首页 > 国外线缆
[问题求助] UL 2919可否不印VW-1?
P:2009-05-08 16:55:06
请问我司UL认证时,样品的VW-1测试均不通过,那是不是代表我的线材都不能印VW-1?
但我看了"AWM  Style pages",上面我看2919.。。。等style 均有要求印VW-1。
UL
Counter-Check
*Program
(4) Detailed Examination.
(4) Tensile Strength and Elongation of Jacket.
(4) Heat Shock on Jacket.
(4) Deformation on Jacket.
(4) Cold Bend on Complete Cable.
(4) Vertical Flame Test on Complete Cable.
不知道可否真的不用印VW-1?
recipient - 盛铅筒,容器,盛铝筒 (0) 投诉
P:2009-05-08 16:57:11
请指教!
green-yellow core - 黄绿色线芯 (0) 投诉
P:2009-05-08 17:51:19
样品送UL测试时,其中任何一项没有通过都不能申请到UL证书,而不是能不能印“VW-1”的问题。
feed-in mechanism - 供给机构,供料机构 (0) 投诉
P:2009-05-09 08:53:25
chicheng:
不会吧! 那为什么UL通知我要来我司做IPI呢?
IEA - International Energy Agency国际能源机构 (0) 投诉
P:2009-05-09 08:57:13
还有,像 STYLE 2725类的本身也没有要求必须通过VW-1,那不会也不能用吧?
solid end - 电缆终端套管 (0) 投诉
P:2009-05-09 13:07:16
style pages 中都要求了,肯定要过才可以了,不能过就不要做这个型号了,免得到时候罚你的钱。
CMEA - Council for Mutual Economic Assistance经济互助委员会,经互会 (0) 投诉
P:2009-06-02 14:26:20
如果送樣認証時VW-1沒過,到時線材上印字不能印,如果你對印VW-1無需求的話,那就沒關系了。具體的還需請教UL工程師。
taper - (电缆)包带头;锥形,锥体,锥削 (0) 投诉
P:2009-06-03 14:37:05
三楼说的对!
local line - 市内线路,局用线路 (0) 投诉
P:2009-10-30 15:55:52
berylium copper wire - 铜铍线 (0) 投诉
P:2009-10-30 19:26:11
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 2       Page 2919        Issued:  1978-03-22
                                    Revised:  2005-04-18
Style 2919
Low Voltage Computer Cable.
Rating
80°C, 30 Volts.
Insulated Conductors
No. 40 AWG minimum.  Labeled or complying with Manufacturer’s AWM Procedure having a minimum rating of 80°C, 30 V.
Assembly
Consists of two or more conductors, twisted pairs or groups of twisted conductors twisted together.  The conductors or groups of conductors may be laid parallel forming a flat, oval or round cable.  The lay of the conductors is not specified.  A barrier layer and/or fillers are optional.  Manufacturer shall maintain a complete description of each assembly.  May use same or mixed AWG size.
Covering
(Optional) - A 6 mil or heavier PVC covering may be extruded over the conductor assembly.
Shield
Optional.
Jacket
PVC - Class 43
                   THICKNESS (MILS)
#Dia of cable
under jacket         Minimum            Minimum
in inches            Average          at any point
0.425 or less            30                24
0.426 - 0.700            45                36
0.701 - 1.000            60                48
1.000 - 1.500            80                64
1.501 - 2.500           110                88
2.501 and larger        140               112
# - Major dia if cable is flat or oval.
Braid
Optional.
Standard
Appliance Wiring Material UL 758.
                                (Continued on Page 2919A)
Subj. 758       Section 2       Page 2919A       Issued:  1978-03-22
                                    Revised:  2003-02-17
Instructions
to UL
Representative
The designation of all Styles of the individual conductors
used making up the cable assembly shall be available, and
the UL Representative’s tag shall indicate if the Style is
labeled or not.  If they are not labeled, the appropriate
Follow-Up Tests shall be conducted.
UL
Counter-Check
Program
(4)  Cold Bend on Completed Cable.
(12) Cable Flame Test on Completed Cable.
If the insulated Styles are not labeled, the appropriate Follow-Up Tests shall be conducted.
Marking
General.
Use
As internal wiring or external interconnection in Class 2 Circuits of electronic computers and electric business machines.
pulse response - 脉冲响应 (0) 投诉
