[技术资料] 常用塑料英语缩略语
P:2009-01-18 10:39:28
常用塑料英语缩略语
英文简称 | 英文全称 | 中文全称 |
Acrylonitrile-butadiene-acrylate | 丙烯腈/丁二烯/丙烯酸酯共聚物 | |
ABS | Acrylonitrile-butadiene-styrene | 丙烯腈/丁二烯/苯乙烯共聚物 |
AES | Acrylonitrile-ethylene-styrene | 丙烯腈/乙烯/苯乙烯共聚物 |
AMMA | Acrylonitrile/methyl Methacrylate | 丙烯腈/甲基丙烯酸甲酯共聚物 |
ARP | Aromatic polyester | 聚芳香酯 |
AS | Acrylonitrile-styrene resin | 丙烯腈-苯乙烯树脂 |
ASA | Acrylonitrile-styrene-acrylate | 丙烯腈/苯乙烯/丙烯酸酯共聚物 |
CA | Cellulose acetate | 醋酸纤维塑料 |
CAB | Cellulose acetate butyrate | 醋酸-丁酸纤维素塑料 |
CAP | Cellulose acetate propionate | 醋酸-丙酸纤维素 |
CE | Cellulose plastics (general) | 通用纤维素塑料 |
CF | Cresol-formaldehyde | 甲酚-甲醛树脂 |
CMC | Carboxymethyl cellulose | 羧甲基纤维素 |
CN | Cellulose nitrate | 硝酸纤维素 |
CP | Cellulose propionate | 丙酸纤维素 |
CPE | Chlorinated polyethylene | 氯化聚乙烯 |
CPVC | Chlorinated poly(vinyl chloride) | 氯化聚氯乙烯 |
CS | Casein | 酪蛋白 |
CTA | Cellulose triacetate | 三醋酸纤维素 |
two-highrolling stand - 双辊机架 (0) 投诉
P:2009-01-18 10:40:13
EC | Ethyl cellulose | 乙烷纤维素 |
EMA | Ethylene/methacrylic acid | 乙烯/甲基丙烯酸共聚物 |
EP | Epoxy, epoxide | 环氧树脂 |
EPD | Ethylene-propylene-diene | 乙烯-丙烯-二烯三元共聚物 |
EPM | Ethylene-propylene polymer | 乙烯-丙烯共聚物 |
EPS | Expanded polystyrene | 发泡聚苯乙烯 |
ETFE | Ethylene-tetrafluoroethylene | 乙烯-四氟乙烯共聚物 |
EVA | Ethylene/vinyl acetate | 乙烯-醋酸乙烯共聚物 |
EVAL | Ethylene-vinyl alcohol | 乙烯-乙烯醇共聚物 |
FEP | Perfluoro(ethylene-propylene) | 全氟(乙烯-丙烯)塑料 |
FF | Furan formaldehyde | 呋喃甲醛 |
HDPE | High-density polyethylene plastics | 高密度聚乙烯塑料 |
HIPS | High impact polystyrene | 高冲聚苯乙烯 |
IPS | Impact-resistant polystyrene | 耐冲击聚苯乙烯 |
LCP | Liquid crystal polymer | 液晶聚合物 |
LDPE | Low-density polyethylene plastics | 低密度聚乙烯塑料 |
LLDPE | Linear low-density polyethylene | 线性低密聚乙烯 |
LMDPE | Linear medium-density polyethylene | 线性中密聚乙烯 |
MBS | Methacrylate-butadiene-styrene | 甲基丙烯酸 |
MC | Methyl cellulose | 丁二烯-苯乙烯共聚物 |
MDPE | Medium-density polyethylene | 中密聚乙烯 |
MF | Melamine-formaldehyde resin | 密胺-甲醛树脂 |
MPF | Melamine/phenol-formaldehyde | 密胺/酚醛树脂 |
PA | Polyamide (nylon) | 聚酰胺(尼龙) |
production department - 生产科,生产车间 (0) 投诉
P:2009-01-18 10:41:07
PAA | Poly(acrylic acid) | 聚丙烯酸 |
PADC | Poly(allyl diglycol carbonate) | 碳酸-二乙二醇酯· 烯丙醇酯树脂 |
PAE | Polyarylether | 聚芳醚 |
PAEK | Polyaryletherketone | 聚芳醚酮 |
PAI | Polyamide-imide | 聚酰胺-酰亚胺 |
PAK | Polyester alkyd | 聚酯树脂 |
PAN | Polyacrylonitrile | 聚丙烯腈 |
Polyaryl amide | 聚芳酰胺 | |
PASU | Polyarylsulfone | 聚芳砜 |
PAT | Polyarylate | 聚芳酯 |
PAUR | Poly(ester urethane) | 聚酯型聚氨酯 |
PB | Polybutene-1 | 聚丁烯-[1] |
PBA | Poly(butyl acrylate) | 聚丙烯酸丁酯 |
PBAN | Polybutadiene-acrylonitrile | 聚丁二烯-丙烯腈 |
PBS | Polybutadiene-styrene | 聚丁二烯-苯乙烯 |
PBT | Poly(butylene terephthalate) | 聚对苯二酸丁二酯 |
PC | Polycarbonate | 聚碳酸酯 |
PCTFE | Polychlorotrifluoroethylene | 聚氯三氟乙烯 |
muscovite mica paper - 白云母纸 (0) 投诉
P:2009-01-18 10:41:33
PDAP | Poly(diallyl phthalate) | 聚对苯二甲酸二烯丙酯 |
PE | Polyethylene | 聚乙烯 |
PEBA | Polyether block amide | 聚醚嵌段酰胺 |
PEBA | Thermoplastic elastomer polyether | 聚酯热塑弹性体 |
PEEK | Polyetheretherketone | 聚醚醚酮 |
Poly(etherimide) | 聚醚酰亚胺 | |
PEK | Polyether ketone | 聚醚酮 |
PEO | Poly(ethylene oxide) | 聚环氧乙烷 |
PES | Poly(ether sulfone) | 聚醚砜 |
PET | Poly(ethylene terephthalate) | 聚对苯二甲酸乙二酯 |
PETG | Poly(ethylene terephthalate) glycol | 二醇类改性PET |
PEUR | Poly(ether urethane) | 聚醚型聚氨酯 |
PF | Phenol-formaldehyde resin | 酚醛树脂 |
PFA | Perfluoro(alkoxy alkane) | 全氟烷氧基树脂 |
PFF | Phenol-furfural resin | 酚呋喃树脂 |
PI | Polyimide | 聚酰亚胺 |
PIB | Polyisobutylene | 聚异丁烯 |
PISU | Polyimidesulfone | 聚酰亚胺砜 |
PMCA | PMCA Poly(methyl-alpha-chloroacrylate) | 聚α-氯代丙烯酸甲酯 |
PMMA | Poly(methyl methacrylate) | 聚甲基丙烯酸甲酯 |
PMP | Poly(4-methylpentene-1) | 聚4-甲基戊烯-1 |
PMS | Poly(alpha-methylstyrene) | 聚α-甲基苯乙烯 |
POM | Polyoxymethylene, polyacetal | 聚甲醛 |
PP | Polypropylene | 聚丙烯 |
PPA | Polyphthalamide | 聚邻苯二甲酰胺 |
PPE | Poly(phenylene ether) | 聚苯醚 |
PPO | Poly(phenylene oxide) deprecated | 聚苯醚 |
crusher - 破碎机 (0) 投诉
P:2009-01-18 10:41:56
PPOX | Poly(propylene oxide) | 聚环氧(丙)烷 |
PPS | Poly(phenylene sulfide) | 聚苯硫醚 |
PPSU | Poly(phenylene sulfone) | 聚苯砜 |
PS | Polystyrene | 聚苯乙烯 |
PSU | Polysulfone | 聚砜 |
PTFE | Polytetrafluoroethylene | 聚四氟乙烯 |
PUR | Polyurethane | 聚氨酯 |
PVAC | Poly(vinyl acetate) | 聚醋酸乙烯 |
PVAL | Poly(vinyl alcohol) | 聚乙烯醇 |
PVB | Poly(vinyl butyral) | 聚乙烯醇缩丁醛 |
PVC | Poly(vinyl chloride) | 聚氯乙烯 |
PVCA | Poly(vinyl chloride-acetate) | 聚氯乙烯醋酸乙烯酯 |
PVDC | Poly(vinylidene chloride) | 聚(偏二氯乙烯) |
PVDF | Poly(vinylidene fluoride) | 聚(偏二氟乙烯) |
PVF | Poly(vinyl fluoride) | 聚氟乙烯 |
PVFM | Poly(vinyl formal) | 聚乙烯醇缩甲醛 |
PVK | Polyvinylcarbazole | 聚乙烯咔唑 |
PVP | Polyvinylpyrrolidone | 聚乙烯吡咯烷酮 |
S/MA | Styrene-maleic anhydride plastic | 苯乙烯-马来酐塑料 |
SAN | Styrene-acrylonitrile plastic | 苯乙烯-丙烯腈塑料 |
SB | Styrene-butadiene plastic | 苯乙烯-丁二烯塑料 |
Si | Silicone plastics | 有机硅塑料 |
SMS | Styrene/alpha-methylstyrene plastic | 苯乙烯-α-甲基苯乙烯塑料 |
SP | Saturated polyester plastic | 饱和聚酯塑料 |
single superfine wire-drawing machine - 单头微拉机 (0) 投诉
P:2009-01-18 10:42:13
SRP | Styrene-rubber plastics | 聚苯乙烯橡胶改性塑料 |
TEEE | Thermoplastic Elastomer,Ether-Ester | 醚酯型热塑弹性体 |
TEO | Thermoplastic Elastomer, Olefinic | 聚烯烃热塑弹性体 |
TES | Thermoplastic Elastomer, Styrenic | 苯乙烯热塑性弹性体 |
TPEL | Thermoplastic elastomer | 热塑(性)弹性体 |
TPES | Thermoplastic polyester | 热塑性聚酯 |
TPUR | Thermoplastic polyurethane | 热塑性聚氨酯 |
TSUR | Thermoset polyurethane | 热固聚氨酯 |
UF | Urea-formaldehyde resin | 脲甲醛树脂 |
UHMWPE | Ultra-high molecular weight PE | 超高分子量聚乙烯 |
UP | Unsaturated polyester | 不饱和聚酯 |
VCE | Vinyl chloride-ethylene resin | 氯乙烯/乙烯树脂 |
VCEV | Vinyl chloride-ethylene-vinyl | 氯乙烯/乙烯/醋酸乙烯共聚物 |
VCMA | Vinyl chloride-methyl acrylate | 氯乙烯/丙烯酸甲酯共聚物 |
VCMMA | Vinyl chloride-methylmethacrylate | 氯乙烯/甲基丙烯酸甲酯共聚物 |
VCOA | Vinyl chloride-octyl acrylate resin | 氯乙烯/丙烯酸辛酯树脂 |
VCVAC | Vinyl chloride-vinyl acetate resin | 氯乙烯/醋酸乙烯树脂 |
VCVDC | Vinyl chloride-vinylidene chloride | 氯乙烯/偏氯乙烯共聚物 |
messenger - 承拉构件,支承件,支承元件 (0) 投诉
