首页 > 国外线缆
[问题求助] 请问LED方面的UL认证是什么?
P:2009-04-15 10:25:29
| LED lightingproducts | ||
| Indicator lights | UL 48 | – |
| Work lights, cabinet lights, desk lamps, floor lamps, wall lamps, etc. (all with power plugs) | UL 153 | Covers portable lighting products, connected to a branch circuit rated 120 V 15 AMP or 20 AMP |
| Christmas tinsel lights | UL 588 | – |
| Emergency lighting and exit signs | UL 924 | – |
| Lights for display cabinets and mirrors | UL 962 | – |
| Stage lights | UL 1573 | – |
| Step lights, down lights, ceiling lights, hanging lamps, wall lamps, street lights, pole lights, etc (all without power plugs) | UL 1598 | Covers fixed lighting products, used in a non-hazardous location and connected to a branch circuit rated 600 V or less |
| Nightlights | UL 1786 | – |
| Low voltage garden lights(without power plugs) | UL 1838 | – |
| Tube lights | UL 2388 | – |
| LED light bulbs | ||
| LED Indicators | UL 496 | – |
| LED light bulbs (ANSI Base),with built-in drive circuit | UL 1993 | E27 Base is European standard and is not applicable to the U.S. market. E26 Base is the standard for the U.S. market. |
| LED light bulbs (non ANSI Base), with built-in drive circuit | UL 496 | – |
| LED arrays or modules, without drive circuit | UL 8750 | – |
| LED drivers | ||
| Power supplies (may have a LPS safety circuit) | UL 60950-1 | Output to LPS safety circuit waives the requirement for an enclosure for the LED module and the LED control module |
| Power supplies (without a Class 2 safety circuit) | UL 1012 | Appropriate enclosure is required to protect the LED module and the LED control module |
| Power supplies (with a Class 2 safety circuit) | UL 1310 | Output to Class 2 safety circuit waives the requirement for an enclosure for the LED module and the LED control module |
| Driver (may have a LPS/Class 2 safety circuit) | UL 935 | Output to LPS/Class 2 safety circuit waives the requirement for an enclosure for the LED module and the LED control module |
| Power supplies for low voltage garden lights | UL 1838 | Appropriate enclosure is required to protect the LED module and the LED control module |
wheel-type capstan haul-off - 轮式牵引装置 (0) 投诉
