首页 > 专业英语|国际贸易
[专业词汇] 电线电缆行业词汇中英文对照(比较齐全)
P:2007-01-21 15:15:31
湿式中拉机 medium wet drawing machine
中拉机 medium wire drawing machine
中拉 intermediate drawing
中拉机 intermediate wire drawing machine
中拉机、大拉机 coarse wire drawing machine
粗-细线拉线机、中拉机 coarse-fine wire drawing machine
多根拉线-退火-束线机组 multi-wire drawing-annealing-bunching line
四节距束线机 four twist bunching machine
双节距束线机 double twist buncher
双节距束线机 double-twist bunch strander
双节距[双倍]束线机 double-twist bunching machine
双节距高速束线机 double-twist laying-up machine
复合束线、复[混[合束线 compound bunch
磨光机、束线机 buffing machine
束线、束绞、束线 bunch
束线、束绞 bunch-strand
束绞铜束线 bunch-stranded copper conductor
束线、绞合线 bunched wire
束线机 buncher
束线机 bunching machine
灌注 potting
双面双层十六头纱包机 16- head double-side douoble-rosette cotton covering machine
立式双层鼓轮 vertical double draft bull block
双层编包风雨线 weatherproof double braid
双层挤出(机)头 twin (extruder) head
双层鼓轮拉线机 twin capstan drawing machine
双头挤出、双层挤出 twin-head extrusion
双层的 twin-layer
橡皮绝缘双层编包线 rubber-covered double braided
双层环氧漆包圆铜电磁线 heavy epoxy-coated round copper magnet wire
泡沫皮绝缘、泡沫/实心双层绝缘 foam skin insulation
双层编织机 double tier type braiding machine
双层钢丝铠装 double wire armour
双层钢丝铠装电缆 double wire-armoured cable
双层挤出(机)头 double(extruder)head
双层编织的 double-braid
双层编织式外导体同轴电缆 double-braid type coaxial cable
双层鼓轮拉线机 double-capstan wire drawing machine
双层滚筒六头拉线机 double-deck 6 head type machine
双层鼓轮 double-deck bull block
双层拉线鼓轮 double-deck drawing block
双层绝缘的 double-insulated
双层的 double-layer
双层一次挤出(法) double-layer coating co-extrusion
双层挤出(机)头 double-layer extrusion head
双层纸 double-ply paper
双丝包的、双层丝绝缘 double-silk covered
双层挤出(机)头 dual (extruder) head
泡沫/实心双层绝缘、泡沫绝缘 dual expanded plastic insulation
双层挤出机 dual extruder
双层绕包头 dual lapping head
双层的 duplex
双层纸 duplex paper
双层护套、焊接的皱纹金属管护套 duplex sheath
双层绕包头 duplicate lapping head
双层铠装 double armo(u)ring
双层鼓轮 double block
双层鼓轮拉线机 double block drawing machine
双层拉线鼓轮 double deck drawing capstan
双层环氧漆包圆铜电磁线 double epoxy-coated round copper magnet wire
双层绝缘导线 double insulated condutor
双层直角挤出机头 double layer crosshead
双层钢带铠装 double layer of steel-tape armour
双层钢带铠装 d.s.t.a.(double layer of steel-tape armour)
双层护套电缆的内护套直径 DOIJ
单层纸 simplex paper
单层滚筒七头拉线机 single deck 7 heads type machine
单层环氧漆包圆铜电磁线 single epoxy-coated round copper magnet wire
单层金属编织机 single tier type wire braiding machine
单层的 single-layer
单层电缆 single-layer cable
单层绞线 single-layer strand
单层纸包圆铜电磁线 single-paper-covered round copper magnet wire
单层纸 single-ply paper
单层纸 single-wire paper
单层 monolayer
单层甲板大帆船 galley
管式绞线机、管绞机 tube strander
管式绞线机、管绞机 tubular closer
管绞机 tubular strander
管式绞线机、管绞机 tubular stranding machine
管绞机筒体 stranding rotor
高速管绞机 high speed tubular stranding machine
光纤拉丝 optical fibre drawing
拉丝乳剂 drawing compounds
拉丝润滑剂 drawing lubricants
拉丝用皂 drawing soaps8
模湿式拉丝机、八模湿拉机 wet drawing machine with 8 dies
拉线、拉丝 wire drawing
拉线模、拉丝模 wire drawing die
拉丝润滑剂 wire drawing lubricant
拉线机、拉丝机 wire drawing miller
拉丝、拔丝 wire-draw
拉丝机、拉丝工 wire-drawer
拉丝架[机] wire-drawing bench
拉丝设备[车间] wire-drawing plant
拉丝、拔丝 wireddrawing
拉丝模(板) wortle
钻石拉丝模超声抛光 ultrasonic diamond die polishing
钻石拉丝模超声抛光装置 ultrasonic diamond die polishing unit
超声波拉丝模打孔机 ultrasonic drawing die drilling machine
超声波拉丝模加工机 ultrasonic drawing die working machine
超声波拉丝机 ultrasonic drawing machine
碳化钨(拉丝)模、硬质合金(拉线)模 tungsten-carbide(drawing) die
组合式辊压模、互成直角的四辊轮拉丝模装置 turks(-)head
互成直角的四辊轮拉丝模装置 turks(head) roll
串列式退火机、连续拉丝退火机 tandem annealer
滑移式拉丝[线]机 slip drawing machine
拉丝溶液 solution-drawing
单道拉丝 single draft drawing
单模拉丝机 single draft drawing machine
单道拉丝 single-pass drawing(光纤)拉丝机 pulling machine
拉丝模孔光洁度 profiloscope
光纤拉丝塔 optical fiber drawing tower
光纤拉丝机 optical fibre drawing machine
多头拉丝、多模拉丝 multiple drawing
多模拉丝机 multiple drawing machinen-
模连续拉丝机 n-die continuous wiredrawer
高性能拉丝生产线 high performance drawing line(拉丝模的)研磨 grinding
光纤拉丝系统 fiber drawing system
光缆拉丝机 fiber pulling machine
光纤拉丝机 fiber-pulling machine
双列[双重]拉丝机 double row wire drawing machine
拉丝[线]机]、拔杆机 draw bench
拉丝机、拔杆机、拔管机 drawbench
拉丝(润滑液)槽 drawing batch
拉丝[线]机、拔杆机 drawing bench
拉丝润滑剂 drawing compound
拉丝塔轮、拉线鼓轮 drawing cone
拉丝设备 drawing equipment
拉丝[线]润滑液 drawing fluid
拉丝[线]润滑液 drawing oil
拉丝[线]润滑液 drawing solution
拉丝模具 drawing tool
拉丝配模、配模 dies arrangement
直接拉丝 direct drawing(拉丝模)模座 die holder
塔轮式拉丝[线]机 cone-type drawing machine
拉丝模、拉丝机 bull block
拉丝机、拉丝模 bull-block
拉丝模、拉丝机 bullblock
防滑动拉丝机 anti-slipping drawing machine
立式单模大拉机、立式鼓轮 vertical bull block
粗拉机、大拉机、开坯机 rod breakdown machine
大拉 rod-breakdown
大拉机 large drawing mill
直线式单头大拉机 in-line bull block machine
卧式单模大拉机、卧式鼓轮 horizontal bull block
大拉机 heavy drawing machine
大拉 heavy rod drawing
大拉机 heavy rod drawing machine
拉线鼓轮、大拉机 drawing block
大拉 coarse drawing
单模大拉机 bull drawing block
大拉机 bar drawblock
小拉机 fine wire drawing
细拉 mini-drawing
细拉机 mini-drawing machine
细拉 mini-fine drawing
细拉 fine drawingvt
拉细丝、细拉 finedraw
细拉机 finishing block(铜杆)剥皮 shave
铜杆剥皮 shaving of copper rod
铜杆的压延 rolling of copper rod
圆铜杆 round copper rod
电工用圆铜杆 round copper rod for electrical purpose
成圈铜杆放线架 pay-off stand for copper rods in coils
热轧铜杆 hot-rolled copper rod
铜杆 copper bar
铜杆、(电缆头用)铜出线梗、接线柱 copper rod
铜杆剥皮机 copper rod descaler
铜杆拉出 copper rod withdrawal
控制电缆 control cables
自动带宽控制 ABC
断线控制系统 wire break control system
线张力控制 wire tension control
线张力控制仪、紧线器 wire tensioner
电压控制 voltage contro
扭力控制装置 torsion control equipment
热液控制、液体控温(法) thermal liquid control
厚度(控制)仪、测厚仪 thickness gage
色调控制孔径 toll-control aperture
带子张力控制 tape tension control
温度控制[调节] temperature control
液体控温(法)、热液控制 temperature control by a liquid medium
温度控制仪 temperature control meter
张力控制[调节]装置 tension control device
张力控制装置 tension control unit
张力控制放线装置 tension controlled pay-off
张力控制仪 tensioner
测试线、控制[操作、监视]线 testing conductor
严格控制[检验、检查] strict control
严格控制[检验、检查] stringent test
监督、检验、检查、控制 supervision
电场控制[调整]、应力控制 stress control
应力控制带 stress control tape
应力控制管 stress control tubing
电[磁]场控制的、应力控制的 stress-controlling
严格检验[检查、控制] severe control
严格检验[检查、控制] severe test
控制线路用多芯用电缆、船用控制电缆 shipboard multicore cable for control circuits
硅管外径控制器 silica tube outer diameter controller
设定值、控制点 setpoint
严格检验[检查、控制] rigid test
严格检验[检查、控制] rigorous test
自动控制收线装置 robot take-up
垂度控制 sag control
垂度控制器 sag controller
垂度控制环 sag-control loop
调节[控制]范围 regulating range
调节[整]器、控制器 regulator
按扭控制[操纵] push-button control
质量控制[检验] quality control
质量检验[控制] quality inspection
生产过程控制、程序控制 process control
工序控制检验 process control inspection
生产过程控制 production control
程序控制 programme control
控制导线、辅助芯线 pilot
控制线芯、监视线芯 pilot conductor
导引绝缘线芯、控制线芯、监视线芯 pilot core
控制线、操作线 pilot line
压缩空气控制 pneumatic operation
放线人工控制速度 pay off manual speed control
放线自动控制微调 payoff automatic-control triment
氢氧焰温度控制器 oxyhydrogen flame temperature controller
控制板[配电盘]开关装置 panel switching equipment
操作台、操纵盘、控制板 operator panel
操作台、控制台 operator's desk
噪声控制装置 noise control equipment
非接触式线径控制仪 non-contact diameter monitor
微处理机控制话缆四线组测试仪 microprocessor telephone quad tester
监测器--电容量控制 monitor-capacitance control
监督、检验、检查、控制 monitoring
灯光显示控制 luminous control panel
生产过程控制 manufacturing control
流量控制器 mass flow controller
柔软云母材料 flexible mica material
软管;套管 sleeving(
柔软)复合材料;复合箔 combined (flexible)material
软化温度;软化点 softening temperature;softening point
软电缆 BX cable
屈服[流动、软化、击穿]点 yield point(YP)
屈服强度、软化强度 yield strength
乙烯绝缘软电缆 vinyl cabtyre cable
耐水软线 water-resistan cord
热塑流试验、软化击穿试验 thermoplastic flow test
三芯电力软线 three conductor power cord
三芯软线 three-core cord
三芯软线 three-way cord
镀锡软铜绞线 tined soft copper stranded wire
箔软线、塞线 tinsel cord
电话软线 telephone cord
电信软件 telesoftware
电源软线 supply cord
交换机电缆[塞子软线] switchboard cable
退火(软)线 soft annealed wire
退火、韧炼、软化退火 soft annealing
软电缆 soft cable
软陶瓷绝缘电磁线 soft ceramic insulated magnet wire
软涂层 soft coating
软拉 soft drawn
软或退火铜线、软铜线 soft or annealed copper wire
箔软线、塞线 tinsel cord
电话软线 telephone cord
电信软件 telesoftware
电源软线 supply cord
软电缆 soft cable
软涂层 soft coating
软拉 soft drawn
软橡胶 soft rubber
软链段 soft segment
软焊料钎焊、锡焊 soft soldering
退火铜线、软铜线 soft-annealed copper wirev
软焊料钎焊、锡焊 soft-solder
软化剂 softener
软化 softening
软化剂 softening agent
软化[退火]装置 softening plant
软化点 softening point
软化区、增塑区 softening region
软钎焊(缝、点、头) soldered joint
软钎焊(缝、点、头) soldering joint
扁形(软线)接头 spade tag
扇形(软线)接头 spade terminal
螺旋芯软线、有弹簧的塞绳 spiral-conductor flexible cord
星绞八芯软电缆 spiral-eight cable
星绞四芯软电缆 spiral-four cable
星绞四芯软电缆 spiral-four type cable
船用软同轴电缆 shipboard flexible coaxial cable
爆破[放炮]用软线 shot-fire cord
丝包软线 silk-covered cord
镀银软或退火铜线、镀银软铜线 silver-coated soft or annealed copper wire
单线软绳 single-wire cord
可收缩软线、弹簧线 retractile cord
橡套软电缆 rubber jacketed flexible cable
橡胶素炼机、软胶机 rubber-homogenizer
软拉 s.d.(soft drawn)
游览车用软线 recreational-vehicle cord
预装配的软电缆 pre-assembled flexible cable
预装配的软电缆及软线 pre-assembled flexible cables and cords
精密排列的扁形软电缆 precision-tiered flat flexible cable
抽头、引线、软导线 pigtail
超软细股线 pigtail wire
塑料护套软线 plastic-sheathed flexible cord
移动式软线 portable cord
普通塑料护套软线 ordinary plastic-sheathed flexible cord
普通型耐磨橡套软电缆 ordinary tough-rubber sheathed flexible cable
普通耐磨橡套软线 ordinary tough-rubber sheathed flexible cord
普通聚氯乙烯护套软线 ordinary(PVC-)sheathed flexible cord
耐油软线 oil-proof cord
耐油软线 oil-resistant cord
光纤软线 optical fiber cord
多芯软线 multicore cord
多芯软线 multiple cord
网络软件 network software
镀镍软或退火铜线、镀镍软铜线 nickel-coated soft or annealed copper wire
麦克风[话筒]软线 microphone cord
麦克风[话筒]软线 mike cord
移动房屋用软线 mobile-home cord
定型设计的电话软线、弹簧电话软线 modular telephone cord
防潮双绞软线 moisture proof twisted cord
单塞绳、单软线 monocord
低温柔软性 low temperature flexibility
低漏泄电流用户软线 low-leakage-current service cord
轻型塑料护套软线 light plastic-sheathed flexible cord
轻型聚氯乙烯护套软线 light(PVC) sheathed flexible cord
电灯(软)线 lamp cord
铅合金包覆软铜线 lead-alloy-coated soft copper wire
铅包软铜线 lead-coated soft copper wire
仪器用软线[塞绳] instrument cord
绝缘软线 insulated flexible wire
综合软件 integrated software
高温软线 high-temperature flexibles
素炼机、软胶机 homogenizing roller
布线用线、安装线、跨接线、柔软连接线 hook-up wire
软管、橡皮管 hose
苛刻条件用软线 hard-service cord
耐热护套软电缆 heat-resistant sheathed flexible cable
重型耐磨橡套软电缆 heavy tough-rubber sheathed flexible cable
镀锌软[低碳]钢丝 galvanized mild steel wire
玻璃丝绝缘软线 glass-fiber-insulated flexibles
馈电软线 feed cord
一级软线 first class flexible cord
扁形软电缆 flat flexible cable
扁形双芯软线 flat twin flexible cord
扁形双芯软线[塞绳] flat twin tinsel cord
软线 flex conductor
柔软性 flexibility
柔软度试验 flexibility test
柔软的 flexible
软电缆 flexible cable
矿工帽灯用软线 flexible cable for miners' cap lamps
软接线 flexible circuit conductor
软导体、柔软导体、软线 flexible conductor
软线、连接塞绳 flexible cord
电缆软接头 flexible joint
移动式电力软线 flexible portable power cord
电力软线 flexible power cord
软绞线 flexible stranded conductor
软绞线 flexible stranded wire
软[花、皮]线 flexible wire
软线布线 flexible wiring
软线、软绳 flexibles
弹性[延伸]软绳 extension cord
特软绞线 extra-flexible stranded conductor
极苛刻条件用软线双芯软线[塞绳] double conductor cord
软化击穿 cut-through
耐切通性、切通强度、耐软化击穿性能 cut-through resistance
切通温度、软化击穿温度 cut-through temperature
切通试验、软化击穿试验 cut-through test
连接塞绳、软线 connecting cord
铜芯聚氯乙烯绝缘平型软线 copper conductor PVC-insulated parallel flexible cord
铜芯聚氯乙烯绝缘绞型软线 copper conductor PVC-insulated twisted flexible cord
软线[绳]、电线电缆、塞绳 cord
花线、装饰线路用软线 cord for decorative chains
带有插塞的电话软线 cord setextra-hard-service cord
成套塞绳、带有插塞的电话软线彩色软线 colour cord
通信软件 communication software
锥形软模具 cone-shaped flexible die
同轴软线、同轴线塞绳 coaxial cord
螺圈形软线 coiled cord
橡皮绝缘(软)电缆、橡套[软件]电缆 cabtyre cable
橡套电缆、软管电缆 cabtyre sheathed cable
配套软件 bundled software
软管电缆 cab-tire cable
橡皮绝缘软线〔软塞绳〕 cab-tyre cord
电缆软接头 cable flexible joint
软连接用电缆 cable for flexible connections
电缆软管 cable hose
电缆软管夹托架 cable hose clamp bracket
编织软绳 braided flexible cord
退火、韧炼、软化 anneal
屈服[流动、软化、击穿]点 YP(yield point)
柔软控制电缆 FCC(flexible control cable)
硬链段与软链段的嵌段共聚物 HYTREL
挤出机 extruders
挤出 extrusion
挤气式挤出机 vent extruder
通用回转式挤出机 versatile turret extruder
立式连续挤出硫化机组 vertical continuous extruding and vulcanizing machine
立式挤出机 vertical extruder
立式挤出 vertical extrusion
二段式挤出机 two-stage extruder
三层挤出机 triple extruder
三层挤出(机)头 triple extruder head
三层挤出(机)头 triple extrusion head
双螺杆挤出机 twin-screw extruder
三层挤出绝缘电缆 three-layer extruded cable(挤出机)模嘴、模芯、末端 tip
串列式挤出机 tandem extruder
挤出物料的脱节 starving of extrudate flow(挤出机)送料螺杆 stockscrew
滤网<挤出机的> strainer
剪切式挤出机头 shear-type extrusion head
护套挤出机 sheathing machine
单螺杆挤出机 single screw extruder(挤出机筒内)焦烧、早期硫化 scorching(in extruder cylinder)
螺杆式挤出机 screw extruder
半导体材料挤出机 semicon extruder
挤出头、压力模座 press block
压力型多层一次挤出模 pressure-type coextrusion die
分段式挤出机 piggyback extruder
行星齿轮式挤出机 planetary gear extruder
(塑料)挤出机 plastic extruder
制粒挤出机 pelletising extruder(挤出机)斜角机头 oblique head
单段式挤出机 one-stage extruder
光缆护套挤出生产线 optical cable sheathing line
多色挤出机 multi-colour extruder
多层挤出机 multi-layer extruder
多级[多段]式挤出机 multi-stage extruder
多根挤出法 multi-wire insulation process
多头挤出装置 multiline extrusion system
多层挤出 multiple extrusion(挤出机)螺杆的计量区 metering section of a screw
混炼挤出机 mixer-extruder
混炼、排气、挤出联合机 mixing ,venting and extruding machine
标色挤出机 marking extruder
铅管挤出机 lead-pipe extrusion press
内皮挤出机 inner skin extruder
绝缘机头、挤出机头 insulating machine head
高效挤出机 high output extruder
高速挤出生产流水线 high speed tandemized extrusion line
高发泡挤出 high-foaming extrusion
高发泡挤出生产线 high-foaming extrusion line
高速挤出生产流水线 high-speed tandemized extrusion line
卧式挤出机 horizontal axis extruder
卧式挤出机 horizontal extrusion press
热挤出 hot extrusion
热挤出用润滑剂 hot extrusion lubricant
静液(压)挤出 hydrostatic extrusion
模芯导向器(挤出机模子) guider tip
注气体挤出机 gas-injection extruder
热挤出 hot extrusion
泡沫挤出生产线 foam extrusion line
泡沫绝缘挤出 foam insulation extrusion
前端驱动挤出机 front-end drive extruder
光纤松套管-紧包缓冲层挤出生产线 fiber-optic loose tube-tight buffer
出线区、挤出区 exit zone
挤出机 extr.
可挤出性、可挤压性 extrudability
挤出物、挤制材料 extrudate
挤出物温度 extrudate temperaturev
挤出[压、包、制] extrude
挤出[压、包、制]的 extruded
挤出型绝缘电缆 extruded cable
挤出型绝缘电缆 extruded dielectric cable
挤出机、挤压机 extruder
挤出机筒体 extruder barrel
挤出机机筒内径 extruder bore
直角挤出机头 extruder crosshead
挤出(机)模具 extruder dies
挤出(机)头 extruder head
挤出机挤出量 extruder output
挤出机螺杆 extruder screw
挤出[制、包、压] extruding
挤出机 extruding machine
挤出[制、包、压] extrusion
挤出模具 extrusion die
挤出(机)模具 extrusion dies
挤出涂漆法 extrusion enamelling process
挤出发泡 extrusion foaming
挤出发泡法 extrusion foaming method
挤出(机)头 extrusion head
挤出指数 extrusion index
挤出生产线速度 extrusion line speed
挤出压力 extrusion pressure
挤出[压、包、制]方法 extrusion process
挤出工艺 extrusion processing
挤出性能 extrusion property
挤出量、挤出速度[量] extrusion rate
挤出(机)螺杆 extrusion screw
挤出技术、挤出工艺 extrusion technology
挤出温度 extrusion temperature
挤出机模芯 extrusion tip
挤出模具 extrusion tool
挤出速度 extrusion velocity
挤出轮 extrusion wheel
有壳挤出 extrusion with shell
无壳挤出 extrusion without shell
(漆包线的)挤出涂漆法 emailex method
(漆包线的)挤出涂漆法 emailex process
双螺杆挤出机 double screw extruder
双层挤出机 dual extruder
非连续性挤出 discontinuous extrusion
挤出机机头口型 die lips
挤出机机头口型间隙 die lips gap(控制)压力挤出法 controlled pressure extrusion
粉末涂敷 powder coating
室温固化 cold curing cold setting
十八盘两段卧式绞线成缆机18- bobbin 2-cage horizontal wire stranding and laying-up machine2/2
芯单段成缆机2/2- core single cage laying-up machinev
成缆、布[配]线、敷设电缆[线] wire
未成缆光纤 uncabled fiber
绞线成缆联合机 stranding and laying-up machine
单节距成缆机 single twist cabler
单节距[单绞式]成缆机 single-twist cabling machine
刚性成缆机 rigid cabling machine
行星式成缆机 planetary cabler
行星式成缆机 planetary cabling machine
行星式成缆机 planetary laying-up machine
行星式成缆机 planetary-type cabling machine
光纤成缆技术 optical fiber laying-up technology
成缆角 laying angle
绞缆、成缆、线芯绞合、敷设 laying up
盘式成缆机 laying up drum twister
成缆工段 laying up section
成缆 laying-up
成缆和包带生产线 laying-up and taping line
成缆角 laying-up angle
成缆机、线芯绞合机 laying-up machine
成缆操作、成缆工序 laying-up operation
成缆用盘 laying-up reel
重型电缆敷设装置、重型成缆设备 heavy cabling equipment
双节距成缆机 double-twist cabling machine
双绞式[双节距]成缆机 double-twist flyer-type high-speed stranding machine
双绞式[双节距]成缆机 double-twist strander/laying-up machine
盘式成缆机 drum cabling machine
盘绞式成缆机 drum twister laying-up machine
盘绞式成缆机 drum twister type cabling machine
盘绞式成缆机 drum twisting assembling machine
盘绞式绞线机、盘绞式成缆机 drum twisting machine
线芯绞合、绞缆、成缆 core stranding
全套挤塑-成缆生产线 complete extrusion-cabling line
成缆材料、包覆材料 cladding material
成缆、绞缆 cable-laying
成缆机 cable-laying-up machine
成缆构件 cabled complement
成缆光纤 cabled optical fiber
成缆(后)包带 cabled tape
成缆机、成缆机、电缆盘 cabler
成缆、成缆、电线敷设、布线、电缆敷设 cabling
成缆损耗 cabling absorption
成缆工段 cabling department
成缆设备、布线设备 cabling equipment
成缆机 cabling machine
成缆放装置 cabling pay-off
成缆工艺 cabling processv
电缆 cable
弓式成缆机 bow cabling machine
弓式成缆机 bow type stranding machine
绞缆机、成缆机 assembling machineSZ
绞成缆机 SZ cabling machineSZ
绞合机、左右绞合机、 SZ
成缆机 SZ strander
电缆填充 cable filling
绕包、缠绕、电缆填充物 wormings
凡士林填充市话电缆 vaseline filled local cable
电缆内壁填充剂[物] wall cable filler
填料、填充、塞入 stuffing
填料[填充]法 stuffing process
浇注温度、填充温度 pouring temperature
粉沫填充电缆 powder filled cable
压力填充 pressure excited filling
聚乙烯填充物 polyethylene filler
聚丙烯填充绳 polypropylene filler yarn
石油膏填充 petrojelly filling
石蜡油填充聚乙烯绝缘电缆 petrolatum-filled polyethylene-insulated cable
石油膏填充物、石油膏填充器 petroleum jelly cable filler
石油膏填充 petroleum jelly filling
非导电填充物 non-conductive filler
矿物填充交联聚乙烯 mineral filled crosslinked polyethylene
填充物、填料 loading material
膏状物填充松管光纤 loose tube optical fiber filled with jelly
石油膏填充塑料电缆 jelly filled plastic cable
石油膏填充设备 jelly-filling equipment
麻填料、填充麻 jute filler
内填充(料) inner filler
内填充(护套)料[混合物] inner filling compound
内填充护套 inner filling sheath
无填充料 inorganic filler
填充包套联合生产线 integrated filling and sheathing line
填充四线组、间充四线组 interstitial quad
高填充胶料 highly-extended compound
润滑脂填充线芯 grease-filled core
全[连续]填充电缆、纵向密封电缆 fully filled cable
光缆填充机 fiber optic cable filling machine
填充系数 fill factor
填充系数、占体率 fill in ratio
填充线芯导线 fill-core conductor
填充系数、占体率 fill-in ratio
填充电缆 filled cable
填充用户电缆 filled service cable
填充[封]物、填料、填芯 filler
填充剂 filler compound
非填充电缆、无填充电缆 fillerless cable
填充、充填、填料 filling
填充复合物、填料、填充剂、填充混合物、浇注料、浇注剂 filling compound
填充机 filling machine
填充材料 filling material
填充温度、浇注温度 filling temperature
挤包内护层、内填充护套 extruded inner covering
环氧填充密封端 epoxy filled sealing end
连续[全]填充电缆、纵向密封电缆 continuously filled cable
色标聚乙烯石油膏填充电话电缆 color coded polyethylene jelly filled cable
石油膏填充粘结护套联合设备 combined petro-jelly filling and bonded sheath equipment
填充率 compaction ratev
装料、填充、充电、电荷 charge
电缆填充剂 cable-filling compound
电缆填充设备 cable-filling plant
中心填充物 center filler
中心填充物、填芯 centre filler
电缆填充、电缆占用率、电缆填充率、电缆线对利用率 cable fill
电缆填充 cable filling
电缆填充装置 cable filling applicator
电缆填充设备 cable filling equipment
电缆填充机 cable filling machine
电缆填充麻 cable filling yarn
电缆填充用油膏、电缆填充油膏 cable jelly
填充、填料、锁紧装置 blocking
色标聚乙烯石油膏填充 CCP-JF(color code polyethylene-jelly filled)
扁平编织线 flat braid
编织 braiding
浇铸〔流延〕 casting
涂敷 coating
包封 encapsulating
耐磨性 Abrasion Resistance
电缆放线车 wheel cable drum carriage
放线车 wire barrow
放线转台[转盘] wire pay-off turntable
放线车 wire-barrow
立式越端放线架 vertical flyer pay-off frame
垂直升降式收、放线装置 vertical lift pay-off and take-up
轨道滑动式放线装置 walk-through pay-off
放线、解绕、退绕 unreeling
退扭放线装置 untwisting pay-off system
退绕[放线]装置 unwinding device
移动式龙门收、放线架 travelling drum take-up and pay-off stand in port
移动式龙门收、放线架 travelling drum take-up and pay-off stand in portal execution
行走式放线装置 travelling pay-off
行走式放线架 travelling pay-off stand
双头立式放线架 twin headed swift
放线(装置) take-off
放线架[装置] take-off stand
收放线(装置) take-up and pay-off
供方、承制厂、放线装置、交货方、制造厂 supplier
放线盘 supply bobbin
放线牵引轮 supply capstan
放线架 supply frame
放线盘 supply reel
放线架[装置] supply stand
收放线装置 spooler-unspooler
固定放线装置 stationary pay-off
固定式放线架 stationary pay-off stand
固定式收放线架 stationary take-up and pay-off stand
成捆或成筒放线装置 stempack or drumpack pay-off system
圈式放线装置、捆式放线装置 stempack pay-off
越端放线的刚性架绞线机 spin-off rigid-frame strander
无轴式恒定张力放线装置 shaft type constant tension pay-off
无轴式恒定张力放线装置 shaftless constant tension pay-off
无轴式放线设备 shaftless pay-off equipment
无轴式放线系统 shaftless pay-off system
单头立式放线架 single headed swift
单盘放线装置 single reel pay-off
转盘式放线装置 ring flyer
旋转放线装置 rotary pay-off
锥形旋转放线架 rotating cone
旋转放线装置 rotating pay-off
放线装置 re-reeler
门式放线架[装置] portal type pay-off
门式放线架 portal-type pay-off stand
放线(装置) pay off
放线装置 pay-ins
放线储线器、放线储存器 pay-off accumulator
组合放线装置 pay-off and bank
收、放线装置 pay-off and take-up
收、放线设备 pay-off and take-up equipment
组合放线装置 pay-off bank
放线盘 pay-off drum
放线架、放线框 pay-off frame
放线导轮架 pay-off guid sheave stand
放线机 pay-off machine
放线平衡器 pay-off neutralizer
放线架 pay-off rack
放线盘 pay-off reel
放线速度 pay-off speed
放线盘 pay-off spool
放线架[装置] pay-off stand
放线架 pay-off swift
放线装置 pay-off unit
放线速度 pay-off velocity
放线架 pay-off-rack
放线角 pay-out angle
放线架 pay-out stand
放线装置 pay-out unit
放线 payed off
放线盘 paying out drum
放线盘 paying out reel
放线盘架 payoff bobbin retainer
放线张力 payoff tension
越端放线(装置) over-end pay-off
越端放线装置 over-end pay-off unit
越端放线、轴向放线 over-flange pay-off
越端放线拉线 over-head take-off drawing
越端放线装置 overend dereeler
越端[轴向]放线装置 overhead pay-off
越端式放线架 overhead pay-off-rack
越端牵引、越端放线 overhead-pull-off
电动放线装置 motor-driven pay-off
机动放线架 motor-driven wire pay-off swift
主动放线装置、电动放线装置 motorised pay-off
多盘放线装置 multi-bobbin pay-off
无驱动放线 non-drive pay off
移动式放线装置 mobile pay-off
行走式放线架 mobile pay-off stand
手动螺杆升降式放线装置 manual screw lift pay-off
放线装置 let-off apparatus
放线篮架 input core drum carrier
放线盘、进线线盘、生产用线盘、机用线盘 input reel
重型无轴式放线装置 heavy duty shaftless pay-off
越端放线装置 flyer dereeler
浮转式放线装置 flyer pay-off
越端放线装置 flyer re-reeler
飞环[越端]式放线装置 flyoff hood arrangement
放线架[装置] feed stand
拉线鼓轮、(电缆敷设用)放线盘 drawing drum
被动式放线装置 driven supply arrangement
筒式放线装置 drumpack pay-off
双盘越端放线(装置) dual flyer pay-off
双盘越端放线(装置) dual flyer type pay-off
双盘放线装置 dual pay-off
双盘放线装置 dual pay-off unit
放线浮拉器 de-reeling flyer
越端放线架 de-reeling flyer frame
圈线绕机、圈线放线架 decoiler
放线装置 dereeler
放线 despooling
放线装置 despooling unit
退绕器、放线器 dewinder
绕线轴架、多轴放线架 creel
放线架 creel stand
毛刷式放线装置 curl flyer
恒定张力放线架 constant tension lef-off stand
中心放线盘 core pay-off reel
锥形、锥、锥体、拉线鼓轮、(收、放线架的)托脚 cone
锥形越端放线装置 cone-type flyer pay-off
成圈复绕装置、收放线装置 coiling and uncoiling device
悬臂式收、放线装置 cantilever pay-off and take-up
中心股放线架 center core pay-off stand
中心放线站 central pay-off station
电缆放线车 cable drum carriage
线盘放线架 bobbin pay-off creel
线盘放线速度 bobbin payout speed
自动放线装置 automatic dereeler
退扭放线 back twist pay-off
盘转式放线装置 barrel-type pay off
毛刷式放线装置 curl flyer
越端放线装置的摩擦片 abrasive plate
绕线、收线、绕包 wind
绕线、收线 wind up
收线器[机]绕线机 wire spooler
收线装置 wire take-up device
绕线机、收线机 wire winding machine
立式静盘成圈收线装置 vertical axis stalabloc coiler
立式升降收线(装置) vertical lift take-up
立式螺旋升降收线架 vertical screw lift take-up stand
立式静盘成圈收线装置 vertical stationary block coiler
行走式收线架 transportable take-up stand
自排式收线(装置) traversing take-up
双盘收线架 twin drum take-up stand
双盘收线装置 twin spooler
顶尖式收线器、无轴式收线装置 tailstock spooler
绕线、收线 take up
收线架 take-off rack
绕线、收线、收线(装置) take-up
收线储存器、收线储线器 take-up accumulator
收线绕线装置 take-up and winding unit
组合收线装置 take-up bank
收线装置 take-up block
收线牵引轮 take-up capstan
收线成圈机 take-up coiler
收线盘 take-up drum
收线盘撑架 take-up drum cantilever
收线篮架 take-up drum carrier
收线架、收线框 take-up drum frame
盘式收线架、收线盘架 take-up drum stand
收线架 take-up frame
收线电机 take-up motor
收线盘 take-up reel
收线速度 take-up speed
收线盘 take-up spool
成盘收线装置 take-up spooler
收线架[装置] take-up stand
收线绞线机 take-up strander
收线张力 take-up tension
收线架[装置]、收线装置 take-up unit
悬挂式收线架 susceptance take-up station
绕线、收线 spool
自动收线装置 spooling
收线设备、收线、绕线 spooling equipment
收线装置 spooling machine
收线架 spooling stand
局部退火、收线机 spot annealing
氨基甲酸酯橡胶 urethane rubber
直焊性聚氨脂漆包铜圆线 solderable polyurethane enamelled round copper wire
直焊性聚氨酯漆包铜圆线 self-fluxing polyurethane enammelled round copper wire
聚氨酯漆包线 polyurethane enamelled wire
聚氨酯泡沫橡胶 polyurethane foam
聚氨酯漆包圆铜电磁线 polyurethane-coated round copper magnet wire
聚氨酯-尼龙丝包圆铜电磁线 polyurethane-nylon-coated round copper magnet wire [化]阿摩尼亚、氨 ammonia
聚氨酯 PUR(polyurethane)
布置、安装 set out
安装、装配、布置、设置 set up
安装、装配、布置、设置 set-up
安装、排字、布景 setting
安排、解决 settle
安排、准备、配置 setup
安息日的 sabbatical .
安全的、平安的 safe adv
安全地、平安地 safely
安全、可靠 safety n
安全设备、保险装置 safety
安全[防护]装置 safety device
可靠性、安全性 reliability
运行[操作]可靠性、运行[操作]安全性 reliability of operation
烦燥不安的 perturbed
安全[保险、紧急]开关 overcurrent cut-out switch
运行[操作]可靠性、运行[操作]安全性 operating reliability
运行[操作]可靠性、运行[操作]安全性 operating safety
就职、安装、装置 installation
安装电缆 installation cable
安装费用、设备投资 installation cost
安装图、施工图 installation drawing
安装说明书 installation instructions
安装[装置]工具 installation kit
安装程序 installation program
安装规程[标准] installation rule
安装标准[规程] installation standard
无线电装置用电线、安装线、装备用电线 installation wires
敷设[安装]工程、敷设[安装]工作 installation work
安装容量、安装功率 installed capacity
安装功率 installed power
安装线 interconnection wire
自身安全装置 intrinsically safe installation
岛、安全地带 island
使安全、偿付 indemnify
高安全性电缆 high-safety electric cable
高温安装线 high-temperature hook-up wire
适合 fit
安装工、装配工 fitter
安装说明 fitting instruction
安装说明书 fitting instructions
安装、修理、确定 fix
治愈(病人)、安顿 fix up
固定、安装、附件、接头 fixing
固定安装线 fixture wire
带状(室内布)线、扁形编织安装线 flat webbed building wire
安全系数、安全[保险]系数 factor of assurance
电气安装 electric installation
安装线 equipment and building wire
设备安装线 equipment hook-up wire
安慰、取悦于 conciliate
管道安装线 conduit-installation wire
(做)预算、安排 budget
电缆安装、电缆敷设、电缆装置[设备] cable installation
电缆敷设[安装] cable laying
电缆及设备安装程序 PACE(program for arrangement of cables and equipment)
千伏安 KvA(Kilovolt-ampere)
用浮筒把电缆拉上海岸 to float a cable ashore
浅海电缆、岸边电缆 shallow water cable
浅海电缆、岸边电缆 shallow-water cable
三聚氰胺石棉塑料 asbestos filled melamine plastics
磺胺类药物 sulfa
磺胺类药 sulfa drug
直焊性聚酰亚胺漆包铜圆线 solderable polyesterimide enamelled round copper wire
聚酰胺 polyamide
聚酰胺漆包线 polyamide enamelled wire
聚酰胺-(酰)亚胺 polyamide-imide
聚酰胺-(酰)亚胺漆包铜圆线 polyamide-imide enamelled round copper wire
聚酰胺-酰亚胺漆包线 polyamide-imide enamelled wire
聚酰胺-酰亚胺浸渍漆 polyamide-imide impregnating varnish
聚酰胺纤维 polyanide fiber
聚酰亚胺 polyesterimide
聚酰亚胺漆包铜扁线 polyesterimide enamelled rectangular copper wire
聚酰亚胺漆包铝圆线 polyesterimide enamelled round aluminium wire
聚酰亚胺/聚酰胺复合漆包铝圆线 polyesterimide enamelled round aluminium wire overcoated with polyamide
聚酰亚胺漆包铜圆线 polyesterimide enamelled round copper wire
聚酰亚胺/聚酰胺复合漆包铜圆线 polyesterimide enamelled round copper wire overcoated with polyamide
聚酰亚胺漆包线 polyesterimide enamelled wire
聚酰亚胺/聚酰胺复合漆包铝圆线 polyesterimide overcoated with polyamide-imide enamelled round aluminium wire
聚酰亚胺/聚酰胺复合漆包铜圆线 polyesterimide overcoated with polyamide-imide enamelled round coper wire
聚酰亚胺涂层光纤 polyimide coated optical fiber
聚酰亚胺漆包铜扁线 polyimide enamelled rectangular copper wire
聚酰亚胺漆包铜圆线 polyimide enamelled round copper wire
聚酰亚胺漆包线 polyimide enamelled wire
聚酰亚胺薄膜 polyimide film
尼龙、酰胺纤维 nylon
金属包层芳族聚酰胺纤维 metal-clad aramid fiber
环已酰亚胺 cycloheximide
抗组织胺 antihistamine
聚酰胺 PA(polyamide)
聚酰亚胺 PI(polyimide)
二基乙酰胺 DMA(dimethyl acetamide)
地表凹陷、地面下沉 subsidence of ground
凹口试杆冲击试验 notched bar impact test
有凹槽的 fluted
凹陷半径 dip radius
凹状梯度折射率光纤、凹形渐变折射率光纤 dipped graded-index fiber
牙、槽、凹陷 dent
凹陷型包复 depressed clad
深凹陷内包层光纤 depressed cladding fiber
凹陷深度 depth of pip
粉末涂敷 powder coating
流化床涂敷 fluidized bed coating
十八盘两段卧式绞线成缆机 18-bobbin 2-cage horizontal wire stranding and laying-up machine
十八盘绞笼 18- bobbin bay
扭绞八芯电缆、对绞四线组电缆、双四线组电缆 quad pair cable
八芯光纤连接器 eight-ways optical fiber connector
摆杆式拉线机 dancer arm drawing machine
摆杆 dancer rocker arm
并列摆动分线板 coordinated oscillating face plate
柱式荡轮、柱式荡轮式储线器、舞摆[动盘]式储线器 column-type dancer accumulator
在...支配或摆布下 at the mercy of
半导电膨胀阻水层 semi-conducting moisture swelling layer
半导体釉 semmiconducting glaze
半导电漆 semiconductive varnish
半年、学期、半学年 semester
半空气绝缘电缆 semi-air space cable
半退火铝导体 semi-annealed aluminium conductor
半自动电缆绝缘剥除机 semi-automatic cable de-insulating machine
半自动电缆测量装置 semi-automatic cable measuring system
半自动收线装置 semi-automatic take-up
半自动双盘收线装置 semi-automatic twin take-up
半导电的、半导体的 semi-conducting
半导体丁基橡胶带 semi-conducting butyl tape
半导体混合物 semi-conducting compound
半导体护套 semi-conducting jacket
半导电层、半导体层 semi-conducting layer
半导体尼龙 semi-conducting nylon tape
半导体橡胶 semi-conducting rubber
半导体屏蔽 semi-conducting screen
半导体带 semi-conducting tape
半导体漆 semi-conducting varnish
半导电的、半导体的 semi-conductive
半导体混合物 semi-conductive compound
半导电线芯 semi-conductive core
半导体层、半电导电层 semi-conductive layer
半导体屏蔽、半导电屏蔽 semi-conductive screen
半导体 semi-conductor
半导体层、半电导电层 semi-conductor layer
半连续铸锭机 semi-continuous casting machine
半连续铸锭 semi-continuous ingot casting
半硫化 semi-cure
半成品 semi-cylindrical conductor
半圆形导体 semi-finished product
半硬铝线 semi-rigid aluminium wire
半硬同轴电缆 semi-rigid coaxial cable
半塞止式接头盒 semi-stop joint
半切线式纸包头[绕包头] semi-tangential lapper
半切线式纸包头[绕包头] semi-tangential lapping head
半圆、半圆形体 semicircle
半圆形导体 semicircular conductor
半导体 semicon
半导电绝缘屏蔽 semicon-insulation
半导体交联聚乙烯 semiconducting crosslinked polyethylene
半导体材料 semiconducting material
半导体纸、半导电纸 semiconducting paper
半导电层、半导体层 semiconductive layer
半导体纸、半导电纸 semiconductive paper
半导体 semiconductor
半导体材料 semiconductor material
半硬铝线 semihard-drawn aluminium .
半盲的、愚笨的 purblind
半[准]导体 semi(quasi)-conductor
半径损耗 radii loss
辐射光线、半径范围 radius
中间[半成品]线材、非银亮线材 process wire
外部曲率半径 outer curvature radius
外半导电层 outer semi-conducting layer
纤芯半径失配损耗 mismatch-off-core-radii loss
电缆转弯的曲率半径与电缆平均直径、节径比、节距比 lay ratio
内半径电层 inner semi-conducting layer
中间[半成品、过程]线材 intermediate wire
半双工 half duplex
半扭绞结构 half twist structure
半硬铝线 half-hard aluminium wire
半硬铜线 half-hard copper wire
动物)半冬眠 half-hibernate
半圆黄铜带 half-round brass strip
半波导线 half-wave conductor
半球、范围 hemisphere
(扇形线芯的)弯曲半径、棱角半径 edge radius
二分法、两半 dichotomy
临界半径 critical radius
线芯半径 core radius
扇形线芯的)棱角半径、弯边半径 corner radius
弯曲半径 bending radius
允许弯曲半径 allowable bending radius
铜芯或铝芯半导体屏蔽聚乙烯绝缘聚氯乙烯护套电缆 Lyonithene cable
金属氧化物半导体 MOS(metal-oxide semiconductor)
最小弯曲半径 Min.bending radius
作用半径 R/A(radius of action)
电平(全)带宽、半最大值处(全)带宽 FWHM(full width at half maximum)
无纬绑扎带 unidrectional binding tape
紧绑 swathe
绑结、绑扎、扎结 stiching
圈线压紧绑扎机 rod coil compacting-tying machine
捆、扎、绑、连接 lace
场控金属线绑扎 field-controlling wire binding
场控金属线绑扎 filed-controlling wire binding
电缆绑结 cable stitching
捆绑、包扎、装钉 bind
绑扎 binder tape
捆绑(物) binding
绑轧绳、捆绑绳 binding yarn
包装 packaging
包封 encapsulating
灌注 potting
密度 Density
十六锭高速编织机 16-carrier high-speed braiding machine
双面双层十六头纱包机 16-head double-side douoble-rosette cotton covering machine)
漆包 enamelling
立式四头包带机 4-head vertical tape lapping machine
盘纸包机 412-sheet paper lapping machine
绕包带 taping
金属焊丝惰性气体保护焊 MIG(Metal-Inert Gas) welding
聚酯漆包线漆 polyester wire enamel
包封胶 埋封胶 encapsulating compound embadding compound
漆包线漆 wire enamel
成圈机)包扎机 wire coil wrapping machine
线(材)绕包 wire covering
线材绕包机 wire covering machine
漆包线漆 wire enamel
单纱包线 wire insulated with single cotton yarn sewings
材线包装 wire packaging
铅包钢丝铠装、铅(护)套加钢丝铠装 wire-reinforced lead sheath
披肩 wrap
绕包屏蔽 wrapped screen
绕包机 wrapper
包装材料 wrapping
绕包方向 wrapping direction
绕包机 wrapping machine
钢带绕包 wrapping of steel tape
绕包车间 wrapping workshop
纱包头 yarn covering head
纱包机 yarn wrapping machine
纱包头 yarn-spinning head
立式笼型包带机、立式笼型绕[纸]包机 vertical cage lapper
立式笼型包带机、立式笼型绕[纸]包机 vertical cage type lapping machine
立式漆包炉 vertical enamelling oven
立式绕[纸]包机、立式包带机 vertical lapping machine
立式包带机 vertical taping machine
涂蜡纱包线 waxed cotton covered wire
无包层光纤 unclad fiber
通用绕包机 universal wrapping machine
无包套光纤 unjacked optical fiber
无磁性漆包铜圆线 unmagnetic enamelled round copper wire
深漆玻璃丝包铜线 varnish-bonded glass-lapped copper conductor
浸漆玻璃丝包铜扁线 varnish-treated glass-fibre covered rectangular copper wire
漆包线 varnished wire
三包层光纤 triple clad fiber
三层纱包的 triple cotton-covered
十二头三层绕包机 triple covering machine with 12 individual heads
三层环氧漆包圆铜电磁线 triple epoxy-coated round copper magnet wire
三股编包线 triple-braided
三层丝包线 triplex silk covered wire
三层绕包线 triply covered wire
三涂层[三包层]光纤 triply-coated fiber
挤包绝缘或护套 tubing
浇包、铸包、浇铸桶 tundish
挤包实体绝缘三芯电缆 three-core cable with extruded solid insulation
分相铅套[铅包]电缆 three-core single lead sheath cable
紧包光纤、紧套光纤 tight (coated) fiber
紧包缓冲套 tight buffer jacket
紧包保护光纤 tight protected fiber
紧包结构<光缆的> tight structure
紧包光纤 tightly packaged fiber
紧包的 tightly wrapped
紧包光纤 tightly-buffered fiber
镀锡铜包钢线 tin-caoted copper-clad steel wire
镀锡、包锡、挂锡 tin-coat
镀[挂、包]锡 tin-coating
镀[挂、包]锡 tinning
螺旋式绕包 to apply helically
螺旋式绕包 to apply spirally
挤压[挤包]铅护套、压铅 to apply the lead sheath
用纸绳绕包 to apply the paper string
用纸绳绕包 to spin the paper string
拉线漆包机组 tandem wire drawing and enamelling line
切线式绕[纸]包机 tangential lapper
切线式纸包头[包带头] tangential lapping head
切线式绕包机 tangential paper lapping machine
切线式绕包机 tangential type lapping machine
带、条 tape
带(状)绝缘、绕包绝缘 tape insulation
包带头、包带机 tape lapper
包带头 tape lapping head
包带机 tape lapping machine
包带式 tape type
带包绝缘导体 tape wrapped conductor
带包式电容锥 tape-wrapped type condenser cone
绕包层 taped covering
内绕包层 taped inner covering
带(状)绝缘、绕包绝缘 taped insulation
绕包型接头 taped joint
绕包式电缆终端头、绕包终端 taped termination
带绕包、包带 taped wrapping
包带机、包带头 tapelapper
带绕包、带包、包带、绕包 taping
包带头、带包头 taping head
包带机 taping machine
包带点 taping point
包带装置 taping unit
包带节距 tapping pitch
包带速度 tapping speed
电话线芯[话缆]包带机 telephone core taping machine
丝包束合漆包铜线 textile -covered bunched enamelled copper wire
绳绕包 string spinning
绳绕包机、绕绳机 string spinning machine
包含、包摄 subsume
合成漆包线 synthetic enamel wire
钢带绕包头 steel tape spinner
钢带绕包头 steel taping head
绞线纸包联合机 stranding and paper lapping machine
绞合回转弓(绕包头) stranding flyer
溶剂粘接直焊性漆包线 solvent bonding self-fluxing enamelled wire
绳、纱、丝、麻)绕包头 spining head
带包头、包带头、绕包头 spinner
纸带(绕包)绝缘 spiral strip paper insulation
螺旋形绕包 spiral wrap
螺旋式绕包机 spiral wrapping machine
插入鞘、包、覆 sheathe
有外护套层的卷边纵包金属护套布线电缆 sheathed metal-clad wiring cable
挤[包]护套、护套 sheathing
护套挤包设备 sheathing equipment
屏蔽(层)、包屏蔽 shielding
屏蔽包制机 shielding machine
包围、围攻 siege
石英包层光纤 silica cladded fiber
有机硅漆包线 silicon enamelled wire
硅酮包层光纤 silicone-clad silica fiber
纱(编)丝包线 silk and cotton covered wire
丝包机 silk covering machine
丝包机 silk wrapping machine
丝包机 silk yarn covered wire
丝包铜线 silk-covered copper conductor
丝包圆铜电磁线 silk-covered round copper magnet wire
丝包线 silk-covered wire
镀银铜包钢线 silver-coated copper-clad steel wire
镀银铜包钢(导)线 silver-plated copperweld conductor
挤包实体绝缘单芯电缆 single cable with extruded solid insulation
单纱包的 single cotton covered
单纱包漆包线 single cotton covered enamel wire
单纱包线 single cotton covered wire
单纱双丝包(的) single cotton double silk covered
单玻璃丝包漆包圆线 single glass-fiber covered enamelled round wire
单头单位式纸包机 single head unit type paper insulating machine
单丝包线 single silk covered wire
单丝包漆包线 single silk enamel covered wire
单包层光纤 single-coated fiber
单纱包机 single-cotton covering machine
单(层)纱包漆包线 single-cotton enamel
单丝包的 single-silk covered
单丝包机 single-silk covering machine
单丝漆包 single-silk enamel
书包 schoolbag
密封绕包 sealing wrap
金属护套的无缝挤包、无缝护包金属护套 seamless extrusion of metal sheaths
自粘直焊漆包线 self-bonding and self-fluxing enamelled wire
自粘直焊漆包线 self-bonding solderable enamelled wire
自粘直焊漆包线 self-fluxing and self-bonded enamelled wire
直焊性漆包铜圆线 self-fluxing enamelled round copper wire
直焊性漆包线 self-fluxing enamelled wire
绕包头、旋转式浮拉器 rotating flier
橡皮绝缘编包线 rubber-covered braided
橡皮绝缘编包风雨线 rubber-covered braided\weather-proof
三明治(夹心面包片) sandwich
多层绕包的(电缆)外护层 sandwich covering
线盘包装机 reel packing machine
误差率、误码率、(漆包线的)针孔数 reeor rate
加固带绕包头 reinforcement tape spinner
钱包、小钱袋、手袋 purse
四层聚酯漆包扁铜电磁线 quadruple polyester-coated rectangular copper magnet wire
人造丝包铜线 rayon-covered copper conductor
浇包、铸勺、浇铸桶 pouring ladle
浇包、铸勺、浇铸桶 pouring-ladle
挤包绝缘电力电缆 power cable with extruded insulation
漆包线漆膜针孔 pinhole of insulation of enamelled wire
油性漆包线漆 plain enamel
平面式绕包头[纸包头] plane lapping head
平面式绕包机 plane type lapping machine
塑料薄膜包线 plastic film covered wire
塑料包覆光纤、塑料包层光纤 plastic-clad fiber
聚酯漆包铜扁线 polyester enamelled rectangular copper wire
聚酯漆包线 polyester enamelled wire
聚酯漆包扁铜电磁线 polyester-coated rectangular copper magnet wire
聚酯漆包圆铜电磁线 polyester-coated round copper magnet wire
聚酯漆包矩形铜电磁线 polyester-coated square copper magnet wire
聚酯玻璃丝包扁铜电磁线 polyester-glass-fiber-covered rectangular copper magnet wire
聚酯玻璃丝包圆铜电磁线 polyester-glass-fiber-covered round copper magnet wire
聚酯玻璃丝包矩形铜电磁线 polyester-glass-fiber-covered square copper magnet wire
字形绕包聚乙烯护套 polyethylene sheath of figure-8 formation
聚合物包层光纤 polymer-clad fiber
聚硅氧烷包层光纤 polysiloxane cladding fiber
聚砜及聚缩醛漆包线 polysulfone and polyacetal-coated wire
缩醛漆包铜扁线 polyvinyl acetal enamelled rectangular copper wire
缩醛漆包铝圆线 polyvinyl acetal enamelled round aluminium wire
缩醛漆包铜圆线 polyvinyl acetal enamelled round copper wire
缩醛漆包线 polyvinyl formal enamelled wire
高强度缩醛漆包铜圆线 polyvinyl-formal enamelled round copper wire with high mechanical properties
缩醛漆包线 polyvinylacetal enamelled wire
包装 packaging
包装等级 packaging level
包装机 packaging machine
包装用线盘 packaging reel
包装标准 packaging standard
包装箱 packing-case
纸包机 papare covering machine
纸包扁铜绕组线 paper covered rectangular copper winding wire)
纸包扁线 paper covered rectangular wire
纸包圆线 paper covered round wire
纸包头 paper covering head
纸包机 paper covering machine
纸包头 paper lapper
纸(带绕)包 paper lapping
纸包纱包联合机 paper lapping and cotton covering machine
纸包头 paper lapping head
纸包机 paper lapping machine
纸包工序 paper lapping operation
纸带(绕包)绝缘 paper ribbon insulation
纸带(绕包)绝缘 paper tape insulating
纸包 paper taping
纸包机 paper taping machine
纸包头 paper wrapping head
纸铝箔纵包机 paper-aluminium-foil applicator
漆包纸绝缘电缆[电磁线] paper-core enamelled type cable
纸包铜线 paper-covered copper conductor
纸包扁铜电磁线 paper-covered rectangular copper magnet wire
纸包圆铜电磁线 paper-covered round copper magnet wire
纸包矩形铜电磁线 paper-covered square copper magnet wire
纸包线 paper-covered wire
纸绝缘铅包的 paper-insulated lead covered
纸包头 papper lapper
无磁性漆包线 non-magnetic enamelled wire
非组合包套 nonintegral jacket
漆包层数 number of enamel coats
缺陷数、(漆包线)、针孔数 number of faults
尼龙丝包圆铜电磁线 nylon-fiber-covered round copper magnet wire
油基漆、油性漆包线漆 oil-base enamel
油性漆包线 oleo resinous enamelled wire
油性漆包线 oleo-resin enamelled wire
油树脂漆、油性漆包线漆 oleoresinous enamel
油树脂漆、油性漆包线漆 oleoresinous varnish
疏绕、间隙绕包 open lapping
正反向绕包、正反向绞合 opposite-direction lapping
松包光纤光缆 optical fiber cable with fibers loosely packaged
紧包光纤光缆 optical fiber cable with fibers tightly packaged
挤包实体绝缘多芯电缆 multicore cable for extruded solid insulation
多头同心包带机 multiple head concentric taping machine
(漆包机的)导轮组 multiple sheave
镍包铜线、镀镍铜线 nickel coated copper conductor
镀镍铜线、镍包铜线 nickel-clad copper wire
镀镍铜线、镍包铜线 nickel-coated copper wire
镀镍铜包钢线 nickel-coated copper-clad steel wire 包层不圆度 non-circularity of cladding
用金属包 metal
金属包覆导体 metal clad conductor
金属包覆层 metal cover layer
金属包层 metal covering
金属包覆电缆 metal-clad cable
金属包覆导体 metal-clad conductor
卷边纵包金属护套布线电缆 metal-clad wiring cable
金属包带 metallic cover tape
改性聚酯漆包铜圆线 modified polyester enamelled round copper wire
低损耗 FEP
包层石英光纤 low loss FEP-clad silica fiber
行李、皮箱、皮包 luggage
电磁线、漆包线 magnet wire
匹配包层光纤 matched cladding fiber
月牙板式钢带绕包头 link-type tape wrapping head
单层纸 simplex paper
单层的 single-layer
单层 monolayer
钢带铠装电缆 tape armoured cable
钢带铠装 steel tape armour
钢带铠装电缆 steel tape armoured cable
钢带铠装 steel tape armouring
钢带铠装机 steel tape armouring machine
钢带铠装电缆 steel-tape armoured cable
铅包钢带铠装、铅套加钢铠装 l.s.s.t.(lead-sheath,steel-taped)
铅包钢带铠装、铅套加钢带铠装 lead-sheath,steel-taped
内钢带铠装电缆 internal steel-tape armoured cable
双钢带铠装 double tape armour
双层钢带铠装 double layer of steel-tape armour(d.s.t.a.)
涂层钢带铠装电缆 coated steel tape armoured
钢带铠装电缆 band-armoured cable
plastic coated metallic tape - 涂塑金属带 (0) 投诉
P:2007-01-21 15:15:54
镀锌 zinc plating
镀锌槽 zinc plating bath
镀锌铁丝 zinc-coated iron wire
铠装用镀锌低碳钢丝 zinc-coated low-carbon steel armour
镀锌钢绞线 zinc-coated steel strand
镀锌钢带 zinc-plated steel tape
镀锌 zinking
高强度镀锌钢丝[芯线] high-strength galvanized steel core
高强度镀锌钢丝[芯线] high-strength zinc-coated steel core
电镀、镀锌 galvanizationvt
电镀、镀锌 galvanize
电镀的、镀锌的 galvanized
镀锌铠装钢丝 galvanized armour wire
铅淬火高张力镀锌钢丝 galvanized high-tensile plough-steel wire
镀锌铠装钢带 galvanized steel armour tape
镀锌钢芯线、镀锌钢丝 galvanized steel core wire
镀锌钢丝 galvanized steel wire
镀锌钢绞线 galvanized stranded wire
镀锌钢丝 galvanized wire
镀锌槽、锌浴 galvanizing bath
镀锌炉 galvanizing furnace
镀锌装置、电镀装置 galvanizing plant
镀锌收线架 galvanizing take-up frame
电镀的、镀锌的 galvanic
防腐镀锌钢丝 corrosion preventing grease-coated galvanized wire
高速管绞机 high speed tubular stranding machine10
对群绞设备10- twin group stranding machine
十三头绞线机13- fold twisting machine
十八盘绞笼18- bobbin bay
压铝护套 Extruded Aluminium Sheath
钢芯铝绞线 ACSR
钢芯铝绞线 ACSR cable4
对群绞设备4- twin group stranding plant
绞盘、绞车 winch
钢丝绳、钢缆、钢绞线 wire rope
绞线机 wire-stranding machine
绕接、缠绕接线法、导体的扭绞连接 wire-wrap connection
钢丝绳、钢缆、钢绞线 wirerope
带退扭的(绞线) with backtwist
不带退扭的(绞线) without backtwist
绞笼架 yoke
立式绞线机 vertical twister
绞合电缆 twsit cable
绞合补偿器、节距调节器 twsit compensator
分层绞线 twsit conductor
绞合对、多股绞合线 twsit pair
扭绞节距、绞距 twsit pitch
复星绞组 twsit quadruplet
扭绞试样成型机 twsit test specimen forming machine
绞合线 twsit wire
同向绞合 unidirectional lay
同节距绞合 unilay stranding
单位式(绞合)电缆 unit cable
单位式绞合 unit lay-up
单位屏蔽对绞电缆 unit shielded paired cable
单位式绞合 unit stranding
单位式绞缆机 unit stranding machine
单位绞电缆 unit twin cable
单位式(绞合)电缆 unit-stranded cable
单位绞 unit-stranding
单位式(绞合)电缆 unit-type stranded cable
三层同心绞合电缆、三相同轴电缆 triple concentric cable
筒式绞线机 tubolarbloc
管(筒)笼式绞线机 tubolarbloc cage strander
预加压管式绞线机 tubular strander with prestressing
防噪音管式绞线机 tubular strander with sound-proof guards
管(式)绞(合) tubular stranding
双绞和四线组对绞电缆 twin and quad pairing cable
双芯电缆、对绞电缆 twin cable
三层共挤 triple extrusion
双金属挤压、多层一次挤出、共挤出(法) co-extrusion
共挤十字机头 coextrusion crosshead
三层共挤 boned triple extrusion
直埋 dirdect burial
校直 straighten
辊式矫直机 straighteners
矫直 straighening
直径 diameter
成品电缆的标称直径 BASFOD
线材矫直器 wire straightener
线材矫直切割机 wire straightening and cutting machine
垂直安装[排列] vertical arrangement
立式垂直浇铸 vertical cast
立式垂直浇铸 vertical casting
耐垂直蠕变性 vertical creep resistance
垂直燃烧试验 vertical flame test
垂直敷设 vertical installation
垂直升降式电缆盘架 vertical lift type drum stand
垂直偏振 vertical polarization
直升装置用电缆 vertical riser cable
垂直敷设 vertical run
垂直悬挂试验 vertical suspension test
垂直托架火焰[燃烧]试验 vertical-tray flame test
垂直偏振电磁波 vertically-polarized electromagnetic wave
地下电缆、直埋电缆 underground cable
直径缩小、缩径 thinning
直通线路 through circuit
直通线路 through line
直接通信 through-traffic
定线、与….成一直线 to be flush
定线、与……成一直线 to be in line with
将金属线拉制成大、中、小直径 to draw wires down to large,medium,small diameters
串列式轧机、直线式轧机 tandem rolling mill
拉伸、矫直 stretching
直裂缝、裂缝[纹、口]、拼合的、分开的 split
直线式储线器 straight accumulator
直接浸渍法 straight dipping process
平直侧板 straight flange
直通接头 straight joint
直链聚乙烯、线性聚乙烯 straight-chain PE
直链聚合物 straight-chain polymer
直线式储线器 straight-line accumulator
直线式拉线 straight-line drawing
直线式拉线机 straight-line drawing machine
直线式拉线机 straight-line wire drawing machine
直通插头 straight-plug
直[平]辊式拉线机 straight-roll wire drawing machine
直通接头[连接器] straight-through connector
直线式拉线 straight-through drawing
直线式拉线机 straight-through drawing machine
直通接头 straight-through joint
直通式压铅机 straight-through lead press
直通式压铅机 straight-through press for lead-sheathing cables
拉直、(线材)矫直 straighten
矫直的电缆试样 straightened cable sample
矫直机[装置]、矫直器、校直机 straightener
矫直、校直 straightening
矫直机 straightening machine
矫直辊 straightening roll
拉直、拉伸、拉紧 stretch
拉伸机、矫直机 stretcher
小(直径)同轴对 small-diameter coaxial pair
直焊性电磁线 solderable magnet wire
中线直接接地 solid earthing of neutral
中线直接接地 solid grounding of neutral
直接接地中线 solidly earthed neutral
直接接地网络[系统] solidly earthed system
直接接地中线 solidly grounded neutral
直接接地网络[系统] solidly grounded system
螺杆长度 nD(D:
直径) screw length nD
自焊性、直焊性 self-solderability
直角连接器 right-angle adapter
直角接头 right-angle connector
直角插头 right-angle plug
基准面直径 reference surface diameter
预矫直机 pre-straightener
预矫直机 pre-straightening machine
预矫直装置 pre-straightening unit
平均直径、层心直径 pitch diameter
直埋式光缆 plow-in optical cable
远程直接数据处理、远程在线数据处理 on-line remote data processing
直接蒸汽硫化 open steam cure
标称直径 nominal diameter
最小出线直径 min. final diameter
最小出线直径 min.final diameter
最小出线直径 minimum final diameter
不同心度、偏心度、不成直线、失配、失调、不匹配 misalignment
模场直径 mode field diameter
低压直流输电信息传输 low transmission voltage d.c. data transmission
低压直流输电信息传输 low transmission voltage d.c.data transmission
最大允许直径 maximum acceptable diameter
最大允许直径 maxinum acceptance diameter
最大理论直径孔径 maxinum theoretical numerical aperture
线性聚乙烯、直链聚乙烯 linear PE
直线式储线器 linear accumulator
直线式电缆牵引装置 linear cable engine
大、中、小直径 large,medium,small diameter
大直径电缆 large-diameter cable
大号[直径]线、粗线 large-diameter wire
大号[直径]线、粗线 large-siza wire
大截面[直径]电缆 large-size cables
电缆的直接冷却[整体冷却]、电缆的间接冷却[单面冷却] lateral cooling of cables
进线直径 inlet diameter
高精度线材矫直器 high precision wire straightener
耐热直焊性漆包线 heat-resistant and solderable enamelled wire
光纤直径 fiber diameter
出线直径、成品线直径 finished wire diameter
固定垂直偏振 fixed vertical polarization(
线盘)侧板直径 flange diameter
压扁机、压延机、矫直机、扁条拉模、拉扁钢丝模、压延工 flattener
矫直辊、矫正辊 dressing roll
有效纤芯直径 effective core diameter
直埋 direct burial
地下敷设、直埋 direct burial (in earth)
直埋电缆 direct burial cable
直埋电缆 direct buried cable
冷却水管、电缆的直接冷却 direct cooling of cable
直接牵引拉线机 direct pull drawing machine
远程直接数据处理、远程在线数据处理 direct remote data processing
直接蒸汽硫化 direct steam cure
直流电压 direct voltage
直接水冷却电缆 direct water-cooled cable
直接波 direct wave
直流耐压试验 direct-current withstand voltage test
直流式压铅机 direct-flow lead press
直接冷却式模架 directly cooled dieholder
不准直 decollimation
直径控制装置、线径控制器 diameter control device
直接耦合 direct coupling
直接串音 direct crosstalk
直流电(流) direct current
直流电缆 direct current cable
直流电力电缆 direct current power cable
直流电阻 direct current resistance
直接拉丝 direct drawing
直接传动 direct drive
电缆在屏蔽前的直径 diameter of the cable beneath the shield
直径比 diameter ratio
直径缩小、缩径 diameter reduction
直径公差 diameter tolerance
十字机头、直角机头 cross head
十字机头、直角机头 cross-head
十字头、直角机头 crosshead
直流增音机 d.c.relay repeater
直流电压 d.c.voltage
直流电压强度 d.c.voltage strength
恒(向、定、流)电流、等幅电流、直流 continuous current
直流电压 continuous voltage
铜带矫直装置 copper strip straightener unit
线芯直径、纤芯直径、(线盘)筒径 core diameter(
纤)芯(直)径偏差 core diameter deviation
电缆芯(直)径比 core ratio
瞬变[断]直流电压 chopped d.c. voltage
包层直径 cladding diameter
包层表面直径偏差 cladding surface diameter deviation
同轴式直角挤出机头 coaxial extrusion crosshead
圈线预矫直机 coil-end pre-straightenner
大截面[直径]电缆 cable with big cross-sectional areas
直埋电缆、地下电缆 buried cable
直埋光缆 buried service lightguide
水线电码直接打印机 cable code direct printer
电缆直径控制 cable diameter control(
线盘)轴孔直径、线盘轴孔直径 bore diameter
平均纤芯直径 average core diameter
筒体直径、线盘筒径 barrel diameter
线模直径 bearing diameter
直流电力电缆 D.C. Power cable
直流电阻不平衡 D.C. resistance unbalance
直流耐压试验 D.C. withstand test
直流电力电缆 D.C.power cable
直流火花试验器[机、仪] DC spark testerdiameter
直径 DIA
导线直径 DOA
缆芯包带层直径 DOCC
泡沫/实心皮绝缘的泡沫部分直径 DOFC
双层护套电缆的内护套直径 DOIJ
线对直径 DiameteroverpairsDOP
屏蔽直径 diameterovershieldDOS
钢屏蔽直径 DiameteroversteelshieldDOSTL
直接淬火线杆 ED rod
高压直流输电子工业 HVDC(high-voltage d.c. transmission)
高压直流输电 HVDC(high-voltage direct current transmission)
长度与直径之比、长径比 L/D ratio
结构高度(对绝缘子串元件) spacing(for string insulator unit)
绝缘子串 insulator string
绝缘子串元件 string insulator unit
不平衡电流、串音电流 unbalanced current
不可懂串音、非线性串音 unintelligible cross-talk
串列式三机架线材压扁整边机 three-stand tandem wire flattening and edging mill
串列式三机架线材压扁机 three-stand tandem wire flattening mill
串连 tandem
串联、串列式布置[装置] tandem arrangement
串联、串列式布置 tandem connection
串列式线材轧机 tandem-type rod mill
实路对幻路的串音 side-to-phantom crosstalk
实路对幻路的远端串音 side-to-phantom far-end crosstalk
实路对实路的串音、实线间串音 side-to-side crosstalk
实路对实路的串音耦合、实线间串音耦合 side-to-side crosstalk coupling
实线间的远端串音 side-to-side far-end crosstalk
串联电路、串联 series circuit
串联、串联电路 series connection
串联干扰电压 series interference voltage
串联电阻 series resistance
反射近端串音 reflected near-end crosstalk
串音 overhearing
近端串音 near-end crosstalk
近端串音衰减 near-end crosstalk attenuation
近端串音损耗 near-end crosstalk loss
近端串音 near-end talk
可懂串音、线性串音 intelligible (linear) cross-talk
间接串音 indirect crosstalk
高频串音特性 high-frequency crosstalk performance
光纤串扰 fiber cross-talk
远端串音 far-end crosstalk
远端串音衰减 far-end crosstalk attenuation
远端串音损耗 far-end crosstalk loss
远端串音防卫度 far-end crosstalk ratio
端串扰、端串音 end cross-talk
串音、串话 cross talk
串音[串话]特性 cross talk characteristic
串音测量[试]法 cross talk measuring method
抗串扰性 cross talk resistance
串音信号 cross-talk signal
串音、串话、串扰、串光、串色 crosstalk
串音衰减 crosstalk attenuation
串音衰减当量 crosstalk attenuation unit
串音平衡 crosstalk balance
串音平衡 crosstalk balancing
同(轴对)串四(线组) crosstalk between coaxial pair and quad
四(线组)串四(线组) crosstalk between star quad
四(线组)串同(轴对) crosstalk between star quad and coaxial pair
同(轴对)串同(轴对) crosstalk between two coaxial pairs
串音电路、串音耦合 crosstalk circuit
串话补偿 crosstalk compensation
串音耦合、串话耦合 crosstalk coupling
串音耦合损耗 crosstalk coupling loss
串音电流 crosstalk current
防串话环 crosstalk damping ring
串音干扰 crosstalk disturbance
串音[串话]因数 crosstalk factor
串音[串话]干扰 crosstalk interference
串音水平 crosstalk level
串音损耗 crosstalk loss
串音测试装置 crosstalk measuring set
串音测试仪 crosstalk meter
串音噪声 crosstalk noise
串音路径 crosstalk path
串音原理 crosstalk principle
串音防卫度 crosstalk ratio
串音信号 crosstalk signal
串音理论 crosstalk theory
串音传输当量、串音衰减 crosstalk transmission equivalent
经由第三回路的串音 crosstalk via tertiary circuit
串话音量 crosstalk volume
无串音特性 crosstalk-free characteristics
串音频率特性 crosstalk-frequency characteristics
无串音的 crosstalk-proof
连续拉线-退火机组、串列式退火机 continuous wire drawing and annealing
路际串音 channel crosstalk
级[串]联、级联电路 cascade connection
级[串]联式冷却器 cascade cooler
电缆串音极限 cable crosstalk limit
十六锭台式编织机16- carrier bench braiding machine16
锭高速编织机16- carrier high speed braider
十六锭高速编织机16- carrier high-speed braiding machine24
锭高速编织机24- carrier high speed braider
金属编织、金属丝编织 wire braid
金属丝编织机、金属丝织机 wire braiding machine
编织套、电缆屏蔽套 wired tube
编织电缆 wove cable
编织电缆 woven cable
镀锡铜线编织 tinned cooper braid
镀锡铜丝编织带[层] tinned copper braid
镀锡铜丝编织屏蔽 tinned copper braid shielding
镀锡铜丝编织带[层] tinned copper mesh
镀锡铜丝编织带 tinned copper mesh(ed)
纤维编织、纱编织 textile braid
金属丝编织带 textile tape with interwoven metal wires
钢丝编织 steel wire braiding
扁编织导线 strap braided conductor
编织套[层]、套管 sleeving
防噪声编织机 sound enclosure braiding machine
屏蔽编织(层)、编织屏蔽(层) shielded braid
屏蔽编织 shielding braid
丝编织线 silk braided wire
镀银铜线编织屏蔽(层) silver plated copper wire braided screen
单头编织机 single-head braiding machine
编织层的浸渍 saturation of braid(编织机)剪模 scissor die
屏蔽编织(层)、编织屏蔽层 screening braid(编织机)右旋侧架 right-hand side frame
加强编织(层) reinforcing braid(编织机的)面板 race plate
编织覆盖率 percentage of braiding coverage
编织机的]摆动臂 osciliating arm
金属(丝)编织 metal braiding
金属丝编织电缆 metal-braided cable
金属(丝)编织(层) metallic braid(编织机)左转侧架 left-hand side frame
束(绞)线、编织线 litz wire
束(绞)线、编织线 litzen wire
束(绞)线、编织线 litzenwire
束(绞)线、编织线 litzwire
编织机 loom
编织机 knitter
针织式编织机 knitting machine
编织线芯超导体 lattice braided supperconductor
编织节距 lay of braiding
高密度编织屏蔽 high-density braid shield
高速编织设备 high-speed braiding equipment
高速编织机 high-speed braiding machine(编织机的)喇叭状齿轮 horngear
玻璃丝编织(层) glass coated micro wire
全自动双头编织机 full automatic dual-head braider
玻璃丝编织线 fiber-glass braid wire
编织物 fabric tape
铜丝编织带 fabric tape with interwoven copper wire
双层编织的 double-braid
双头编织机 dual-head braider(编织机)模臂 die arm
棉纱编织(层) cotton braid
棉纱编织 cotton braiding
棉纱编织机 cotton-yarn braiding machine
铜丝编织屏蔽 copper braid shielding
铜编织线 copper braided wire
铜丝编织 copper braiding
铜丝编织带 copper mesh tape
铜丝编织带 copper threaded textile tape
铜线编织(层) copper wire braid
铜丝编织 copper wire braiding
铜丝编织屏蔽 copper-mesh screen
铜丝编织屏蔽 copper-mesh shield
布、编织物 cloth
玻璃丝编织尼龙护套电缆 cable with glass braid and nylon finish
电缆编织机 cable braider
电缆编织机 cable braider machine
电缆编织机 cable covering machine
编织、编织层 braid
编织角 braid angle
铜芯编织电缆 braid cable with copper conductor
编织同轴屏蔽 braid coaxial shielding
编织导线 braid conductor
编织点 braid point
编织屏蔽电缆 braid shielded cable
编织线 braid wire
编织电缆 braid-covered cable
编织导线 braided conductor
铜丝编织屏蔽 braided copper screen
棉纱编织层 braided cotton covering
编织屏蔽 braided shield
编织线 braided wire
编织屏蔽电缆 braided-shiled cable
编织机 braider
编织 braiding
编织角 braiding angle
编织头 braiding head
编织机 braiding machine
编织机锭子 braiding machine carrier
钢丝编织 braiding machine for steel wire
编织车间 braiding workshop
编织涂蜡 braiding-impregnating
裸铜丝编织 bare copper braiding
氟化乙烯丙烯绝缘玻璃或石棉编织线 FEP insulated wire with glass or asbestos braid
氟化乙烯丙烯绝缘玻璃或石棉编织线 FEPB(fluorated ethylene-propylene insulated wire with glass or asbestos braid)
皱纹铝护套 corrugated alumnimum sheath
热缩护套 the heath shrinkable sleeves
护套 jacket
铅护套 Lead sheath
外护套 outer sheath
护套 sheathing
铝-聚乙烯粘接护套 APL sheath
铝-树脂-聚乙烯-铝-聚乙烯综合护套 ARPAP type sheath
铝-钢-聚乙烯综合护套 ASP sheath4
铝-聚乙烯综合护套电缆 Alpeth cable
铝-聚乙烯综合护套 Alpeth cover
铝-聚乙烯综合护套电缆 Alpeth sheathed cable
铝-聚乙烯综合护套 Alpeth-sheath
焊接皱纹钢带护套 welding corrugated steel sheath
护套起皱 wrinkle of jacket
壁厚、绝缘[护套]厚度 wall thickness
内护套、内护层 undersheath
硬橡皮电缆护套 tough rubber cabtyre sheath
高频熔焊皱纹金属护套 toughlex sheath
挤包绝缘或护套 tubing
双活塞电缆护套挤压机 twin-ram cable sheathing press
热塑性氯化聚乙烯护套 thermoplastic chlorinated polyethylene jacket
热塑性塑料绝缘及护套电缆 thermoplastic insulated and jacketed cable
剥除电缆护套 to strip the cable sheath
夯实、捣固、铅护套扩张试验 tamping
丁苯合成橡皮护套 styrene-butadiene synthetic rubber jacket
在接头处护套互联的电缆系统 system with the cable sheaths connected across the joints
内护套、内护层 undersheath
挤包绝缘或护套 tubing
钢-铝-聚乙烯综合护套电缆 stalpeth cable
钢-铝-聚乙烯护套 stalpeth cover
钢-铝-聚乙烯综合护套 stalpeth sheath
钢-铝-聚乙烯综合护套电缆 stalpeth sheathed cable
钢-铝-聚乙烯综合护套 stalpeth-sheath
钢护套 steel sheath
光护套、光滑护套 smooth sheath
光滑铝护套 smooth-profile aluminium sheath
光滑护套电缆 smooth-sheathed cable
护层、护套 sheath
护套轧纹 sheath crimping
护套偏心监控仪 sheath eccentricity monitor
护套涡流损耗系数 sheath eddy current loss factor
护套绝缘环 sheath insulating ring
护套损耗 sheath loss
护套损耗 sheath losses
护套结构 sheath make-up
护套加固箍 sheath reinforcing bandage
护套的接续 sheath splice
护套的接续 sheath splicing
护套加强元件、护套加强单元 sheath strength member
护套剥除机、剥护套机 sheath stripping machine
护套表面 sheath surface
护套厚度 sheath thickness
护套换位 sheath transposition
护套(内)壁 sheath wall
护套壁厚 sheath wallthickness
护套线、被覆线 sheath wire
护套电缆 sheathed cable
固定布线用护套电缆 sheathed cable for fixed wiring
护套线、被覆线 sheathed wire
挤[包]护套、护套 sheathing
护套混合物[料] sheathing compound
护套挤制生产线 sheathing line
护套材料 sheathing material
护套试样 sheathing test-piece
护套线、被覆线 sheathing wire
护套颜色 sheating color
护套工段 sheating department
单护套 single sheath
单芯电缆(有或无护套) single-core cable (with or without sheath)
内部配线用单芯无护套电缆、布线电缆 single-core non-sheath cable for internal wiring
有护套的单芯导线 single-core sheathed conductor
单护套电缆 single-jacketed cable
聚乙烯密封护套 sealpeth sheath
自粘性外护套 self-bonding overcoat
护套剥离绳 rip cord
橡皮绝缘护套 rubber insulating blanket
橡皮护套、橡套 rubber sheath
加固型铅护套 reinforced lead sheath
增强型护套 reinforced sheathv
剥除(绝缘、护套)、拆卸 remove
铝护套电力电缆 power cable with aluminium sheath
抗压力护套 pressure-retaining sheath
护套 protective jacket
护套、护层 protective jackte
护套 protective sheath
平[光]滑护套 plain sheath
塑料护套 plastic sheath
塑料护套厚度检测装置 plastic thickness test unit
塑料[非金属]护套电缆 plastic-sheathed cable
氯丁橡胶护套电缆 polychloroprene sheathed cable
聚乙烯护套 polyethylene jacket
聚乙烯护套料 polyethylene jacking compound8
聚乙烯护套料 polyethylene sheating compound
聚乙烯护套电缆 polyethylene-jacketed cable
铅-聚乙烯综合护套 polyethylene-protected lead sheath
聚乙烯铝膜粘接护套 polyethylene/aluminium bonded laminate sheath
聚乙烯护套电缆 polythene jacketed cable
聚乙烯绝缘聚氯乙烯护套电缆 polythene-insulated cable sheathed with PVC
聚氯乙烯绝缘及护套电缆 polyvinyl chloride insulated and sheathed cable
聚氯乙烯护套 polyvinyl chloride jacket
护套的透潮 permeation through jacket
聚合物外护套 outer polymeric sheath
外护套 outer sheath
外护套 outer shell
外护套、外护层 overcoat
外护套、外护层 oversheath
耐臭氧乙丙橡胶护套 ozone-resisting ethylene propylene rubber jacket
包套、外护套 package sheathing(
油浸)纸绝缘铅护套电缆 paper-insulated lead-covered cable(
油浸)纸绝缘铅护套电缆 paper-insulated lead-sheathed cable
纸绝缘金属护套电缆 paper-insulated metal-sheathed cable
非金属护套 non-metallic sheath
非金属护套电缆 non-metallic-sheathed cable
无护套电缆 non-sheathed cable
固定布线用无护套电缆 non-sheathed cable for fixed wiring
非金属护套 nonmetallic covering
尼龙护套电缆 nylon jacketed cable
尼龙护套光纤 nylon-jacketed optical fiber
纸绝缘金属护套充油电缆 oil-filled paper-insulated metal-sheathed cable
多层护套(北美采用) multilayered jacket
多层护套 multilayered sheath
多层护套、层式护套 multiple sheath
天然橡胶护套 natural rubber jacket
金属护套 metal sheath
金属护套电缆 metal-sheathed cable
铜芯矿物绝缘铜护套电缆 mineral-insulated copper-sheathed cable with copper conductor
防潮护套 moisture barrier jacket
防潮护套 moisture barrier sheath
氧化镁绝缘金属护套电线 magnesia-insulated metal sheathed wire
聚乙烯-铅综合护套层、铅-聚乙烯综合护套 lepeth
铅-聚乙烯综合护套电缆 lepeth cable
铅-聚乙烯综合护套电缆 lepeth-sheath cable
轻型聚氯乙烯护套电缆 light PVC-sheathed cable
浅色护套 light-colored jacket
铝-聚乙烯粘接护套 laminated aluminum-polyethylene sheath
金属护套 metal sheath
层式护套、多层护套、薄层粘接护套 laminated sheath(
层状)粘接[结]带、金属-塑料综合护套用复合带 laminated tape
压铅机、电缆铅护套挤压机 lead cable-sheathing press
压铅机、铅护套挤压机 lead press
铅护套变形 lead sheath strain
铅护套、铅包 lead sheathing
铅合金护套 lead-alloy sheath
铅合金护套 lead-alloy sheathing
铅合金护套电缆 lead-alloy-sheathed cable
铅-聚乙烯综合护套 lead-polyethylenev
挤压[挤包]铅护套、压铅 n
铅(护)套、铅护套 lead-sheath
铅护套挤压机、压铅机 lead-sheathing press
内护套(北美采用) inner jacket
挤压[挤包]铅护套、压铅 n
绝缘与护套挤包设备 insulating and jacketing plant
绝缘捩护套材料 insulating jacketing material
护套(在北美、 sheath
仅指金属包覆层)、护层、外壳 jacket
护套渗漏 jacket leak
护套剥除工具 jacket removal tool
护套、包护层 jacketing
护套 jacking
护套印字机 jacking machine
聚氯乙烯绝缘单芯无护套高温电缆 high temperature PVC insulated single-core non-sheathed cable
高折射率护套 higher-index jacketing
液压连续式电缆护套挤压机 hydraulic continuous cable-sheathing press
无卤素护套材料 halogen-free sheathing material
无卤护套 halogon-free jacket
重型丁腈/聚氯乙烯护套 heavy-duty acrylonitrile-butadiene/polyvinyl chloride(NBR/PVC) jacket
重型氯化聚乙烯护套 heavy-duty chlorinated polyethylene(CPE)jacket
通用单芯无护套电缆 general purpose single-core nonsheathed cable
通用丁腈/聚氯乙烯护套 general-purpose acrylonitrile-butadiene/polyvinyl chloride(NBR/PVC) jacket
通用氯化聚乙烯护套 general-purpose chlorinated polyethylene(CPE) jacket
通用乙丙烯橡皮护套 general-purpose ethylene-propylene rubber jacket
聚乙烯-铝带综合护套 glovar sheath
卷边[摺边]铝护套 folded aluminium sheath
卷[摺]边铝护套 folded aluminium shield
铝护套锉削 filing of the aluminium sheath(for jointing)
阻燃护套 flame-retardant jacket
超重型黑色氯化聚乙烯护套 extra-heavy-duty chlorinated polyethlene jacket
挤制铝护套 extruded aluminium sheath
电缆上挤包护套 extrusion of the sheath on to the cable
厚度均匀<绝缘、护套等> equithickness
双护套 double sheath
双活塞电缆护套挤压机 double-acting cable sheathing press
双护套光纤 double-jacketed optical fiber
双活塞电缆护套挤压机 double-ram cable sheathing press
双护套电缆 double-sheathed cable
双护套电缆 dual jacketed cable
偏心(率、度)<绝缘、护套> eccentricityv
、 n(
管子或护套的)减径 die-downv(
金属护套的)减径 die down
皱纹铝护套 corrugated aluminium sheath
皱纹铝护套电缆 corrugated aluminium-sgeathed cable
皱纹铜护套 corrugated copper sheath
皱纹无缝护套 corrugated seamless sheath
皱纹护套 corrugated sheath
皱纹钢护套 corrugated steel sheath
皱纹钢护套电缆 corrugated steel-sheathed cable
护套的龟裂 cracking of jacket
电缆护套的交叉连接[粘接] cross-bonding of cable sheaths
交联氯化聚乙烯护套 crosslinked chlorinated polyethylene jacket
交联氯磺化聚乙烯护套 crosslinked chlorosulfonated polyethylene jacketv
剥除(绝缘、护套) cut back
电缆护套损伤[损坏] damage to the cable sheath
外护套 containment
连续式电缆护套挤压机 continuous cable sheathing press
铜带屏蔽尼龙外护套电缆 copper tape screen nylon jacketed cable
铜护套电缆 copper-sheathed cable
皱纹护套电缆 cormex cable
电缆护套轧纹 v
轧纹 corrugate
耐寒护套 cold-proof sheath
