[问题求助] 此款线材如何做才可满足衰减及回损要求
P:2008-10-13 13:57:10
下面有关于CAI  COAXIAL CABLE 的规格及测试要求,请问该如何做才可满足测试要求? 请各位高手指点.
     1. Mechanical Specification
The mechanical specifications for the cable as follows:
Inner Conductor : To be copper
Diameter of Inner Conductor : 1.0 +/-0.02mm
Outer Braid / Tape : No contact between dissimilar metals
External Diameter of Sheath : 6.55 +/-0.3mm
Bending Radius : 40mm
Flexing Radius : 75mm
The DC resistance of the inner conductor should be <26 W/km.
The DC resistance of the outer conductor should be <15 W/km.
2.Longitudinal Loss (Attenuation)
(Reference BS EN 50117-1:1997 Section 11.8)
The attenuation of the cable under test should meet the following:
5 MHz :   < 1.6 dB/100m
50 MHz :  < 4.6 dB/100m
100 MHz :  < 6.5 dB/100m
200 MHz :  < 9.5 dB/100m
460 MHz :  < 15.0 dB/100m
860 MHz :  < 19.5 dB/100m
1000 MHz : < 21.5 dB/100m
1750 MHz : < 29.0 dB/100m
2150 MHz : < 32.5 dB/100m
3.Return Loss
(Reference BS EN 50117-1:1997 Section 11.6)
The return loss of the cable under test should meet the following:
5 - 30 MHz : > 23 dB
30 - 470 MHz : > 23 dB
470 - 862 MHz : > 20 dB
862 - 2150 MHz : > 18 dB
In each frequency band, 3 peak return loss values up to 4dB lower than the
stated specified limit are permissible.
c.d. - cold-drawn冷拉的,硬拉的 (0) 投诉
P:2008-10-13 14:02:59
先按Spec试试。不然怎么知道可不可以。
但绝缘一定Foam-PE
IOCs - Integrated Optical circuits集成光路 (0) 投诉
P:2008-10-13 14:36:39
我将线芯做到4.57,但测试衰减及回损都不行
repeated scrape test - 反复耐刮试验 (0) 投诉
P:2008-10-13 15:28:51
CU1.0MM   FPE4.6MM  AL/P18MM  TC0.12*96.这些参数都是很标准的了,如果说难的话,那低频可能会高点,内导体上面是26W/km,用1.0mm的铜线,不要太小了。电容52+/-1
self-cost - 成本 (0) 投诉
P:2008-10-13 16:17:15
 用GAS PE較好.
HSI - horizontal situation indicaor水平位置指示器 (0) 投诉
P:2008-10-13 16:51:38
COPPER 1.0,FPE4.8,采用铜箔,非电接触与编织,铜司60%,护套6.55 +/-0.3mm
stress control layer - 应力控制层(电缆终端头的) (0) 投诉
P:2008-10-13 17:06:16
绝缘用FPE,4.57--4.60MM,屏蔽有AL+编织即可,结构这样是可以的,同轴线的RL最主要是机器设备的稳定性,同心度好不好等因素影响
legend printing - 符号[代号]印字(电缆标志形式之一) (0) 投诉
P:2008-10-13 17:10:31
一定用铜箔
span - 杆间距离,杆挡(架空线的) (0) 投诉
P:2008-10-13 17:12:05
有条件用氮气发泡做比较好.
stereotelevision receiver - 立体电视接收机 (0) 投诉
P:2008-10-13 17:14:11
西班牙的采用英表
back pressure - 反压力(挤压时) (0) 投诉
P:2008-10-13 17:42:21
铜箔最好,但是铝箔这个衰减是能做到的,况且她的外电阻有要求,铝箔+TC编织可以做到她的外电阻要求,性价比也要考虑的
physical architecture - 物理结构(电信管理网的) (0) 投诉
P:2008-10-13 17:58:32
我现在是用的铜箔,电阻这块都没问题.但目前做的衰减在2150MHZ时为41 dB,回损才7dB.我们做的也是氮气发泡
die cassete - 模箱,模座 (0) 投诉
P:2008-10-14 12:39:07
这种是欧洲国家的线材,一般会 要铜箔铜编织,不过也有要铝箔镀锡铜编织的,上面的性能是很普通的,如果这种结构达不到上面的性能,肯定是有问题的。你的衰减应该是各个频段都高把(如果发泡材料没问题,建议查看发泡度,和发泡粉是否受潮)
RW - ring wire塞环线,b线,r线 (0) 投诉
P:2008-10-14 13:52:53
在押发泡线芯时,有测水中电容,显示值在54.5-55,因为没有外层HDPE,不敢发的太泡,太泡后线芯在经过引取轮就变形了. 再说,按照以上线规,其衰减在2150MHZ时也会在39dB左右,怎计算出小于32.5
Z-connection - Z形连接,曲折接法 (0) 投诉
P:2008-10-15 12:26:25
水中电容太大了,保证不了衰减的
rotating mirror drum - 旋转镜操作盘,反射镜操作盘(激光测径仪的) (0) 投诉
19
