首页 > 线缆设计|参数计算
[问题求助] 请教高手解释几款线材规格
P:2009-05-11 11:33:49
1.Alarm cable,13x2x(7/0.127mm) tinned copper conductor, single tinned copper braid shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 1500V.
2.External Alarm Cable,13x2x(7/0.127mm), tinned copper braid shielding. Silicon sheath. 213.25 Ohm, maximum voltage 1500V.
3.A-BIS PCM Cable,8x0.25mm silvered copper conductor, tinned copper braid shielding PVC sheath, 75+7-2 Ohm, maximum voltage 1500V.
4.RS LAN Cable CAT 5, S-FTP. 4x2x0.48mm bare copper rconductor, 26 AWG, AL/PET shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 2500V
5.RS CYR Cable,12x2x0.4mm+0.4mm, tinned copper conductor, twist. AI/PET + tinned copper braid shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 1500V
6.RS CNIA PCM Cable,4x(2x2x0.4mm), tinned copper solid conductor, AWG26, tinned copper braid shielding. PVC sheath, 120+/-15 Ohm, maximum voltage 1200V.
winding wire - 绕包线,绕组线 (0) 投诉
P:2009-05-11 11:52:58
1。Alarm电缆, 13x2x ( 7/0.127mm )镀锡铜导体,单镀锡铜编织屏蔽。聚氯乙烯护套, 100 + / -15欧姆,最大电压1,500V 。
2。External报警电缆, 13x2x ( 7/0.127mm ) ,镀锡铜编织屏蔽。硅鞘。 213.25欧姆,最大电压1,500 。
3。A ,国际清算银行的PCM电缆, 8x0.25mm镀银铜导体,镀锡铜编织屏蔽聚氯乙烯护套, 75 +7-2欧姆,最大电压1,500V 。
4。RS局域网电缆5类,第S -的FTP 。 4x2x0.48mm裸铜线 26AWG,特设工作组,铝/聚酯屏蔽。聚氯乙烯护套,100 + / -15欧姆,最大电压2500V
5。RS西尔电缆,12x2x0.4mm 0.4毫米,镀锡铜导体,捻度。人工智能/聚酯+镀锡铜编织屏蔽。聚氯乙烯护套,100 + / -15欧姆,最大电压1500 V
6。RS CNIA的PCM电缆,4倍( 2x2x0.4mm ),镀锡铜导体固体26 AWG,镀锡铜编织屏蔽。聚氯乙烯护套,120 + / -15欧姆,最大电压的1200V 。
[chicheng 在 2009-5-11 12:33:13 编辑过]
bell type annealing furnace - 钟罩式退火炉 (0) 投诉
