[问题求助] 请问110KV电缆用石墨有没有相关标准啊?
P:2009-03-25 11:47:12
·如题,如果没有相关标准有没有检测方面的要求?
The seller - 卖方 (0) 投诉
P:2009-03-28 15:57:41
<DIV style="mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: page; mso-element-anchor-horizontal: margin; mso-element-left: center; mso-element-top: 79.85pt; mso-height-rule: exactly"> </DIV><DIV style="mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: page; mso-element-anchor-horizontal: margin; mso-element-left: center; mso-element-top: 79.85pt; mso-height-rule: exactly">粒度测定按GB3520—83《石墨粒度测定方法》干筛法进行</DIV><DIV style="mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: page; mso-element-anchor-horizontal: margin; mso-element-left: center; mso-element-top: 79.85pt; mso-height-rule: exactly">水分、固定碳、分析方法按GB3521—83《石墨化学分析方法》进行。</DIV>
box - 电缆终端头壳体;箱,盒,接线盒 (0) 投诉
P:2009-03-30 09:43:47
谢谢楼上指点!
expert - 专家,能手 (0) 投诉
P:2011-05-09 16:00:29
GB/T3519   GB/T3518
ACC - automatic crosshead change (system)十字(机)头自动更换(系统) (0) 投诉
