[技术资料] HDMI高頻特性要求及測試參數
P:2007-01-23 18:01:34
HDMI高頻特性要求及測試參數,供大家参考。有不正之处请指出,谢谢!
編號 NO. 量測參數 (Parameter Measured) 試驗條件 建議規范 1 差分阻抗 TDR Measurement 100Ω±10Ω(Cable) 100Ω±15Ω(Assembly) 100Ω±15Ω(Conn.) (Differential Impedance) 200ps Differential Risetime 2 差動延遲 TDR/TDT Measurement 5.05ns/M(Assembly) (Differential Delay) 200ps Differential Risetime 3 差分對間延遲差 TDR/TDT Measurement 0.4 Tpixel(Assembly) 最嚴格的為2.42ns (Inter-Pair skew) 200ps Differential Risetime 4 差分對內延遲差 TDR/TDT Measurement 0.25 TBit(Assembly) 最嚴格的為151ns (Intra-Pair skew) 200ps Differential Risetime 5 遠端串音 TDT Measurement 5%(Assembly) (Far-end Crosstalk) 200ps Differential Risetime 6 遠端串音 NA Measurement -26dB/max@ 1~5000MHz (Far-end Crosstalk) 7 傳輸損失 NA Measurement -8dB/max@1~825MHz -21dB/max@825~2475MHz -30dB/max@2475~4125MHz (Attenuation/Insertion Loss)
silane water cure method - 硅烷温水交联法 (0) 投诉
34
