[问题求助] 各位大侠帮看一下以下规格是什么安规线材
P:2009-05-25 11:56:41
 13x2x(7/0.127mm) tinned copper conductor, single tinned copper braid shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 1500V.
 8x0.25mm silvered copper conductor, tinned copper braid shielding PVC sheath, 75+7-2 Ohm, maximum voltage 1500V.
cable CAT 5, S-FTP. 4x2x0.48mm bare copper conductor, 26 AWG, AL/PET shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 2500V
12x2x0.4mm+0.4mm, tinned copper conductor, twist. AI/PET + tinned copper braid shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 1500V
4x(2x2x0.4mm), tinned copper solid conductor, AWG26, tinned copper braid shielding. PVC sheath, 120+/-15 Ohm, maximum voltage 1200V.
12x2x0.4mm+0.4mm, tinned copper conductor, twist. AI/PET + tinned copper braid shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 1500V.
lubricant cycling system - 润滑剂循环系统 (0) 投诉
P:2009-05-25 12:59:34
13对SFTP28AWG网络线。
CAT。5E SFTP4对单股裸铜,应该为铝箔+编织屏蔽,以下同样的理解
lead smelting bath - 熔铅槽 (0) 投诉
P:2009-05-25 20:50:55
楼主,自己慢慢翻译,中国人就这样,一看英语就头大了,这是通病!
short-circuit current - 短路电流 (0) 投诉
