首页 > 国外线缆
[问题求助] UL 10362 PFA铁氟龙电线
P:2006-07-03 08:07:26
UL 10362 PFA
铁氟龙电线
Teflon Wire
额定温度:250℃
额定电压:600V
火花测试:6000V
导体:镀锡铜线(单支或多股)
绝缘层:PFA
安全标准:UL758 CSA C22.2
通过UL VW-1及CSA FT1 垂直燃烧
Rated Temperature:250℃
Rated Voltage:600V
Spark Test:6000V AC
Conductor:Tinned Copper(Solid or Stranded)
Insulation:PFA
Standards for Safety:UL758 CSA C22.2
Pass Ul VW-1 and CSA FT1 vertical flame test
Use:Internal wiring of appliances or electronic equipment.
slip-type drawing - 滑动式拉线 (0) 投诉
P:2007-08-29 08:57:34
各位大侠,有没有UL62标准?谢谢提供.
difference quantity - 差异量 (0) 投诉
