首页 > 专业英语|国际贸易
[翻译求助] 各位大侠,请问这个什么意思,ul444中的,搞不明白
P:2009-01-04 08:19:24
The specimens shall be subjected to an applied ac potential that is increased from near zero at a uniform or nearly uniform rate that is not less than 100 per cent of the potential rating of the wire or cable in 60 s and is not more than 100 per cent in 10 s (the rate of increase is not to exceed 500 V/s in
any case).
drycured material - 干式交联材料 (0) 投诉
P:2009-01-04 13:50:14
你想翻译整个句子吗?
pulling-in dog - 穿模夹头(拉线机穿模时用于夹住线端) (0) 投诉
P:2009-01-04 15:10:22
可以的话,就翻译整句,主要是后面的不太懂,麻烦诸位了
tape cable - 扁导体带状电缆,扁平电缆 (0) 投诉
P:2009-01-04 21:17:16
大意如下:
在试样上施加交流电压,试验电压应从接近零开始以匀速或近似于匀速上升,升压速度应在60秒内升至不小于电线或电缆额定电压的100%,在10秒内升至不大于产品额定电压的100%(任何情况下升压速度不得大于500V/s)。
strand clip - 绞线箍 (0) 投诉
P:2009-01-05 08:09:40
谢谢,受用了
AA conductor - 全铝导体,铝合金导体 (0) 投诉
