[问题求助] 请问电话线标准是什么?哪里能下到呢?
P:2009-04-10 20:41:19
请问电话线标准是什么?哪里能下到呢?
funnel - 漏斗;缩孔,漏斗形物 (0) 投诉
P:2009-04-11 12:07:54
给我个标准号,我可以帮你找到!然后发给你!
IDC - International Documentation Center国际文献中心<设在瑞典 (0) 投诉
P:2009-04-11 19:53:15
YDT840-1996电话线标准,论坛里可以找到的
ACSE - ACSR/AS铝包钢芯铝绞线 (0) 投诉
P:2011-07-25 09:59:37
cN - centi-newton 1/100牛顿,10-2牛顿 (0) 投诉
P:2011-07-25 11:09:05
给你一个相关标准下载网址,各行各业的标准都有,如要请联系QQ441091752
wiring capacity - 布线电容 (0) 投诉
P:2011-07-29 13:51:20
UL20251
high-temperature flexibles - 高温软线 (0) 投诉
P:2011-07-29 13:53:09
UNDERWRITERS LABORATORIES INC.              APPLIANCE WIRING MATERIAL
Subj. 758     Section 2     Page 20251      Issued:  1983-02-23
                                Revised:  2003-08-07
Style 20251       Multi-Conductor Cord.
______________________________________________________________________________
Rating     60°C, 150 Volts, 300 Volts peak.
Conductor     Two to ten 18-33 AWG, tinned or bare, solid, stranded,
           or tinsel.  May include mixed AWG sizes.
Insulation    Polypropylene, 7 mils minimum average, 5 mils minimum
           at any point.
Shielding     (Optional) One or more may be shielded.
Jacket     PVC, Class 43, 20 mils minimum average, 16 mils minimum
           at any point.
Assembly      Cable may be either straight or wound in retractile
           form.  Core may be either flat or round.  Barrier
           layer and/or fillers optional.
Standard      Appliance Wiring Material UL 758.
Instructions  Detailed Examination.
to UL         Physical Properties, Unaged Insulation and Jacket.
Representative    Spark Test.
           Flexibility Test, unaged, if unable to perform Physical
              Properties on tinsel and/or stranded conductors.
UL         (4)  Detailed Examination.
Counter-Check (4)  Physical Properties of Insulation and Jacket,
Program            Unaged and Aged.
           (4)  Heat Shock.
           (4)  Cold Bend.
           (4)  Deformation.
*          (12) Horizontal Flame Test on Cable.
           (4)  Flexibility Test, if unable to perform Physical
                Properties on Tinsel and/or Stranded Conductors.
Marking       General.
Use        Internal cable of electronic equipment, or as
           "Handset Wire or Telephone Cord for Subscriber Sets".
VHSIC - very high speed integrated circuit 极高速集成电路 (0) 投诉
