首页 > 线缆设计|参数计算
[物理性能] 电线导体偏心距的计算方法
P:2009-03-20 11:04:31
The calculation method of the offset of the wire’s conductor’s center
Definition:
The offset —— conductor’s center deviating to insulation’s center.
Lack of impartiality the degree——minimum insulation the thickness( Min) with biggest insulate the thickness( Max)'s per cent specific value.
Be had by diagram:
Min+R2+O1O2=R1           (1)
Max+R2-O1O2=R1           (2)
Two equation  reducing, and have to calculate the offset :
C= O1O2=( Max- Min)/2    (*)
Remarks: This method does not need the center of the certain circle, and only need to be measured with tool microscope out to insulate the thickness biggest and worth and minimum worth.
SIOLAP - siograthene laminated paper半合成纸 (0) 投诉
P:2009-03-20 15:42:50
有中文的么?
UFMG - Federal University of Minas Gerais(巴西)米纳斯吉拉斯联邦大学 (0) 投诉
P:2009-03-20 23:45:57
这么都是英文的啊。中文的有吗?能不能搞个中文的,在说,这个也基本了  也不用搞哪么复杂。。。。
decoiling unit - 成圈复绕装置,成线复绕装置 (0) 投诉
P:2009-03-21 22:25:21
這個計算方法對,實際操作没有用的?在說了基本的東西,誰都知道要實際操作才可以的.
bar drawer - 大拉机 (0) 投诉
P:2009-03-23 20:25:27
兄台啊!你给翻译过来呢,这样我看不懂啊!
braided shield - 编织屏蔽 (0) 投诉
P:2009-03-27 16:23:04
看不懂也!!!!!!!!
DSF - dispersion-shifted fiber色散位移光纤 (0) 投诉
