首页 > 标准共享
[国外标准] IEC 60512-15-5-2008 Connectors for electronic equipment – Tests and measurements –Part 15-5: Connector tests (mechanical) – Test 15e: Contact retention in insert,
P:2009-04-09 10:05:27
IEC 60512-15-5-2008 Connectors for electronic equipment – Tests and measurements –Part 15-5: Connector tests (mechanical) – Test 15e: Contact retention in insert,.pdf
lightning surge over voltage - 雷电冲击电压 (0) 投诉
