首页 > 特种电缆
[风能电缆] 风电标准目录
P:2009-06-05 10:22:24
风电标准目录
<DIV align=center>序号</DIV><DIV align=center>风电场名称</DIV><DIV align=center>英文名称</DIV><DIV align=center>备注</DIV>
GB/T 19115.2-2003离网型户用风光互补发电系统 第2部分:试验方法The off-grid wind-PV hybrid generating electricity of household-use Part 2: Test method
GB/T 19115.1-2003离网型户用风光互补发电系统 第1部分:技术条件The off-grid wind-PV hybrid generating electricity of household-use Part 1: Technical condition
GB/T 19073-2003风力发电机组 齿轮箱The gearbox of wind turbines generating system
GB/T 19072-2003风力发电机组 塔架The tower of wind turbines generating system
GB/T 19071.2-2003风力发电机组 异步发电机 第2部分:试验方法Asynchronous generator of wind turbines generating system Part 2: Test method
GB/T 19071.1-2003风力发电机组 异步发电机 第1部分:技术条件Asynchronous generator of wind turbines generating system Part 1: Technical condition
GB/T 19070-2003风力发电机组 控制器 试验方法The controller of wind turbines generating system - Test method
GB/T 19069-2003风力发电机组 控制器 技术条件The controller of wind turbines generating system - Technical condition
GB/T 19068.3-2003离网型风力发电机组 第3部分:风洞试验方法Off-grid wind turbines generating system - Part 3: Wind tunnel Test method
GB/T 19068.2-2003离网型风力发电机组 第2部分:试验方法Off-grid wind turbines generating system - Part 2: Test method
GB/T 19068.1-2003离网型风力发电机组 第1部分:技术条件Off-grid wind turbines generating system - Part 1: Technical condition
GB/T 18710-2002风电场风能资源评估方法Methodology of wind energy resource assessment for wind farm
GB/T 18709-2002风电场风能资源测量方法Methodology of wind energy resource measurement for wind farm
GB 18451.2-2003风力发电机组 功率特性试验Wind turbine generator systems - Power performance test
GB 18451.1-2001风力发电机组安全要求Wind turbine generator systems - Safety requirements
GB 17646-1998小型风力发电机组 安全要求Safety of small wind turbine generator systems
GB/T 16437-1996小型风力发电机组结构安全要求Safety requirements for small wind turbine generator structures
GB/T 13981-92
风力机设计通用要求
Design general requirements for wind energy conversion system
GB/T 10760.2-2003离网型风力发电机组用发电机 第2部分:试验方法The generator of off-grid wind turbine generator systems - Part 2: Test method
GB/T 10760.1-2003离网型风力发电机组用发电机 第1部分:技术条件The generator of off-grid wind turbine generator systems - Part 1: Technical condition代替GB/T 10760.1-1989
GB 8116-1987风力发电机组 型式与基本参数Wind-generating sets-Type and basic parameters
GB/T 2900.53-2001电工术语 风力发电机组Electro technical terminology - Wind turbine generator systems
DL/T 5067-96风力发电场项目可行性研究报告编制规程Code on compiling feasibility study report of wind power projects
DL/T 797-2001风力发电场检修规程Code on maintenance of wind farm
DL/T 666-1999风力发电场运行规程Code on operation of wind power plant
JB/T 10194-2000风力发电机组 风轮叶片Rotor blades - wind turbine generation system
JB/T 10137-1999提水和发电用小型风力机 试验方法Wind turbine for water pumping and generating - Test method
JB/T 10300-2001风力发电机组 设计要求Wind turbine generation system - design requirement
JB/T 9740.4-1999低速风力机 安装规范Low speed wind turbine - installation rules
JB/T 9740.3-1999低速风力机 技术条件Low speed wind turbine - technical condition
JB/T 9740.2-1999低速风力机 型式与基本参数Low speed wind turbine - types and basis parameters
JB/T 9740.1-1999低速风力机 系列Low speed wind turbine - series
JB/T 7879-1999风力机械 产品型号编制规则The rule for naming the product of wind energy conversion systemGB 8975-88国标降部标
JB/T 7878-1995风力机 术语Terminology of wind energy conversion systemGB 8974-88国标降部标
JB/T 7323-1994风力发电机组 试验方法Test method of wind turbine
JB/T 7143.2-1993离网型风力发电机组用逆变器 试验方法Test procedure for converter of small wind turbine
JB/T 7143.1-1993离网型风力发电机组用逆变器 技术条件Technical condition for converter of small wind turbine
JB/T 6941-1993风力提水用拉杆泵 技术条件Pump of wind pump - Technical condition
JB/T 6939.2-2003离网型风力发电机组用控制器第2部分:试验方法The controller of off-grid wind turbine - Part 2:Test procedure代替JB/T 6939.2-93
JB/T 6939.1-2003离网型风力发电机组用控制器第1部分:技术条件The controller of off-grid wind turbine - Part 1:Technical condition代替JB/T 6939.1-93
IEC WT 01:2001规程和方法 - 风力发电机组一致性试验和认证系统System for Conformity Testing and Certification of Wind Turbines - Rules and Procedures
IEC 61400-25风电场监控通讯Communications for monitoring and control of wind power PlantDraft 2.WD 2001-08-15
IEC 61400-24风力发电机组防雷Lightning protection for wind turbine systemsTS Ed. 1
IEC 61400-23 风力发电机组叶片满量程试验Full-Scale Structural Testing of Wind Turbine BladesTS Ed. 1
IEC 61400-22 风力发电机组认证Wind Turbines CertificationTS Ed. 1.0
IEC 61400-21 并网风力发电机组功率质量特性测试与评价Measurement and Assessment of Power Quality Characteristics of Grid Connected Wind TurbinesEd. 1
IEC 61400-13 机械载荷测试Measurement of Mechanical LoadsTS Ed. 1
IEC 61400-12 风力发电机组 第12部分:风力发电机功率特性试验Wind Turbine Power Performance Measurement TechniquesEd. 1 1998
IEC 61400-11 风力发电机噪音测试Acoustic Noise Measurement Techniques, edition 2Ed. 1 1998.9.1
IEC 61400-2 风力发电机组 第2部分:小型风力发电机的安全Safety Requirements for Small Wind Turbine GeneratorsEd. 1 1996
IEC 61400-1 风力发电机组 第1部分:安全要求Safety RequirementsEd. 2 1999.2.1
ASTM E 1240-88风能转换系统性能的测试方法Standard Test Method for Performance Testing of Wind Energy Conversion System
ASME/ANSI PTC 42-1988风力机性能试验规程Wind Turbine Performance Test Codes
ANSI/IEEE 1021-1988小型风能转换系统与公用电网互联的推荐规范Recommended Practice for Utility Interconnection of Small Wind Energy Conversion System
communication software - 通信软件 (0) 投诉
P:2009-06-05 12:21:19
什么多西呀!
IPI - initial product inspection原始产品检验 (0) 投诉
P:2009-06-05 18:38:03
有没有风电电缆的部分
n-hole lay-plate - n-孔分线板 (0) 投诉
P:2009-09-10 16:45:12
好像没有啊!
water repellent wire - 防水型电线 (0) 投诉
P:2009-09-21 15:13:22
没有电缆相关的
OFDR - optical frequency domain reflectometer[reflector]光频域反射计[器] (0) 投诉
P:2009-10-13 09:18:33
都是针对整机
field wire - 野战被复线,军用电线 (0) 投诉
P:2009-11-25 16:48:10
怎么哦?
tetrode - 四极管 (0) 投诉
P:2009-12-15 09:26:01
这个有什么用啊 ,看不懂
CRTC - Canadian Radio-Television Commission加拿大无线电电视委员会 (0) 投诉
P:2010-01-31 11:54:04
实用 哈哈
special test - 特殊试验 (0) 投诉
P:2010-02-01 08:25:14
呵呵   骗人吧
sector shaped stranded conductor - 扇形绞合导体 (0) 投诉
P:2010-11-08 14:08:49
没有电缆的 标准
irradiation curing - 辐照交联 (0) 投诉
P:2010-11-09 10:48:18
只有目录没用啊
optics - 光学 (0) 投诉
P:2010-12-21 12:14:43
有标准码 ?
rate of adhesion - 粘附率 (0) 投诉
P:2010-12-21 15:32:22
迷糊着呢 真不知道
applicator roll - 供漆辊 (0) 投诉
