首页 > 电气装备用线缆
[问题求助] 请问,DCHH是什么电缆?
P:2008-12-29 11:34:32
43芯电缆,
<DIV style="mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: center; mso-element-top: .05pt; mso-height-rule: exactly"><DIV style="mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: center; mso-element-top: .05pt; mso-height-rule: exactly">适用于交流额定电压750V铁路电力机车重联用。电缆长期工作温度不超过 |
diameter quick changing system - 直径快速转换系统 (0) 投诉
