首页 > 专业英语|国际贸易
[翻译求助] 请求翻译
P:2009-06-08 16:09:18
请求翻译,在这里先谢过了!
Material Safety Data Sheet
Company's name:                                              Date:
The answersection:                                             Page:  1  Of  2
Responsible person for answer:
Style:
Note: Blank space are not permitted if any item is not applicable or no
                           information is available , the space must bemarked to indicate that.
SECTION 1 - MATERIAL  I DENTIFICATION AND  INFORMATION
CONTENTS- Chemical Names and Common Notes OSHA  ACGIH OTHER LIMITS
               (Hazardous Components 1% or greater) % PEL TLV RECOMENDED
OSHA
PEL
ACGIH
TLV
OTHER LIMITS RECOMENDED
TOTAL
100
SECTION 2 -- PHYSICAL / CHEMICAL  CHARACTERISTICS
Boiling Point:
Specific Gravity:
Vapor Pressure:
Melting Point:
Vapor Density:
Evaporation:
Solubility in Water:
Water Effective:
Appearance and Odor:
SECTION  3 -- FIRE  AND  EXPLOSION  HAZARD  DATA
Flash Point and Method used:
Auto-Ignition Temperature:
Flammable Limits in Air % by Volume:
Extinguisher Media:
Special Fire Fighting Procedures :
Unusual Fire and Explosion Hazards:
*Optional              ※NA=Not Applicable
coil of rod - 成圈线杆,杆圈 (0) 投诉
P:2009-06-08 16:10:28
Page:  2  Of  2
SECTION  4  -- REACTIVITY  HAZARD  DATA
STABILITY
□ Stable
□Unstable
Conditions To Avoid:
Incompatibility(Materials to Avoid): Not known.
Hazardous (Decomposition Products):
Hazardous Polymerization:
□ May Clear
□ Will not Clear
Conditions To Avoid :
SECTION  5  -- HEALTH  HAZARD  DATA
PRIMARY ROUTES   □ Inhalation □ Ingestion
OF  ENTRY         □ Skin Absorption□ Not Hazardous
CARCINOGEN□NIP    □ OSHA
LISTED  IN □LARC Monograph □ Not Listed
HEALTH
HAZARDS
Acute:
Chronic:
Signs and Symptoms by Exposure:
Medical Condition Generally Aggravated by Exposure:
EMERGENCY FIRST AID PROCEDURES - Seek medical assistance for further treatment, observation and support, if necessary.
Eye Contact :
Skin Contact :
Inhalation :
Ingestion :
SECTION  6  --  CONTROL  AND  PROTECTIVE  MEASURES
Respiratory Protection :Not required.
Protective Gloves :Not required.
Eye Protection :Not required.
VENTILATION
USED
□ Local Exhaust
□ Mechancial (general)
□ Special
□ Other (Specify)
□ Not Required
Other Protective Clothing & Equipment:
Hygienic Work Practice :
SECTION  7  --  PRECAUTIONS  FOR  SAFE  HANDLING  AND  USE / LEAK  PROCEDURES
Steps to be Taken If Material is Released Or Spilled:
Waste Disposal Methods:
Precautions to be Taken in Handling and Storage:
Other Precaution and/or Special Hazards:
*Optional                        ※ NA = Not Applicable
varnishing unit - 涂漆装置 (0) 投诉
P:2009-06-08 16:39:55
第六部分--控制保护措施
Respiratory Protection :Not required.  呼吸保护:不需要
Protective Gloves :Not required. 防护手套:不需要
Eye Protection :Not required. 眼睛保护:不需要
VENTILATION
USED 通风换气
□ Local Exhaust 局部排出
□ Mechancial (general)机械排出(通常使用)
□ Special 特定方法
□ Other (Specify) 其他(特定)
□ Not Required 不需要
Other Protective Clothing & Equipment:  其他防护服和防护设备:
Hygienic Work Practice : 卫生生产实习
第七部分——安全操作使用规程预防
Steps to be Taken If Material is Released Or Spilled: 材料释放或者溢出后的措施
Waste Disposal Methods: 废物处理方法
Precautions to be Taken in Handling and Storage: 操作储存过程中采取的预防
Other Precaution and/or Special Hazards: 其他预防措施和/或者特别的危险
*Optional  可选择的                      ※ NA = Not Applicable 不适用的
appleseden 奖励 20 金币,.08 声望,于 2009-6-8 17:26:59 原因:加分奖励
E-beam cross-linking - 电子束交联 (0) 投诉
P:2009-06-08 16:52:10
第四部分——反应危险数据
STABILITY 稳定性
□ Stable 稳定
□Unstable不稳定
Conditions To Avoid: 避免的环境
Incompatibility(Materials to Avoid): Not known.不相容性(避免的材料):不知道
Hazardous (Decomposition Products): 危险性(分解产物)
Hazardous Polymerization:  聚合危险性
□ May Clear 可能清除
□ Will not Clear 将不会被清除
Conditions To Avoid :避免的环境
第五部分——健康危险数据
PRIMARY ROUTES  主要路径 □ Inhalation 吸入□ Ingestion摄取
OF  ENTRY         □ Skin Absorption皮肤吸收 □ Not Hazardous 没有危险
CARCINOGEN 致癌物 □NIP    □ OSHA
LISTED  IN □LARC Monograph □ Not Listed 没有列出
HEALTH
HAZARDS健康危险因素
Acute: 急性的
Chronic: 慢性的
Signs and Symptoms by Exposure:  接触后产生的症状
Medical Condition Generally Aggravated by Exposure: 接触后恶化的医学条件
EMERGENCY FIRST AID PROCEDURES 紧急急救程序- Seek medical assistance for further treatment, observation and support, if necessary.如果需要,寻求医学进一步的观察诊断治疗。
Eye Contact : 眼睛接触
Skin Contact : 皮肤接触
Inhalation : 吸入
Ingestion : 摄取
de-reeling device - 放线装置 (0) 投诉
P:2009-06-08 16:57:41
第二部分——物理化学特性
Boiling Point: 沸点
Specific Gravity: 比重
Vapor Pressure: 蒸汽压
Melting Point: 熔点
Vapor Density: 蒸气密度
Evaporation: 蒸发
Solubility in Water:水溶性
Water Effective:
Appearance and Odor: 外貌和气味
第三部分——火与爆炸危险数据
Flash Point and Method used:   闪点以及测试方法
Auto-Ignition Temperature:  自燃温度
Flammable Limits in Air % by Volume: 空气中体积燃烧极限
Extinguisher Media:   灭火介质
Special Fire Fighting Procedures :  灭火的特别程序
Unusual Fire and Explosion Hazards: 特别的火以及爆炸危险
processing - (数据)处理;工艺过程 (0) 投诉
P:2009-06-08 23:39:35
谢谢away0210,虽然翻译的有点生硬,但大意还是差不多理解,十分感谢!
Star Physical Topology - 星形物理拓扑结构 (0) 投诉
P:2009-06-09 10:26:42
还能有谁再给具体的翻译吗
continuous pickling device - 连续酸洗装置 (0) 投诉
P:2009-06-13 08:09:05
材料安全数据表
公司名称:日期:
该answersection :页数: 1 2
负责人答:
风格:
注:空格是不能容许的,如果任何项目不适用或根本没有
                           资料,空间必须bemarked表明。
第1节-物料予别和信息
目录化学名称和职业安全与卫生署共同注ACGIH其他限制
                (有害成分的1 %或更高) %帕弗瑞限值建议
 职业安全与卫生署
帕弗瑞
  ACGIH
限值
 其他限制的建议
POSS - prototype optical surveillance system标准光学监视系统 (0) 投诉
P:2009-06-16 02:55:54
上面好像图片的表格是怎么发上去的啊?
纳闷中~~我不会发呢!
我想帮你发专业一点的翻译啊
那个教我一下吗?
utility model - 实用新型 (0) 投诉
P:2010-12-25 11:59:50
需要的话联系我:arroy.cai@gmail.com
estuary cable - 水下电缆,过河电缆 (0) 投诉
