[挤塑工序] 押出线速计算与螺杆基本资料
P:2008-12-19 13:13:46
| 螺 杆 基 本 資 料 | |||||||||||
| 螺杆編號 | D | P | C/R | L | L/D | P' | D' | D" | 原 編 號 | 用 途 | 備 註 |
| 30-1-1 | 30 | 30 | 3.1 | 763 | 25.4 | 26.4 | 20 | 26.8 | 進料段雙螺紋,壓縮段雙螺紋 | ||
| 30-2-1 | 30 | 30 | 2.9 | 795 | 26.5 | 26.6 | 19.4 | 26.4 | (30-2) | PVC | 標准形 |
| 30-2-2 | 30 | 28.7 | 2.1 | 800 | 26.7 | 24.5 | 22 | 26.1 | D0201042(30-2) | Kynar/LSNH/IRPE | 標准形 |
| 30-2-3 | 30 | 30 | 2.1 | 800 | 26.7 | 25.6 | 24 | 27.2 | 芯押16(30-2) | Kynar LSNH | 壓縮段雙螺紋 |
| 30-2-4 | 30 | 30 | 2.2 | 797 | 26.6 | 26 | 22.2 | 26.4 | 芯押26(30) | PE/PVC/PP | 標准形 |
| 30-2-5印條 | 22 | 22 | 3.5 | 393 | 17.9 | 17.3 | 14.4 | 19.8 | 標准形 | ||
| 32-1-1 | 32 | 32 | 3.0 | 703 | 22 | 27.2 | 21.8 | 28.6 | 芯押22(32-1) | PVC | 計量段柱狀形 |
| 32-1-2 | 32 | 32 | 2.8 | 700 | 22 | 27 | 22 | 28.4 | 芯押20(32-1) | PVC | 計量段柱狀形 |
| 32-1-3 | 32 | 32 | 2.9 | 703 | 22 | 26.3 | 21.7 | 28.5 | 芯押21(32-1) | PVC | 計量段柱狀形 |
| 32-1-4 | 32 | 32 | 3.2 | 700 | 22 | 28.3 | 21.4 | 28.7 | 芯押25(32) | PE/PP | 計量段柱狀形 |
| 32-1-5 | 32 | 32 | 2.1 | 700 | 22 | 27.7 | 21.5 | 27 | 芯押24(32) | KYNAR/IRPE | 壓縮段花鍵形 |
| 32-1-6 | 32 | 32 | 3.2 | 712 | 22 | 27.5 | 21.8 | 28.8 | 芯押23(32) | PVC | 標准形 |
| 32-1-7 | 32 | 32 | 3.7 | 703 | 22 | 28.2 | 21.6 | 29.2 | 計量段柱狀形 | ||
| 32-2-1 | 32 | 32 | 2.3 | 834 | 26 | 28.3 | 23.4 | 28.3 | 芯押01(32-2) | Kynar/LSNH/IRPE | 標准形 |
277807927 奖励 10 金币,.05 声望,于 2012-5-26 9:10:26 原因:辛苦奖 你很有心 但下次最好打包 谢谢
apparatus - 仪器,装置,器械 (0) 投诉
P:2008-12-19 13:14:28
| 32-2-2 | 32 | 32 | 3.1 | 833 | 26 | 27.8 | 20.8 | 28.4 | 芯押03(32-2) | PVC | 壓縮段雙螺紋 |
| 32-2-3 | 32 | 32 | 2.4 | 832 | 26 | 28.5 | 23 | 28.2 | 芯押02(32-2) | Kynar/LSNH/IRPE | 標准形 |
| 32-2-4 | 32 | 31.8 | 3.7 | 833 | 26 | 27.4 | 19.4 | 28.6 | PE | 標准形 (現生產kynar料) | |
| 35-1-1 | 35 | 35 | 2.9 | 978 | 28 | 29 | 23.7 | 31.1 | 芯押04(35) | PVC | 壓縮段雙螺紋,計量段花鍵形 |
| 35-1-2 | 35 | 35 | 3.0 | 978 | 28 | 31 | 22.6 | 30.8 | 芯押07(35) | PVC | 壓縮段雙螺紋 |
| 35-1-3 | 35 | 35 | 2.0 | 985 | 28 | 28.6 | 28.2 | 31.6 | 芯押05(35) | Kynar / LSNH/IRPE | 標准形 |
| 35-1-4 | 35 | 35 | 2.9 | 980 | 28 | 29 | 22.8 | 30.8 | 芯押06(35) | PVC | 標准形 |
| 35-1-5印條 | 30 | 30 | 2.9 | 718 | 24 | 27 | 18.4 | 26 | B96464(35) | PE/PEF/PVC | 標准形 |
| 35-1-6印條 | 30 | 30 | 3.5 | 720 | 24 | 25.8 | 17.5 | 26.4 | 標准形 | ||
| 45-1-1 | 45 | 45 | 2.9 | 1133 | 25 | 40.8 | 29 | 39.4 | 芯押08(45-1) | PVC | 壓縮段雙螺紋 |
| 45-1-2 | 45 | 45 | 3.3 | 1135 | 25 | 39.5 | 30.7 | 40.7 | 標准形 | ||
| 50-1-1 | 50 | 50 | 2.6 | 1263 | 25 | 46 | 34.2 | 44 | 芯押10(50-1) | PVC/LSNH/IRPE | 標准形 |
| 50-1-2 | 50 | 50 | 2.9 | 1264 | 25 | 45 | 33.6 | 44.4 | PVC | 壓縮段雙螺紋 | |
| 50-1-3印條 | 35 | 35 | 3.3 | 840 | 24 | 29.6 | 21.8 | 31 | 標准形 | ||
| 50-2-1 | 50 | 50 | 3.5 | 1209 | 24 | 44.6 | 34.6 | 45.6 | 芯押14(50-2) | PE/PP | 標准形 |
| 50-2-2 | 50 | 50 | 3.7 | 1208 | 24 | 45 | 34.4 | 45.8 | 芯押13(50-2) | PE/PP | 標准形 |
| 50-2-3印條 | 32 | 32 | 2.9 | 486 | 15 | 26.2 | 21.6 | 28.4 | 標准形 | ||
| 50-2-4 | 50 | 49.5 | 3.4 | 1214 | 24 | 44.5 | 35 | 45.6 | 標准形 |
nuclear radiation - 核辐射,放射性辐射 (0) 投诉
P:2008-12-19 13:15:08
| 50-3-1 | 50 | 50 | 2.9 | 1213 | 24 | 45.1 | 36.6 | 45.4 | 標准形 | ||
| 65-1-1 | 65 | 64 | 1.4 | 1575 | 24 | 57 | 53.5 | 56.7 | PVC/LSNH/IRPE | 標准形 | |
| 65-1-2 | 65 | 64 | 1.4 | 1578 | 24 | 57 | 56.8 | 59 | 外被09(60標准) | PVC/LSNH/IRPE | 壓縮段雙螺紋 |
| 65-1-3 | 65 | 64 | 3.2 | 1572 | 24 | 56 | 49 | 60 | 外被10(60混練) | PE/PP | 計量段柱狀紋 |
| 65-1-4 | 65 | 66.3 | 3.1 | 1575 | 24 | 59.5 | 46.4 | 59 | PVC | 壓縮段雙螺紋,計量段斜花鍵形 | |
| 75-4-1 | 75 | 75 | 2.6 | 2115 | 28 | 65 | 60.6 | 69.4 | 外被03(70) | PVC | 標准形 |
| 75-4-2 | 75 | 69 | 3.4 | 2120 | 28 | 61 | 58 | 70 | 外被06(70標准) | PE/PP | 標准形 |
| 75-1-1 | 75 | 62 | 3.1 | 1950 | 26 | 55 | 60.3 | 70.2 | 外被14(75標准) | PVC | 標准形 |
| 75-1-2 | 75 | 68 | 1.5 | 1950 | 26 | 59 | 60 | 65 | 外被05(75標准) | LSNH/IRPE | 壓縮段雙螺紋,計量段花鍵形 |
| 75-1-3 | 75 | 74 | 2.9 | 1948 | 26 | 64.8 | 58 | 69.2 | 外被07(75標准 (雙螺紋) | PVC | 壓縮段雙螺紋 |
| 75-1-4 | 75 | 76 | 2.8 | 1950 | 26 | 68.4 | 58 | 69 | 壓縮段雙螺紋 | ||
| 75-1-5 | 75 | 75 | 2.8 | 1950 | 26 | 67.9 | 54.3 | 67.6 | 壓縮段雙螺紋,計量段花鍵形 | ||
| 75-1-6 | 75 | 75 | 3.0 | 1950 | 26 | 67.4 | 57 | 69 | 壓縮段雙螺紋 | ||
| 90-1-1 | 90 | 90 | 1.5 | 2340 | 26 | 78 | 69.2 | 76 | 雙螺紋 | LSNH/KYNAR | 壓縮段雙螺紋,計量段花鍵形 |
furnace - 炉,炉子 (0) 投诉
P:2008-12-19 13:15:28
| 90-1-2 | 90 | 92 | 3.0 | 2340 | 26 | 83.8 | 66.2 | 82 | 標准形 | ||
| 90-2-1 | 90 | 90 | 3.0 | 2262 | 25 | 80 | 72 | 84 | 混練 | PVC | 壓縮段花鍵形,計量段柱狀形 |
| 90-2-2 | 90 | 90 | 3.0 | 2262 | 25 | 80 | 72 | 84 | 外被01(90混練) | PVC | 壓縮段雙螺紋,計量段柱狀形 |
| 90-2-3 | 90 | 90 | 1.5 | 2260 | 25 | 81 | 75.3 | 80.5 | 標准形 | ||
| 45-2-1 | 45 | 45 | 2.1 | 1380 | 31 | 41 | 33.4 | 39.4 | B95465(45-2) | PE/PEF | 壓縮段雙螺紋,計量段鋸齒狀,雙螺紋 |
| 45-2-2 | 45 | 45 | 5.6 | 1380 | 31 | 41 | 28.2 | 42 | B95438(45-2) | PVC | 壓縮段雙螺紋,計量段鋸齒狀,圓螺母形 |
| 45-2-3 | 45 | 45 | 2.6 | 1380 | 31 | 40.7 | 36.6 | 41.8 | 壓縮段少半牙﹐計量段圓螺母形 | ||
| 45-30-1 | 30 | 30 | 2.0 | 754 | 25 | 28.3 | 20 | 25 | 芯押18 | Teflon | 壓縮段雙螺紋(45-2外層押出) |
| 45-30-2 | 30 | 30 | 2.0 | 756 | 25 | 28.6 | 20 | 25 | 壓縮段雙螺紋(45-2內層押出) | ||
| 45-30-3 | 30 | 30 | 2.7 | 760 | 25 | 26.3 | 22.4 | 27.2 | 9 | Teflon | 標准形(45-2外層押出) |
infra-red measuring instrument - 红外线测试仪 (0) 投诉
P:2008-12-19 13:16:27
| 押出機台基本參數表 | ||||||||||||||||
| 機臺 項目 | 給 線 | 給線儲線 | 收線儲線 | 卷取速度 | 軸裝 | 打卷 | 裁條 | 捅裝 | 押出轉速max | 主机設定轉速max | 引取設定轉速max | 空轉最高線速m/min | 目標線速m/min | |||
| 自動(Y/N) | 張力范圍(max) | 圈數 | 張力范圍(max) | 圈數 | 張力范圍(max) | rpm | Y/N | Y/N | Y/N | Y/N | ||||||
| 20-1 | Y | 1 | 150MM | 15 | 4A | 100 | Y | N | N | N | 40 | 999 | 999 | 138.5 | 100 | |
| 25-1 | Y | 4 | 570MM | 10 | 3A | 1800 | Y | N | N | N | 64.6 | 1468 | 1506 | 296.5 | 150 | |
| 30-1 | N | 21 | 3A | 1800 | Y | N | N | N | 124 | 1837 | 400 | 300 | 150 | |||
| 30-2 | Y | 3 | 砝碼(1~5kgf) | 12 | 5A | 1800 | Y | N | N | Y | 69.3 | 1736 | 817 | 610 | 350 | |
| 32-1 | Y | 3 | 600MM | 21 | 3A | 1800 | Y | N | N | Y | 110 | 1750 | 1137 | 330 | 350 | |
| 32-2 | Y | 3 | 600MM | 12 | 5A | 1800 | Y | N | N | N | 83.3 | 1469 | 1395 | 520 | 350 | |
| 35-1 | Y | 3 | 600MM | 14 | 3A | 1800 | Y | N | N | Y | 100 | 2000(2019) | 2000(1778) | 904 | 600 | |
| 45-1 | Y | 3 | 600MM | 4 | 70psi | Y | N | N | N | 95 | 2000(1706) | 2000(1725) | 905 | 600 | ||
| 45-2 | Y | 4 | 3 | Y | ||||||||||||
| 50-1 | Y | 3 | 600MM | 4 | 70psi | Y | N | N | N | 95 | 2000(1700) | 2000(1700) | 876 | 700 | ||
cable television - 电缆电视,有线电视 (0) 投诉
P:2008-12-19 13:16:48
| 50-2 | Y | 3 | 600MM | 15 | 5A | 1800 | Y | Y | N | Y | 100 | 1740 | 2000 | 700 | 600 | |
| 50-3 | Y | 3 | 砝碼(1~5kgf) | 12 | 5A | 1800 | Y | Y | N | Y | 99.6 | 1814 | 1646 | 723 | 600 | |
| 80-1 | Y | 7 | 7 | Y | ||||||||||||
| 60-1 | Y | 30V | 10 | 260 | 9 | 5A | 1800 | Y | Y | N | N | 80.6 | 1722 | 1482 | 172 | 140 |
| 70-1 | Y | 5A | 13 | 5A | 10 | 5A | 1800 | Y | Y | Y | N | 93 | 1739 | 1758 | 145 | 120 |
| 75-1 | Y | 5A | 7 | 5A | 7 | 5A | 1800 | Y | Y | Y | Y | 81.3 | 1743 | 1748 | 144 | 120 |
| 75-2 | Y | 5A | 7 | 5A | 7 | 5A | 1800 | Y | Y | N | Y | 80.5 | 1756 | 1745 | 143 | 120 |
| 75-3 | Y | 5A | 7 | 5A | 7 | 5A | 1800 | Y | Y | Y | Y | 50.6 | 1691 | 1742 | 197 | 130 |
| 90-1 | Y | 5A | 7 | 5A | 7 | 5A | 2000 | Y | Y | N | Y | 50 | 1750 | 1750 | 203 | 150 |
| 90-2 | Y | 30V | 9 | 1.5A | 1800 | Y | Y | N | N | |||||||
SFCE - Syndicat des Fils et Cable E'lectriques电线电缆协会(法国) (0) 投诉
P:2008-12-19 13:17:16
| 押 出 線 速 計 算 公 式 | |||||||||||||||||||
| 一 押出机馬力及押出量選取--一般文獻 | 二 結合實際用公式 | 三 從理論求各參數 | |||||||||||||||||
| 押出機螺桿直徑D | 25 | mm | 已知某線速Va | 43.3 | m/min | 螺杆直徑D | 25 | mm | |||||||||||
| 押出機螺桿直徑D | 0.98 | inch | 對應轉速Ra | 55.0 | RPM | 螺杆節距P' | 22.5 | mm | |||||||||||
| 押出機馬力--一般型 | 1.9 | HP | 欲求另一線速Vb下 | 50.5 | m/min | 計量段直徑D" | 23 | mm | |||||||||||
| 押出機馬力--加強型 | 2.9 | HP | 對應轉速Rb | 64.09 | RPM | 材料比重ρ | 2.13 | --- | |||||||||||
| 押出機流量--一般型 | 19.2 | LB/HR | 已知最大轉速RPMmax. | 64.6 | RPM | 押出機最大轉速N | 64.6 | rpm | |||||||||||
| 押出機流量--加強型 | 28.8 | LB/HR | 押出主機最高設定轉速 | 1468 | RPM | 押出有效效率ή | 30 | % | |||||||||||
| 押出機流量--一般型 | 8.7 | KG/HR | Va線速下對應主機設定轉速 | 1249.8 | RPM | 最大押出量Q | 4.03 | KG/HR | |||||||||||
| 押出機流量--加強型 | 13.1 | KG/HR | Vb線速下對應主機設定轉速 | 1456.3 | RPM | 線材所用材料單位重量 | 1.33 | KG/KM | |||||||||||
| 線材所用材料單位重量 | 1.33 | KG/KM | 已知線材所用材料單位重量 | 1.33 | KG/KM | 則線材可達最大線速 | 50.5 | m/min | |||||||||||
| 押出該線材最高線速--一般型 | 109.5 | m/min | 則Vb速度下的押出量為 | 4.03 | KG/HR | 欲求某線速下 | 50.2 | m/min | |||||||||||
| 押出該線材最高線速--加強型 | 164.2 | m/min | 黃底和藍底需要填數據 | 對應轉速 | 64.27 | rpm | |||||||||||||
| 理論押出量QT及實際押出量QR | |||||||||||||||||||
| ή=QR/QT (30~50%) | |||||||||||||||||||
| QT=υ0*N*ρ*60*10-6(Kg/Hr) | |||||||||||||||||||
| υ0=3.14159*hm*D"*P' | |||||||||||||||||||
| 本例以RF CABLE OD1.8 28AWG*1C芯押為例進行解說,理論與實際進行比較 | |||||||||||||||||||
earth bus - 接地母线 (0) 投诉
P:2008-12-19 13:18:00
| 押出機螺桿直徑D | 30 | mm | 已知某線速Va | 42.0 | m/min | 螺杆直徑D | 30 | mm | |||||||||||
| 押出機螺桿直徑D | 1.18 | inch | 對應轉速Ra | 16.0 | RPM | 螺杆節距P' | 27 | mm | |||||||||||
| 押出機馬力--一般型 | 3.0 | HP | 欲求另一線速Vb下 | 60 | m/min | 計量段直徑D" | 26.8 | mm | |||||||||||
| 押出機馬力--加強型 | 4.5 | HP | 對應轉速Rb | 22.86 | RPM | 材料比重ρ | 2.13 | --- | |||||||||||
| 押出機流量--一般型 | 30.3 | LB/HR | 已知最大轉速RPMmax. | 124.0 | RPM | 押出機最大轉速N | 124 | rpm | |||||||||||
| 押出機流量--加強型 | 45.5 | LB/HR | 押出主機最高設定轉速 | 1837 | RPM | 押出有效效率ή | 32 | % | |||||||||||
| 押出機流量--一般型 | 13.8 | KG/HR | Va線速下對應主機設定轉速 | 237.0 | RPM | 最大押出量Q | 18.44 | KG/HR | |||||||||||
| 押出機流量--加強型 | 20.7 | KG/HR | Vb線速下對應主機設定轉速 | 338.6 | RPM | 線材所用材料單位重量 | 0.96 | KG/KM | |||||||||||
| 線材所用材料單位重量 | 0.96 | KG/KM | 已知線材所用材料單位重量 | 0.96 | KG/KM | 則線材可達最大線速 | 320.2 | m/min | |||||||||||
| 押出該線材最高線速--一般型 | 239.3 | m/min | 則Vb速度下的押出量為 | 3.46 | KG/HR | 欲求某線速下 | 60 | m/min | |||||||||||
| 押出該線材最高線速--加強型 | 358.9 | m/min | 黃底和藍底需要填數據 | 對應轉速 | 23.23 | rpm | |||||||||||||
| 本例以RF CABLE OD1.13 32AWG*1C芯押為例進行解說,理論與實際進行比較 | |||||||||||||||||||
electric wire - 电线,导线 (0) 投诉
P:2008-12-19 13:19:01
| 押出機螺桿直徑D | 75 | mm | 已知某線速Va | 52.0 | m/min | 螺杆直徑D | 75 | mm | |||||||||||
| 押出機螺桿直徑D | 2.95 | inch | 對應轉速Ra | 14.8 | RPM | 螺杆節距P' | 67.5 | mm | |||||||||||
| 押出機馬力--一般型 | 30.0 | HP | 欲求另一線速Vb下 | 120 | m/min | 計量段直徑D" | 69 | mm | |||||||||||
| 押出機馬力--加強型 | 44.9 | HP | 對應轉速Rb | 34.15 | RPM | 材料比重ρ | 1.38 | --- | |||||||||||
| 押出機流量--一般型 | 299.6 | LB/HR | 已知最大轉速RPMmax. | 81.3 | RPM | 押出機最大轉速N | 81.3 | rpm | |||||||||||
| 押出機流量--加強型 | 449.5 | LB/HR | 押出主機最高設定轉速 | 1743 | RPM | 押出有效效率ή | 35 | % | |||||||||||
| 押出機流量--一般型 | 136.2 | KG/HR | Va線速下對應主機設定轉速 | 317.3 | RPM | 最大押出量Q | 103.42 | KG/HR | |||||||||||
| 押出機流量--加強型 | 204.3 | KG/HR | Vb線速下對應主機設定轉速 | 732.2 | RPM | 線材所用材料單位重量 | 6.32 | KG/KM | |||||||||||
| 線材所用材料單位重量 | 6.32 | KG/KM | 已知線材所用材料單位重量 | 6.32 | KG/KM | 則線材可達最大線速 | 272.7 | m/min | |||||||||||
| 押出該線材最高線速--一般型 | 359.2 | m/min | 則Vb速度下的押出量為 | 45.504 | KG/HR | 欲求某線速下 | 60 | m/min | |||||||||||
| 押出該線材最高線速--加強型 | 538.8 | m/min | 黃底和藍底需要填數據 | 對應轉速 | 17.89 | rpm | |||||||||||||
| 本例以UL2725 CABLE OD:3.0 28AWG*2C被覆押出為例進行解說,理論與實際進行比較 | |||||||||||||||||||
portable wire temperature meter - 携带式线材温度测量仪 (0) 投诉
P:2008-12-19 13:19:29
| 押出機螺桿直徑D | 75 | mm | 已知某線速Va | 60.0 | m/min | 螺杆直徑D | 75 | mm | |||||||||||
| 押出機螺桿直徑D | 2.95 | inch | 對應轉速Ra | 40.0 | RPM | 螺杆節距P' | 68.5 | mm | |||||||||||
| 押出機馬力--加強型 | 44.9 | HP | 對應轉速Rb | 80.00 | RPM | 材料比重ρ | 1.38 | --- | |||||||||||
| 押出機流量--一般型 | 299.6 | LB/HR | 已知最大轉速RPMmax. | 80.5 | RPM | 押出機最大轉速N | 80.6 | rpm | |||||||||||
| 押出機流量--加強型 | 449.5 | LB/HR | 押出主機最高設定轉速 | 1691 | RPM | 押出有效效率ή | 40 | % | |||||||||||
| 押出機流量--一般型 | 136.2 | KG/HR | Va線速下對應主機設定轉速 | 840.2 | RPM | 最大押出量Q | 118.91 | KG/HR | |||||||||||
| 押出機流量--加強型 | 204.3 | KG/HR | Vb線速下對應主機設定轉速 | 1680.5 | RPM | 線材所用材料單位重量 | 17.42 | KG/KM | |||||||||||
| 線材所用材料單位重量 | 17.42 | KG/KM | 已知線材所用材料單位重量 | 17.42 | KG/KM | 則線材可達最大線速 | 113.8 | m/min | |||||||||||
| 押出該線材最高線速--一般型 | 130.3 | m/min | 則Vb速度下的押出量為 | 125.424 | KG/HR | 欲求某線速下 | 60 | m/min | |||||||||||
| 押出該線材最高線速--加強型 | 195.5 | m/min | 黃底和藍底需要填數據 | 對應轉速 | 42.51 | rpm | |||||||||||||
| 本例以HDMI CABLE 31AWG*(4P+7C)被覆押出為例進行解說,理論與實際進行比較 | |||||||||||||||||||
mast - 电杆,电线杆,天线杆,杆塔 (0) 投诉
P:2008-12-19 13:20:06
| 押出機螺桿直徑D | 75 | mm | 已知某線速Va | 80.0 | m/min | 螺杆直徑D | 75 | mm | |||||||||||
| 押出機螺桿直徑D | 2.95 | inch | 對應轉速Ra | 45.0 | RPM | 螺杆節距P' | 67.5 | mm | |||||||||||
| 押出機馬力--一般型 | 30.0 | HP | 欲求另一線速Vb下 | 150 | m/min | 計量段直徑D" | 69 | mm | |||||||||||
| 押出機馬力--加強型 | 44.9 | HP | 對應轉速Rb | 84.38 | RPM | 材料比重ρ | 1.35 | --- | |||||||||||
| 押出機流量--一般型 | 299.6 | LB/HR | 已知最大轉速RPMmax. | 50.6 | RPM | 押出機最大轉速N | 50.6 | rpm | |||||||||||
| 押出機流量--加強型 | 449.5 | LB/HR | 押出主機最高設定轉速 | 1691 | RPM | 押出有效效率ή | 35 | % | |||||||||||
| 押出機流量--一般型 | 136.2 | KG/HR | Va線速下對應主機設定轉速 | 1503.9 | RPM | 最大押出量Q | 62.97 | KG/HR | |||||||||||
| 押出機流量--加強型 | 204.3 | KG/HR | Vb線速下對應主機設定轉速 | 2819.7 | RPM | 線材所用材料單位重量 | 11.74 | KG/KM | |||||||||||
| 線材所用材料單位重量 | 19.41 | KG/KM | 已知線材所用材料單位重量 | 19.41 | KG/KM | 則線材可達最大線速 | 89.4 | m/min | |||||||||||
| 押出該線材最高線速--一般型 | 116.9 | m/min | 則Vb速度下的押出量為 | 174.69 | KG/HR | 欲求某線速下 | 80 | m/min | |||||||||||
| 押出該線材最高線速--加強型 | 175.4 | m/min | 黃底和藍底需要填數據 | 對應轉速 | 45.28 | rpm | |||||||||||||
| 本例以USB CABLE OD4.8 28AWG*1P+24AWG*2C被覆押出為例進行解說,理論與實際進行比較 | |||||||||||||||||||
floor model extruder - 地板移动式挤出机(底座装有滚轮) (0) 投诉
P:2008-12-19 13:20:54
| 押出機螺桿直徑D | 90 | mm | 已知某線速Va | 100.0 | m/min | 螺杆直徑D | 90 | mm | |||||||||||
| 押出機螺桿直徑D | 3.54 | inch | 對應轉速Ra | 48.0 | RPM | 螺杆節距P' | 80 | mm | |||||||||||
| 押出機馬力--一般型 | 47.3 | HP | 欲求另一線速Vb下 | 80 | m/min | 計量段直徑D" | 84 | mm | |||||||||||
| 押出機馬力--加強型 | 70.9 | HP | 對應轉速Rb | 38.40 | RPM | 材料比重ρ | 1.35 | --- | |||||||||||
| 押出機流量--一般型 | 472.7 | LB/HR | 已知最大轉速RPMmax. | 50.0 | RPM | 押出機最大轉速N | 50.6 | rpm | |||||||||||
| 押出機流量--加強型 | 709.0 | LB/HR | 押出主機最高設定轉速 | 1750 | RPM | 押出有效效率ή | 40 | % | |||||||||||
| 押出機流量--一般型 | 214.8 | KG/HR | Va線速下對應主機設定轉速 | 1680.0 | RPM | 最大押出量Q | 103.83 | KG/HR | |||||||||||
| 押出機流量--加強型 | 322.3 | KG/HR | Vb線速下對應主機設定轉速 | 1344.0 | RPM | 線材所用材料單位重量 | 16.40 | KG/KM | |||||||||||
| 線材所用材料單位重量 | 16.40 | KG/KM | 已知線材所用材料單位重量 | 16.4 | KG/KM | 則線材可達最大線速 | 105.5 | m/min | |||||||||||
| 押出該線材最高線速--一般型 | 218.3 | m/min | 則Vb速度下的押出量為 | 78.72 | KG/HR | 欲求某線速下 | 100 | m/min | |||||||||||
| 押出該線材最高線速--加強型 | 327.5 | m/min | 黃底和藍底需要填數據 | 對應轉速 | 47.95 | rpm | |||||||||||||
| 本例以USB CABLE OD4.4 28AWG*1P+26AWG*2C被覆押出為例進行解說,理論與實際進行比較 | |||||||||||||||||||
pin-hole tester - 针孔试验器 (0) 投诉
35
不错! 最好上传公式。
