[问题求助] 请教高手解释几款线材规格
P:2009-05-11 11:28:23
 1.Alarm cable,13x2x(7/0.127mm) tinned copper conductor, single tinned copper braid shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 1500V.
 2.External Alarm Cable,13x2x(7/0.127mm), tinned copper braid shielding. Silicon sheath. 213.25 Ohm, maximum voltage 1500V.
 3.A-BIS PCM Cable,8x0.25mm silvered copper conductor, tinned copper braid shielding PVC sheath, 75+7-2 Ohm, maximum voltage 1500V.
4.RS LAN Cable CAT 5, S-FTP. 4x2x0.48mm bare copper rconductor, 26 AWG, AL/PET shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 2500V
5.RS CYR Cable,12x2x0.4mm+0.4mm, tinned copper conductor, twist. AI/PET + tinned copper braid shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 1500V
6.RS CNIA PCM Cable,4x(2x2x0.4mm), tinned copper solid conductor, AWG26, tinned copper braid shielding. PVC sheath, 120+/-15 Ohm, maximum voltage 1200V.
disruptive voltage - 击穿电压 (0) 投诉
P:2009-05-11 14:37:43
 1.Alarm cable,13x2x(7/0.127mm) tinned copper conductor, single tinned copper braid shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 1500V.(13P*28AWG,PP INSULATION,
BRAID,PVC JACTET)
 2.External Alarm Cable,13x2x(7/0.127mm), tinned copper braid shielding. Silicon sheath. 213.25 Ohm, maximum voltage 1500V.(SILICON JACKET)
(8同轴,镀银导体,总编织,PVC外被)
4.RS LAN Cable CAT 5, S-FTP. 4x2x0.48mm bare copper rconductor, 26 AWG, AL/PET shielding. PVC sheath, 100+/-15 Ohm, maximum voltage 2500VTIO
(24AWG双屏蔽网络线)
(12P*26AWG,双屏蔽,PVC外被)
(4P屏蔽线,26AWG导体,编织,PVC外被)
以上的绝缘用料和线径要设计,因为有特性阻抗要求)
[管理员 在 2009-5-11 21:13:34 编辑过]
flexible distribution - 自由配线 (0) 投诉
P:2009-05-16 22:29:02
学习了。。。。。
ultrasonic welding assembly method - 超声波焊接装配法 (0) 投诉
