首页 > 产品认证
[船级认证] DNV产品认证申请表格上如何填写?
P:2009-01-13 15:38:27
1. Type Approval of: (Please use one sheet for each type of cable) | ||||||||
2. List of all variants covered by the type approval: | ||||||||
Number of cores and strands x conductor cross-section | Insulation thickness | Inner covering | Sheath thickness inner/outer | Braiding core diameter | Overall | |||
(mm2) | (mm) | (mm) | (mm) | (mm) | (mm) | |||
(Please use company data sheet) | ||||||||
这个是说每种型号电缆一个表格吗?
[klfeixue 在 2009-1-13 15:40:46 编辑过]
attrition wear - 互磨磨损 (0) 投诉
