[问题求助] 求高手告之以下电缆是什么类型的电缆?
P:2008-11-05 14:11:04
<DIV>1.RG8 with copper, multiple strand</DIV><DIV>Specification : 7*0.75mm BC + SOLID PE 7.25MM + 7*24/0.15MM BC + PVC JACKET 10.30MM</DIV><DIV> </DIV><DIV>
2.RG58 with copper, multiple strand</DIV><DIV>Specification : 19*0.18mm BC + SOLID PE 2.95MM + 7*16/0.12MM BC + PVC JACKET 4.95MM</DIV><DIV> </DIV><DIV>
3.RG11 copper</DIV><DIV>Specification : 1.63mm BC + FOAM PE 7.11MM + AL/PET BONDED FOIL +6*16/0.16MM AL + PVC JACKET 10.10MM</DIV><DIV> </DIV><DIV>
4. RG6 ECONOMIC TYPE</DIV><DIV><DIV>Specification : 1.02mm CCS 15% CONDUCTIVITY + FOAM PE 4.80MM + AL/PET FOIL +3*16/0.12MM AL + PVC JACKET 6.80MM</DIV></DIV><DIV>
</DIV>
free inner wire-end - 外露内线端<收线盘的> (0) 投诉
P:2008-11-05 14:13:56
同轴线啊
trailing edge - 后缘(螺杆螺纹的) (0) 投诉
P:2008-11-05 17:07:25
具体的规格是什么啊?上面的专业术语不是很懂.
oil-filled cable - 充油电缆 (0) 投诉
P:2008-11-06 13:04:32
 1.)  7*0.75mm 铜内导体7.25MM 实心PE绝缘,  7*24/0.15MM铜编织,10.30MMPVC 护套       ??????????????
glass fibre waveguide - 玻璃纤维波导管 (0) 投诉
P:2008-11-19 18:29:25
你问的是什么意思呀,说明白点啊
magneto-strictive rotating nickel stack - 磁致伸缩的旋转镍管(拉线模重磨装置的) (0) 投诉
P:2008-11-19 18:30:38
这不就是同轴电缆吗
domestic news - 国内新闻 (0) 投诉
P:2008-12-10 11:41:25
是同轴线,结构也告诉你了
SMUX - synchronous multiplexers同步复接器,同步复用器 (0) 投诉
