首页 > 国外线缆
[问题求助] 请教各位SVT电源线与SJT电源线的分别
P:2009-01-08 08:53:04
SVT : Same as SV, using Thermoplastic in place of rubber构造同SV,但绝缘及被覆皆为塑料材料,可以加一条接地线,使用电压300V,温度范围有60℃、75℃、90℃及105℃。SV : Vacuum cleaner cord, rubber insulated and jacketed, light duty in damp locations表示真空吸尘器(Vacuum-Cleaner)用线。以橡胶绝缘橡胶被覆,单线心数为2心,使用电压300V,导线尺寸范围AWG#18~AWG#17,温度60℃。 SJT : Same as SJ, using Thermoplastic in place of rubber亦为UL规格移动型电缆,以橡胶或塑料绝缘,外被为PVC。使用压300V,温度60℃,心数2~4C,导体尺寸范围AWG#18~AWG#10。SJ : Junior hard service, same as S but300V, thickness different
normalized birefringence - 归-化双折射率 (0) 投诉
