首页 > 国外线缆
[问题求助] UL Style Page 2560
P:2009-06-04 11:37:22
UL Style page里面的有没有UL 2560,具体有哪些标准,请各位高手指点。
plastic insulated conductor cable - 塑料绝缘电缆 (0) 投诉
P:2009-06-04 13:56:17
UL2560是多芯护套电缆,额定温度60度,额定电压30V
导体:裸铜或镀锡铜;绝缘:不限(符合你跟踪服务细则的要求)
成缆:要求与UL2464一样
屏蔽:可以有屏蔽
护套:PVC,护套下的外径在11.0mm以下时:平均厚度0.76,任意点最小厚度:0.61
SBS - stimulated Brillouin scattering受激布里渊散射; (0) 投诉
P:2009-06-04 16:17:20
我这里有!
three-core separately leadsheathed cable - 分相铅套电缆 (0) 投诉
P:2009-06-05 09:20:09
上UL网站一下就查到了!
labelling machine - 贴标签机,标记机 (0) 投诉
P:2009-06-05 17:21:31
UNDERWRITERS LABORATORIESAPPLIANCE WIRING MATERIAL
Subj.758Section 2Page 2560Issued:1972-02-07
Revised:2008-05-27
Style 2560Jacketed Cable.
Rating60 deg C, 30 Vac, Cable flame.
InsulationLabeled or complies with manufacturer's procedure or see Facing Page.
AssemblyTwo or more singles or groups of singles twisted together. The singles or groups may be either laid parallel to form a flat cable with no more than three rows of single conductors or groups of conductors or cabled together to form a round cable. Lay not specified. Barrier layer and/or fillers optional. Manufacturer shall maintain a complete description of each assembly.
ShieldOptional.
JacketPVC
dia of cable in inches of 0.425 or less30 mils min average24 mils minimum at any point
0.426 to 0.700 dia45 avg36 min
0.701 to 1.000 dia60 avg48 min
1.001 to 1.500 dia80 avg64 min
1.501 to 2.500 dia110 avg88 min
2.501 dia and larger140 avg124 min
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseInterconnecting cable for use with EDP equipment where terminated in connectors and located entirely exterior to the equipment, Class 2 wiring systems only.
aluminium cable-sheathing press - 电缆铝护套挤压机,压铝机 (0) 投诉
P:2009-06-09 16:46:36
学习中学习中
modulator - 调制器,调幅器 (0) 投诉
P:2011-08-05 10:58:00
you can go to UL web
tree-retardant cross-linked polyethylene - 防水树交联聚乙烯 (0) 投诉
P:2013-06-19 10:46:41
楼主你手里的不是最新的,去UL网站下载吧。
application die - 涂敷模 (0) 投诉
P:2016-10-30 15:26:31
reel handling device - 线盘运输装置 (0) 投诉
