首页 > 国外线缆
[问题求助] UL1015 /UL1569/UL1007材料
P:2009-06-26 10:30:09
本人急切地求助各位,UL1015,UL1569,UL1007是用什么绝缘料生产,本人非常感谢各位大侠的帮忙!
funnel - 漏斗;缩孔,漏斗形物 (0) 投诉
P:2009-06-26 10:49:56
用PVC生产
IDC - International Documentation Center国际文献中心<设在瑞典 (0) 投诉
P:2009-06-26 13:51:48
建议楼主看看UL758规范!
ACSE - ACSR/AS铝包钢芯铝绞线 (0) 投诉
P:2009-06-26 14:22:03
相关的UL STYLE PAGE上有明确的规定
cN - centi-newton 1/100牛顿,10-2牛顿 (0) 投诉
P:2009-07-01 16:51:18
給你STYLE PAGE 參考下:
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758 Section 1 *Page 1007 Issued: May 1, 1959
Revised: June 20, 2001
Style 1007 Polyvinyl Chloride Insulated Wire.
____________________________________________________________________________
Rating 80°C, 300 V.
Conductor 32-16 AWG, solid or stranded.
Insulation Polyvinyl Chloride, 15-Mils minimum average,
13 mils minimum at any point, 60 or 80°C in oil,
if applicable.
_____________________________________________________________________________
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Physical Properties, unaged.
Representative Spark Test.
UL (4) Detailed Examination.
Counter-Check (4) Physical Properties.
Program (4) Heat Shock.
(4) Cold Bend
(4) Horizontal Flame Test.
(4) Deformation.
Marking General.
Use Internal wiring of Appliances; or where exposed to oil at
a temperature not exceeding 60°C or 80°C, whichever is
applicable. Tags may indicate the following: 600 V Peak -
For Electronic Use Only.
wiring capacity - 布线电容 (0) 投诉
P:2009-07-01 20:14:08
dbhouse:
简单的说:
1007  用 80度PVC生产
1015和1569 用 105度PVC生产
high-temperature flexibles - 高温软线 (0) 投诉
P:2011-07-08 08:23:26
1007用80度PVC
VHSIC - very high speed integrated circuit 极高速集成电路 (0) 投诉
