首页 > 国外线缆
[问题求助] 求,UL20276的标准!
P:2008-10-29 12:22:52
求,UL20276的标准!
load switch - 负荷开关 (0) 投诉
P:2008-10-29 13:08:32
你查一下UL标准就行了,20276是其中的一种线规
lightpipe - 光管,光导管 (0) 投诉
P:2008-10-29 14:19:38
我这里有一款,希望对你有用!
dissymmetry - 不对称 (0) 投诉
P:2008-10-29 14:21:53
怎么不能上传呢?
color coating - 彩色涂层 (0) 投诉
P:2008-10-29 21:34:06
UNDERWRITERS LABORATORIES INC.              APPLIANCE WIRING MATERIAL
Subj. 758     Section 2     Page 20276       Issued:  1983-08-16
                                Revised:  2003-06-05
Style 20276       Electronic Cable.
______________________________________________________________________________
Rating     60°C or 80°C, 30 V.
Insulated     No. 40 AWG minimum.  Labeled or complying with AWM
Conductors    Procedure having a minimum rating of 60°C or 80°C
           whichever is applicable.
Assembly      Consists of two or more conductors, twisted pairs,
           parallel pairs, or groups of twisted conductors or
           parallel pairs twisted together.  The conductors or
           groups of conductors may be laid parallel forming a flat,
           oval or round cable.  The lay of the insulated conductors
           are not specified.  A barrier layer and/or fillers are
           optional.  Manufacturer shall maintain a complete
           description of each assembly.  May use same or mixed AWG
           size.
Covering      (Optional.)  A 6 mil or heavier PVC covering may be
           extruded over the conductor assembly.
Shield     Optional.
Jacket     PVC, Class 43.
               Thickness (mils)
                 Construction A       Construction B
               External Use          Internal Use
           #Dia. under                  Minimum         Minimum
            jacket in        Minimum    at       Minimum      at
             inches__     Average   any Point   Average   any Point
           0.350 or less     20        17         15         12
           0.351 - 0.700     30        24         30         24
           0.701 - 1.00      40        36         40         36
           0.101 - 1.50      54        48         54         48
Standard      Appliance Wiring Material UL 758.
                            (Continued on Page 20276A)
Subj. 758     Section 2     Page 20276A        Issued:  1983-08-16
                                Revised:  2003-06-05
Instructions  Detailed Examination.
to UL         Physical Properties of Jacket.
Representative
           The designation of all Styles of the individual
conductors used making up the cable assembly shall be
available, and the UL Representative's tag shall indicate
if the Style is labeled or not.  If they are not labeled,
the appropriate Follow-Up Tests shall be conducted.
UL         (4)  Detailed Examination.
*Counter-Check    (4)  Physical Properties of Jacket.
*Program      (4)  Heat Shock.
*          (4)  Cold Bend.
*          (4)  Deformation.
           (12) Cable Flame Test on Completed Cable,
                Construction A only.
           (12) Horizontal Flame Test on Completed Cable,
                Construction B only.
           If the insulated Styles are not labeled, the appropriate
Marking       General.
Use        Construction A:  Internal wiring or external
           interconnection of electronic equipment in Class 2
           circuits only.
           Construction B:  Internal wiring of electronic equipment
           in Class 2 circuits only.
zhengliang 奖励 10 金币,.05 声望,于 2009-12-7 10:16:23 原因:奖励下
die stand - 模座 (0) 投诉
P:2008-10-30 09:36:21
谢谢
sagging - 松垂 (0) 投诉
P:2009-07-02 11:16:16
我也学习一下。。谢谢fourwo !
aluminium - 铝 (0) 投诉
P:2009-07-02 11:25:48
最新的20276(2009年01月份的版本)
GMBD - geometric mean breakdown strength几何平均击穿强度 (0) 投诉
P:2009-07-03 15:43:10
上UL网上一下就查到了
transmission - 传输,通话;输电 (0) 投诉
P:2009-07-15 16:24:27
没中文555555555555555555555555555555555555555555555555555
screening - 屏蔽;包屏蔽 (0) 投诉
P:2009-08-22 09:32:36
我也正在找相關資料。可惜沒錢哪
coil winding - 成圈卷绕,成圈收线 (0) 投诉
