首页 > 标准共享
[国外标准] IEC 60512-15-2-2008 Connectors for electronic equipment – Tests and measurements –Part 15-2: Connector tests (mechanical) – Test 15b: Insert retention in housing
P:2009-04-09 17:36:25
IEC 60512-15-2-2008 Connectors for electronic equipment – Tests and measurements –Part 15-2: Connector tests (mechanical) – Test 15b: Insert retention in housing.pdf
copper weld steel wire - 铜焊线,铜焊丝;铜包钢线 (0) 投诉
