首页 > 线缆机器设备
[绞制设备] 新定购笼式绞线机
P:2009-03-18 10:21:00
我们公司新定购以下设备,在广东省的设备厂可联系我 邮件sa571328@163.com
笼式绞线机 6+12组合 18对一次成缆大绞线机 1600mm铁辘的放线架 1600mm的收线机 绞线机装630铁辘!
D.C.servo motor - 直流伺服电动机 (0) 投诉
P:2009-03-18 10:48:06
马上就会把相关资料发给你,呵,,,让您久等了,不好意思
critical angle - 临界角 (0) 投诉
P:2009-03-18 14:04:51
楼上的,怎么资料还没发过来呀
residual performance test - 剩余性能试验 (0) 投诉
P:2009-03-19 22:23:11
我已经发过去了!请看完后,与我联系!
bedding core - 垫芯,填芯 (0) 投诉
P:2009-03-21 14:13:59
Wirshine Wire&Cable Machinery (Nantong) Co., Ltd is located in the City of Haimen—a National Clean City, east near Yellow Sea, south depends on Yangtze River separating of the Shanghai, close to Suzhou-Nantong Yangtze River Bridge, has extremely convenient transportation facilitates. The city is also called as “small Pudong in Golden Triangle”.
WIRSHINE—means Wire Machine,the company is a modern company which specializes in R&D, and manufacturing of machinery and equipment for electric wires and cables, and the main products of the company include different type of planetary stranding machine, rigid frame stranding machine, tubular stranding machine, drum cabling machine, laying-up stranding machine, copper rod drawing machine, aluminum or aluminum alloy rod drawing machine, extruder, optical fiber cable SZ stranding line, optical fiber sheath production line and relevant auxiliary equipments. The company has strong technical strength, advanced technology, excellent processing equipments and strict quality management system, and is dedicated to providing products with high quality and excellent performance. We are waiting to provide detailed technical consultation and perfect services for you.
“Quality achieves future”—we will make and let brand of WIRSHINE become a famous international brand, which leads Chinese market and well known around the world. We are cordially expecting you: select WIRSHINE brand, experience WIRSHINE products and feel WIRSHINE service.
jitter - 不稳定性;晃动,抖动,信号的不稳定性;图像晃动,抖动 (0) 投诉
P:2009-03-22 22:08:18
楼上的能否发中文
roll-on/roll-off arbour-style take-up - 上下盘滚轴式收线装置,滚轴上下盘收线装置 (0) 投诉
P:2009-03-23 20:00:26
全看懂真难
mandrel holder - 模芯座 (0) 投诉
P:2009-03-26 10:55:33
是否要新设备呀??
EPDM - ethylene-propylene diene monomer三元乙丙橡胶 (0) 投诉
P:2009-03-26 14:15:56
是的
digital cross-connect(ing) system - 数字跨接系统 (0) 投诉
P:2009-03-31 22:12:13
兄台是否可考虑成都的设备商啊,我们设备和服务都非常到位的。
failure rate - 故障率 (0) 投诉
