[同轴电缆] RG系列国外标准
P:2008-11-15 10:50:13
RG系列国外标准
产品描述:RG系列编织网通讯电缆RG系列编织网同轴电缆,内导体为单根或多股无氧铜线或镀锡铜丝,PE塑料绝缘,外导体为镀锡铜丝、铝镁合金丝或裸铜线高密度的单或双层编织,外层为PVC或PE塑料绝缘护套。RG系列通讯电缆各性能指标均按国家标准生产及命名。它广泛用于宽带网络传输数据、电视、电话和计算机通讯、仪表的连接传输,射频及视频信号的传输。网上发布仅为我司部分产品,若您有合作意向,欢迎您拨打电话与我们联系!
Product description: RG series weaving Netcom hearing RG series cable knit network of coaxial cable, with conductor for a single unit or oxygen-free copper or tin copper wire line, PE plastic insulation, the outer conductor for the copper wire tin, aluminum-magnesium alloy or bare wire Copper high-density single-or double-weaving, for the outer layer of PE or PVC plastic insulating sheath. RG series of communications cables are indicators of the performance of national standards of production and names. It is widely used in broadband data transmission, television, telephone and computer communications, instrumentation transmission links, radio and video transmission. I just posted some of the Secretary, if you have intentions to cooperate, welcome to call us!
overlapping coefficient - 重叠率 (0) 投诉
P:2009-08-05 11:15:09
收藏了
pay-off frame - 放线架,放线框 (0) 投诉
P:2009-10-10 16:29:34
got it
restringing - 更换导线 (0) 投诉
P:2009-12-03 10:13:58
这什么啊
wet wiredrawing - 湿式拉线 (0) 投诉
P:2009-12-03 11:26:35
让人学英语了
condition - 条件,状况 (0) 投诉
P:2009-12-03 13:46:40
拿分的DDDDD
JCTA - Japan Cable Television Association日本有线电视协会 (0) 投诉
P:2010-04-01 11:42:00
学习大了
effective cross-sectional - 有效截面 (0) 投诉
P:2010-04-01 11:43:56
怎么没有了?
sealpeth sheath - 聚乙烯密封护套 (0) 投诉
P:2010-04-06 08:53:13
做广告的!
filler string - 填芯绳,电缆填芯绳 (0) 投诉
P:2010-07-12 12:22:10
学习了
cable tube - 电缆管道,电缆地下管道 (0) 投诉
P:2010-10-09 15:27:41
什么单位的?
master-slave D-flip-flop - 主从D型触发器 (0) 投诉
P:2011-01-11 15:33:44
将前面的翻译在后面,这样也有分
THW - UL 规格建筑用线最常用者,耐热、防潮、耐燃,使用温度 75℃,电压 600V,导体尺寸范围 AWG#14~1000MCM。 (0) 投诉
P:2011-01-12 08:41:45
垃圾广告
POF - polyethylene-sheath oil-filled聚乙烯护套充油(电缆) (0) 投诉
