[同轴电缆] 美国客户的要求过分吗
P:2008-10-30 20:48:39
弟兄门,帮我看看衰减指标能实现吗?指标该定多少?
RG59
CONDUCTOR:
AWG 20
Stranding: Solid
Conductor Diameter: .032 in.
Conductor Material:  BCCS - Bare Copper Covered Steel
INSULATION:
Insulation Material: Gas-injected FPE - Foam Polyethylene
Insulation Diameter: .144 in.
Bonded Aluminum Foil-Polyester Tape-AluminumFoil 100%
Braid AL - Aluminum 40%
OVERALL NOMINAL DIAMETER:
Overall Nominal Diameter: .237 in.
MECHANICAL CHARACTERISTICS:
Operating Temperature Range: -40°C To +80°C
Max. Recommended Pulling Tension: 80 lbs.
APPLICABLE SPECIFICATIONS AND AGENCY COMPLIANCE:
APPLICABLE STANDARDS:
NEC/(UL) Specification CATV, CM
CEC/C(UL) Specification CM
ELECTRICAL CHARACTERISTICS:
Nom. Characteristic Impedance 75 +/- 3 Ohms
Nom. Inductance .097 µH/ft
Nom. Capacitance Conductor to Shield 16.2 pF/ft
Nominal Velocity of Propagation 83 %
Nominal Delay 1.2 ns/ft
Nom. Conductor DC Resistance @ 20 Deg. C 44.5 Ohms/1000 ft
Nominal Outer Shield DC Resistance @ 20 Deg.C 17 Ohms/1000 ft
Nom. Attenuation :
Description Frequency (MHz)                                  Nom. Attenuation (dB/100 ft.)
5        0.8
55        1.8
211        3.4
500        5.2
750        6.5
862        7.0
1000        7.7
1450        9.3
1800        10.3
2250        11.9
super-broadband leaky coaxial cable - 超带宽漏泄同轴电缆 (0) 投诉
P:2008-10-30 21:37:12
理论上有点难﹐做到衰减12.5还可以
[cuijiude 在 2008-10-30 21:38:15 编辑过]
integrity of welded joint - 焊接接头整体性 (0) 投诉
P:2008-10-31 09:05:30
楼上的大虾,指点一下吧.
谢谢
wearability - 耐磨性 (0) 投诉
P:2008-10-31 09:59:17
楼主你确认它的单位为100ft?
abrasion resistance tester - 耐磨试验机 (0) 投诉
P:2008-10-31 13:01:44
控制好点的话,还是可以达得到的,关键是导体直径稳定性和发泡材料的选用上,还有就是铝箔中铝的厚度适当加厚一些。
test for separation of cores - (绝缘)线芯分离试验 (0) 投诉
P:2008-10-31 13:20:32
5MHZ 小于3.9/100m,1000MHZ 小于27/100M保守
dispersion flattened multiple clad fiber - 色散平坦型多包层光纤 (0) 投诉
P:2008-10-31 13:42:16
還要看BCCS的電導率是多少了?
cable passage - 电缆通路,电缆通道 (0) 投诉
P:2008-10-31 15:03:12
kaka2004:
還要看BCCS的電導率是多少了?
它上面已经给出内导体电阻,导电率23%
dipping tank - 浸渍槽 (0) 投诉
P:2008-10-31 15:31:46
客户要求永远都是苛刻的,,没有什么过分。因为他就是你的上帝。。。
能不能做到就看你家的能力。既然有这样的要求肯定是可以做到的。我想他们是从BELDEN网上复制的。
integrated filling and sheathing line - 填充包套联合生产线 (0) 投诉
P:2008-10-31 17:02:17
要求是比较高的,我学习了一下,2200MHz,13.05dB/100ft,这个要求还可以,但你的2250MHz才11.905dB/100ft,学习了。
single conductor - 单根导线,单芯 (0) 投诉
P:2008-10-31 18:29:26
有点难,但总会有办法的
drawbench - 拉线机,拉丝机 (0) 投诉
P:2008-11-01 09:16:31
BELDON好象也不能绝对做到!
diameter gauging system - 直径测量系统,测径装置 (0) 投诉
P:2008-11-03 19:15:45
单位没有错!
感谢各位指点,受教了.
我考虑导电率为26%(放宽10%).
请教5楼的兄弟,发泡材料的选择上有何讲究?
air-supported fiber - 空气间隙光纤 (0) 投诉
P:2008-11-03 19:18:33
我理论计算的衰减怎么也不可能满足指标,不知道怎么回事?
我按照射频电缆设计规范计算的,哪为仁兄帮我指导其中的问题.
spooling equipment - 收线设备 (0) 投诉
P:2008-11-03 19:20:25
请教2楼,可以做到12。5吗?怎么做?
service plane - 业务平面(智能网概念模型的组成部分) (0) 投诉
