[射频电缆] SYWY(V)-75中国标准
P:2008-11-15 10:42:29
中国标准:
China Standard:
产品描述:SYWV(Y)-75系列物理高发泡聚乙烯绝缘电缆
SYWV(Y)-75型聚乙烯物理高发泡电缆是一种具有很低损耗的电缆,它是通过气体注入使介质发泡,选择适当的工艺参数使得形成很小的互相封闭的气孔,这种介质不易老化,不易受潮。
电缆内导体有纯铜线、铜包钢、铜包铝,外导体为铝塑复合带加镀锡铜线、裸铜线、铝镁合金线编织,介质和内导体相互牢固结合,当温度变化或电缆受拉压时,介质与导体之间不会发生相互移动。
SYWV(Y)-75型电缆的衰减比同尺寸的其它射频电缆小,它用于CATV闭路电视系统、传输高频和超高频信号,亦可用于数据传输网络,进行数据传输。
Product description:
SYWV (Y) -75 series of high physical polyethylene foam insulation cable. SYWV (Y) -75-high polyethylene foam physical cable is a very low-loss cables, it is through the media so that the gas injected foam, select the appropriate process parameters allow each other to form a small closed pores, which Media aging is not easy, not easy to damp.
With a pure copper conductor cable line, copper clad steel, copper clad Aluminum, aluminum-plastic composite outer conductor for the increase in tin with copper, bare copper wire, aluminum-magnesium alloy wire weaving, medium and conductor with a strong combination with each other, when the temperature changes Or by cable tension and compression, media and the conductor does not occur between each move.
SYWV (Y) -75 cable attenuation than with the size of other small radio-frequency cables, closed-circuit television system for CATV, high-frequency transmission, and ultra-high frequency signal can also be used for data transmission network for data transmission. If you have intentions to cooperate, welcome to call us!
http://albertandsun.blog.china.alibaba.com
http://hi.baidu.com/albertandsun
http://albertandsun.blog.tianya.cn/
http://sunbo0320.blog.163.com/
secondary heat bonding roller - 二次加热粘接辊 (0) 投诉
