首页 > 线缆机器设备
[押出设备] 求购电缆设备以及测试仪器
P:2009-04-02 00:22:38
我司的一位老客户,今年想上新的电缆设备生产线,具体要求在下面。如有能生产此设备的企业请速与我联系,将详细的价格以及中英文配置,以及文中的问题,有一个详细的说明。我将在这个月带客户过来考察,希望能真诚合作。我的联系方式是:slfeng007@hotmail.com    沈先生
CABLE PLANT MACHINERIES
I would like to installed a Cable Factory, the range of Cable Production - 1mm2, 1.5 mm2, 2.5 mm2,4.0 mm2....up to 120 mm2 under BDS, BS and VDE Standard of 250/300/450 voltage A/C. Regarding of this to use two extruder machine (60/65mm and 90/95mm), how many number of coils of 100 meters (1mm2 to  16 mm2) and (25mm2 to  120 mm2) can be produce? And to comply its production - following plant machineries are needed to produce cable.
Sl.
Name of the Machine
Capacity
Required
1.
Butt Welding Machine
5/10 KVA
01 (One) set
2.
Annealing Unit (退火设备)
Please mention production capacity of the machine
01 (One) set
3.
Conductor re-winding unit
01 (One) set
4.
Stranding Unit
3, 7 and 1+12 (19 wire) Vertical/Horizontal
01 (One) set
5.
Bounching Machine
High speed double twist for S.W.G- 36/38
7, 14, 24, 40, 80 & 120
01 (One) set
6.
Extruder with cross head die setting attachment
Complete Package including all necessary Machineries from Pay-off to Take-up Unit
60/65mm and 90/95mm
Please mention extrusion Capacity = ? Kg/hrs
02 (Two) sets
7.
P.V.C. Compounding mixture machine
100 kg per Batch, for color mixing
01 (One) set
8.
Bobbin Loading - unloading auxiliary equipment and Nos. of bobbin for Plant operation.
As per required Plant Capacity.
01 (One) set
9.
Packing Unit
01 (One) set
k
Fine Gauge wire drawing machine Inlet Copper dia S.W.G-18 - Outlet dia S.W.G.-35/36
Please Mention the Production Capacity per 8 hrs
For our Enamelling wire Plant
Testing Equipment
<DIV align=center>
Sl.
Description
1.
High Voltage Tester AC/DC
2.
Spark Tester
3.
Cold Impact Tester
4.
Cold Chamber
5.
Hot Water Bath
6.
Hot deformation Tester
7.
Fleambility Tester
8.
Torsan Tester
9.
Laboratory Oven
10.
Swidis Cheamni
11.
Air Aging Oven
12.
Thermal Stability
</DIV>
gripper - 夹钳,夹子,夹头,夹具 (0) 投诉
P:2009-04-02 07:41:16
我来试试吧,我们公司自己有进出口权
plug wire - 塞绳,插塞线,插头线 (0) 投诉
P:2009-04-02 08:24:00
不知道楼主的客人是哪个国家的呢?我们公司刚接了一个孟加拉的定单,看了看你们所需要的设备和他们的差不多,相信我们完全有机会合作的,期待您的回复,并真诚的合作!谢谢!联系方式:13411875884王生,
test model - 试验模型 (0) 投诉
P:2009-04-02 10:34:04
我们可以做;方便留给电话吗?
LSI - large scale integration大规模集成 (0) 投诉
P:2009-04-02 10:37:43
自己顶一下自己的帖子。
楼上的,我已经回复你的邮件。
adhesion test - 粘结试验 (0) 投诉
P:2009-04-02 11:29:41
不要测径仪(Diameter Measurer) 啊。
internall steel-tape armoured cable - 内钢带铠装电缆 (0) 投诉
P:2009-04-02 14:59:39
你好,,相关配置和报价已经发到您的邮箱了,请查收,谢谢!
low temperature test - 低温试验 (0) 投诉
