首页 > 标准共享
[国外标准] IEC 60512-15-3-2008 Connectors for electronic equipment – Tests and measurements –Part 15-3: Connector tests (mechanical) – Test 15c: Insert retention in housing
P:2009-04-09 17:36:25
IEC 60512-15-3-2008 Connectors for electronic equipment – Tests and measurements –Part 15-3: Connector tests (mechanical) – Test 15c: Insert retention in housing.pdf
TCR - temperature coefficient of resistance电阻温度系数 (0) 投诉
