[Display] Apple Mini DisplayPort Connector Dimension Ver 1.1
P:2008-12-27 12:15:41
若有兴趣开发Mini DisplayPort的,就必须要看附档由Apple发放出来的Mini DisplayPort ConnectorDimension。内里还有Apple的Mini DisplayPort Evaluation License和Mini DisplayPort Connector Implementation License共三份pdf档。
The Mini DisplayPort Connector is a small form factor connectordesigned to fully support the VESA DisplayPort protocol. It isparticularly useful on systems where space is at a premium, such asportable computers or to support multiple connectors on reduced heightadd-in cards. The dimensional specifications of the plug and receptaclemating interface and a recommended PCB landing pad are available fordownload under the Mini DisplayPort Evaluation License. If you agree tothe terms of the evaluation license, download the Mini DisplayPortConnector Dimensions.
Mini DisplayPort Connector Implementation License (No Fee)
If, after evaluation, you would like to obtain a license to develop ordistribute plugs, receptacles or other devices implementing the MiniDisplayPort Connector, please download and print this Mini DisplayPortImplementation License, complete according to the attached checklistand mail two original signed Implementation License forms to theSoftware Licensing address on the checklist. Your license will becomeeffective when signed by Apple.
open-top cable tray - 开顶式电缆托架 (0) 投诉
P:2008-12-27 14:26:57
请问有没有公布的啊?
cylinder - 体筒(挤出机的),螺筒 (0) 投诉
P:2008-12-29 14:02:15
这是苹果公司在12月头公布的,可在网络上找到相关文章。只要在百度下打入'Apple Mini Displayport'便看到如下网址的相关文章:
http://cn.engadget.com/2008/12/03/apple-ponies-up-free-mini-displayport-spec-license/
http://product.ccidnet.com/art/5471/20081204/1628477_1.html
http://www.--cnbeta.com/articles/71231.htm
[lyq214258 在 2008-12-29 15:52:00 编辑过]
voltage life characteristic - 电压寿命特性 (0) 投诉
P:2009-02-09 14:57:22
应该有的吧,我手头就有一条这样的样品.
physically foamed PE insulation - 物理发泡聚乙烯绝缘 (0) 投诉
P:2009-02-09 15:58:11
誰要這個產品,我可以提供。
ingot slicing machine - 切锭机 (0) 投诉
P:2009-02-10 15:34:43
 5楼你好,你们现在是量产,还是处于研发阶段.
 如果是批量的话大家可以聊聊。看是否有合作机会。
Withdraw Force - 拔出力 (0) 投诉
P:2009-02-16 13:24:12
你提供线缆还是成品??
washing tank - 冲洗槽 (0) 投诉
P:2009-02-19 14:20:34
我想要這個產品.
yield strength - 屈服强度,屈服点。某种材料发生弹性变形之最低应力。低于此应力则材料具有弹性,超出此应力,则结构上会受到损害甚至断裂,降伏强度之高低,可以显示该材料之优劣。 (0) 投诉
P:2009-02-20 10:24:16
6樓的兄弟,應該拿到樣品了吧?
multi-colour extruder - 多色挤出机 (0) 投诉
P:2009-02-20 15:13:25
DisplayPort協會公告把Apple的mini Displayport connector歸入Specification 1.2內。
audio-frequency trunk cable - 音频干线电缆 (0) 投诉
P:2009-08-05 12:13:54
想学习可没有金币的啊!!
water vapour Permalex - 水蒸气渗透性,水蒸气渗透率 (0) 投诉
P:2009-08-05 13:41:44
正解了,我们有做,嘿~~
half-duplex - 半双工 (0) 投诉
P:2009-08-05 13:49:09
好东西的啊,受益匪浅的啊
phosphor-bronze wire - 磷青铜线 (0) 投诉
P:2010-09-11 16:02:52
不怎么样
heat run test - 热循环试验 (0) 投诉
P:2011-06-28 12:32:54
DP 1.2
deoxidant - 脱氧剂 (0) 投诉
16
