[问题求助] 怎样识别AWG规格 以及线规?
P:2008-11-24 10:26:46
怎样识别AWG规格以及线规(例如5 12   和5 10) ?
MMA - methylmalonic acid甲基丙二酸 (0) 投诉
P:2008-11-24 10:33:25
AWG为美国线规
26AWG   0.348-0.432mm
24AWG   0.485-0.546mm
23AWG   0.546-0.610mm
22AWG   0.61-mm
highly-extended compound - 高填充胶料 (0) 投诉
P:2008-11-24 13:32:02
横截面不同
foam skin tandem telephone core insulation line - 串列式话缆线芯泡沫皮绝缘生产线 (0) 投诉
P:2008-11-24 14:17:14
线规标准
aluminium alloy conductor,steel-reinforced - 钢芯铝合金绞线 (0) 投诉
P:2008-11-25 16:33:47
补发附件
client layer - 客户层 (0) 投诉
P:2008-12-05 14:42:53
參考一下   常用线规号码与线径对照表
<DIV align=center>
线规
SWG
BWG
BG
AWG
号码
英寸
毫米
英寸
毫米
英寸
毫米
英寸
毫米
7/0
17
18
19
20
21
22
23
24
25
26
0.500
12.700
0.6666
16.932
。0808
</DIV>
optic access network - 光接入网 (0) 投诉
P:2008-12-05 14:43:36
參考一下   常用线规号码与线径对照表
<DIV align=center>
线规
SWG
BWG
BG
AWG
号码
英寸
毫米
英寸
毫米
英寸
毫米
英寸
毫米
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
O.0164
O
.0149
O
.0136
O
.0124
O
.0116
O
.0109
O
.0100
O
.0092
O
.0084
O
.0076
O
.0068
O
.0052
O
.0048
O
.0044
O
.0040
O
.0036
O
.0032
O
.0028
O
.0024
O
.0020
O
.0016
O
。0012
O
.0010
O.417
O
.376
O
.345
O
.315
O
.295
O
.274
O
.254
O
.234
O
.213
O
.193
O
.173
O
.152
O
.132
O
.122
O
.112
O
.091
O
.081
O
.071
O
.061
O
.051
O
.041
O
.030
O
.025
O.016
O
.014
O
.013
O
.012
O
.010
O
.009
O
.008
O
.005
O
.004
O.406
O
.356
O
.305
O
.254
O
.229
O
.203
O
.127
O
.102
O.1745
O
.01390
O
.01230
O
.01100
O
.00980
O
.00870
O
.00770
O
.00690
O
.00610
O
.00540
O
.00480
O
.00430
O
.00386
O
.00343
O
.00306
O
.00272
O
.00242
O
.00215
O
.00192
O
.00170
O
.00152
O
.00135
O
.00120
O.443
O
.397
O
.353
O
.312
O
.249
O
.221
O
.196
O
.175
O
.155
O
.137
O
.122
O
.109
O
.087
O
.078
O
.069
O
.061
O
.055
O
.049
O
.043
O
.039
O
.034
O
.030
O.01420
O
.01264
O
.01126
O
.01003
O
.00893
O
.00795
O
.00708
O
.00630
O
.00561
O
.00500
O
.00445
O
.00353
O
.00314
O
.00280
O
.00249
O
.00222
O
.00198
O
.00176
O
.00157
O
.00140
O
.00124
O
.00111
O
.00099
O.361
O
.321
O
.286
O
.227
O
.202
O
.180
O
.160
O
.143
O
.127
O
.113
O
.101
O
.090
O
.080
O
.071
O
.056
O
.050
O
.048
O
.035
O
.032
O
.028
O
</DIV>
vernier - 游尺,游标,游标尺 (0) 投诉
