首页 > 国外线缆
[问题求助] UL2835 能不能用铜包铝做导体
P:2009-10-30 19:56:35
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 2 Page 2835 Issued: 1976-10-28
Revised: 2003-01-03
Style 2835 | PVC Jacketed Cable. |
Rating | 60C, 30 V. |
Conductor | 40 AWG minimum. Material not specified. |
Insulated Singles | Material not specified for use statement 1A or 1B. Labeled or complies with manufacturer's Procedure for use statement 2A or 2B. |
Assembly | Consists of two or more conductors, twisted pairs, or groups of twisted conductors. The conductors may be laid parallel or twisted together to form a flat, oval, or round cable construction. Lay not specified. Barrier layer and/or fillers optional. May use same or mixed AWG sizes. Manufacturer shall maintain a complete description of each assembly. |
Covering | Optional. PVC, 5 mils minimum at any point, over the assembly or groups of singles. |
Shield | Optional. May be over one or more of the insulated conductors or applied over the assembly. |
Jacket * * | PVC - Class 43. If parallel construction is rippable, the measurements are made after ripping. Dia# of Cable under Jacket Minimum Minimum in inches Average (mils) at any point 0.250 or less (1A,2A only) 15 13 0.250 or less (1B,2B only) 30 27 0.251 - 0.424 30 27 0.425 - 0.700 60 48 0.701 - 1.500 80 64 1.501 - 2.500 110 88 2.501 or larger 140 112 # = Major diameter if flat or oval construction. |
(Continued on Page 2835A)
Subj. 758 Section 2 Page 2835A Issued: 1976-10-28
Revised: 2003-01-03
Standard | Appliance Wiring Material UL 758. |
Instructions to UL Representative | Detailed Examination. |
UL Counter-Check Program | (4) Detailed Examination. (4) Flexibility Test. (12) Cable Flame Test on Completed Cable, External Use, Constructions 1B and 2B. (12) Horizontal Flame Test on Completed Cable Internal Use, Constructions 1A and 2A. |
Marking | General. |
Use No. 1A Use No. 1B Use No. 2A Use No. 2B | Internal wiring in Class 2 circuits of electronic equipment where each end is terminated in connectors. CABLES - using 30 mils or greater jacket thickness only: External interconnection or internal wiring in Class 2 circuits of electronic equipment where each end is terminated in connectors. Internal wiring in Class 2 circuits of electronic equipment where not routed along walls, floors, or other abuse areas. CABLES - using 30 mils or greater jacket thickness only: External interconnection or internal wiring in Class 2. |
auto-readout laser gauge - 自动读数激光测量仪 (0) 投诉
