首页 > 国外线缆
[问题求助] UL3386标准
P:2009-07-01 16:09:39
UNDERWRITERS LABORATORIES, INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 3 Page 3386 Issued: Jan. 29, 1980
Revised: Nov. 15, 2000
Style 3386 Irradiated Polyethylene Insulated Wire.
______________________________________________________________________________
Rating 105°C, 600 Volts.
*Conductor 32-4/0 AWG solid or stranded.
Insulation Irradiated polyethylene. See Facing Page For Compound
Designation.
Minimum Average Minimum Thickness
Conductor Size Thickness, Mils at any point, Mils
32-9 30 27
8-7 45 40
6-2 60 54
1-4/0 80 72
*Shield (Optional)
Jacket (Optional except when shield is used) - PVC, 30 mil min.
average, 27 mil min. at any point.
*Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
*to UL Physical Properties, same as Class 43.
*Representative Spark Test.
UL (4) Detailed Examination.
*Counter-Check (4) Physical Properties, same as Class 43.
*Program (4) Heat Shock.
* (4) Deformation.
* (4) Cold Bend.
* (4) Horizontal Flame Test.
*Marking General.
Use Internal Wiring of Appliances., Tags may indicate the
following: 2500 Volts Peak - For Electronic Use Only.
Designation.
32-9 30 27
8-7 45 40
6-2 60 54
1-4/0 80 72
*Shield (Optional)
* (4) Deformation.
* (4) Cold Bend.
*Marking General.
test plant - 试验设备 (0) 投诉
