首页 > 国外线缆
[国外型号] 求助高手,看看这是什么电缆?
P:2007-01-11 16:37:44
求助高手,看看这是什么电缆?先谢谢了!
Technical requirements
This specification talks about to HD polyethylene isolated copper cable 75 HDPE °C with neutral concentric, (2x#8+1x#8 AWG), 600 V, with stuffed and jacket for the three-wire single-phase system 120/240 volts. The geometry of the cross-sectional section of the finished cable will have to be to circulate.
Characteristics of the phase conductor
• The used raw material in coppe
• Before of its application on the copper conductor it must fulfill the requirements of norm ASTM D 1248.
• The isolation and the jacket must fulfill the requirements established in norms UL 854 and UL 1581, be adapted for humid and dry means use, to be resistant to the mechanical efforts during the installation and operation of the cable, and to be resistant to ultra-violet rays.
• The two phases
The concentric neutral conductor must be conformed by soft copper wires applied on the filling. The factor of wiring or step does not have to be inferior to the stipulated thing in UL 854.
• The wires of the concentric neutral conductor will be applied helically or by another system of no rectilinear manufacture as it stipulates UL to it 854 and must uniformly be distributed throughout the length
Characteristics of the jacket or cover
• It will have to be of HD polyethylene HDPE, and their compounds will have to fulfill norm ASTM D 1248.
• It must be adapted for humid and dry means uses.
• It must be resistant to the mechanical efforts during the installation and operation of the cable, and to be reasonably flexible.
• It must be of black color, with black pigmentation of resistant smoke a
line communication - 有线通信 (0) 投诉
