
111
