首页 > 矿用橡套电缆
[橡套电缆] u型m型煤矿用橡套电缆
P:2008-12-20 15:45:09
产品标准standard
本产品按GB12972-1991《矿用橡套软电缆》、MT818-1999《煤矿用阻燃电缆》及Q/320282DCE037-2003标准生产,同时还可根据用户需要按国际电工委员会推荐标准IEC、英国标准、德国标准及美国标准生产。
The product is manufactured according to the standard 《Flexible rubber-sheathed cables for mining purposes》of GB12972-1991,《Flame retardant drade flexible rubber-sheathed cables for mining purposes》of MT818-1999,Q/320282DCE037-2003,the same time is also manufactured according to the standard of IEC、English、GermanyAmerica.
适用范围Applications
矿用橡套软电缆适用于工频额定电压U0/U660/1140V及以下矿用动力装置用移动敷设的电缆。
Flexible rubber-sheathed cables for mining purposes of suitable for mining purposes power device with moving installationrated voltage up toincluding 660/1140V.
使用特性Operating characteristics
● 工频额定电压U0/U为380/660V、660/1140V。
Rated power-frequency voltage U0/U:380/660V660/1140V。
● 电缆导体的最高允许工作温度:65℃
Max. admissible operating temperature of the conductor:65℃
● 电缆允许最低的工作环境温度为-35℃
Permissible long-term operating temperature: Lowest working temperature is :-35℃
● 电缆弯曲半径:The bending radius of cable
D≤25mm.: ≥4D
D>25mm.: ≥6D
(D—Diameter of the cable).
型号
名称
U
UY
MY
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用移动橡套软电缆
UP
UYP
MYP
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用屏蔽移动橡套软电缆
UC
MC
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套采煤机软电缆
UCP
MCP
UCPQ
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套采煤屏蔽软电缆
UZ
UZP
MZ
MZP
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用电钻电缆
UYQ
MYQ
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用轻型软电缆
型号 Type名称 Designation
U
UY
MY
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用移动橡套软电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible cables forming purposes.
UP
UY
P MYP
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用屏蔽移动橡套软电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible shielding cables forming purposes.
UC
MC
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套采煤机软电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible coal cutter cables forming purposes.
UCP
MCP
UCPQ
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套采煤屏蔽软电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible coal cutter shielding cables forming purposes.
UZ
UZP
MZ
MZP
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用电钻电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible drill cables forming purposes.
UYQ
MYQ
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用轻型软电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible light-duty cables forming purposes.
生产范围 Production range of cable
型号 Type额定电压 Rated voltages V芯数 NO.of cores标称截面 Nominal cross-sectional area mm2
主线 Principal line地线 Ground wire控制线 Controlled line
U*10003112.5~70
UP*10003112.5~70
UY ●
MY
380/66031—4~70
UYP ●
MYP
380/66031—4~70
UYP ●
MYP
660/114031—4~70
UC*1000312~710~50
UC ●
MC
380/660313~716~50
UCP*1000312~710~50
UCP ●
MCP
380/660313~716~50
UCPQ*114031335~70
UCP ●
MCP
660/114031335~95
UZ ●
UZP ●
MZ MZP
300/5003112.5~4
UYQ ●
MYQ
300/5002~12——
drum-emptying device - 料桶排空装置(安装在塑料颗粒定量系统上) (0) 投诉
