首页 > 标准讨论 培训学习
[标准信息] ASTM-B系列标准目录 [截至2005年]
P:2008-10-07 10:51:47
ASTM B770-02 通用铜铍合金砂型铸件 Standard Specification for Copper-Beryllium Alloy Sand Castings for General Applications9^nRqV3p
ASTM B771-87(2001) 硬质合金短杆断裂韧度的试验方法 Standard Test Method for Short Rod Fracture Toughness of Cemented Carbides
fK$p|t*v ASTM B772-97(2003) 电接触材料(击穿和非击穿)化学成分的规定 Standard Guide for Specifying the Chemical Compositions for Electrical Contact Materials (Arcing and Nonarcing)
a$Y;p{Z/p:p ASTM B773-96(2002)e1 用超声波C扫描测定钎焊或焊接电触点组件的粘接性 Standard Guide for Ultrasonic C-Scan Bond Evaluation of Brazed or Welded Electrical Contact Assemblies6?(Q] H l hTg
ASTM B774-00 低熔点金属 Standard Specification for Low Melting Point Alloys,v/Co5O/F&r9^ hQ
ASTM B775-02 镍和镍合金无缝和焊接管 Standard Specification for General Requirements for Nickel and Nickel Alloy Welded Pipe5{u2f[\#J
ASTM B776-01a 铪和铪合金带材,薄板和中厚板 Standard Specification for Hafnium and Hafnium Alloy Strip, Sheet, and Plate-p_!} VW/~N;SW'~+?5j
ASTM B777-99 钨基高密度金属 Standard Specification for Tungsten Base, High-Density Metal3Uh&tMs/s-S
ASTM B778-02 线状致密同芯绞捻铝导线 Standard Specification for Shaped Wire Compact Concentric-Lay-Stranded Aluminum Conductors (AAC/TW)
;ZtU#JY`5uQ4v ASTM B779-03 钢芯加强线状致密同芯绞捻铝导线 Standard Specification for Shaped Wire Compact Concentric-Lay-Stranded Aluminum Conductors, Steel-Reinforced (ACSR/TW)
cnum a@&n ASTM B780-98(2004) 含75%银,24.5%铜,0.5%镍的电触点合金 Standard Specification for 75% Silver, 24.5% Copper, 0.5% Nickel Electrical Contact Alloy
+H'd0JT(K3\:gc _ a ASTM B781-93a(1999) 银镉氧化接触材料 Standard Guide for Silver-Cadmium Oxide Contact Material
{sk }_sz ASTM B782-00 烧结球墨铸铁轴承(注油) Standard Specification for Iron Graphite Sintered Bearings (Oil-Impregnated) \Y`)@'|p)H.n
ASTM B783-04 黑色粉末冶金结构部件的材料 Standard Specification for Materials for Ferrous Powder Metallurgy (P/M) Structural Parts-gxOcV1o7E`
ASTM B784-01 绝缘电缆用改进的同芯绞捻铜导线 Standard Specification for Modified Concentric-Lay-Stranded Copper Conductors for Use in Insulated Electrical Cables
`il4_~6ZC J ?!| ASTM B786-02a 次级绝缘用19股单绞捻1350型铝导线 Standard Specification for 19 Wire Combination Unilay-Stranded Aluminum Conductors for Subsequent Insulation'[]jY"X:w!G l'i
ASTM B787/B787M-01 次级绝缘用19股单绞捻铜导线 Standard Specification for 19 Wire Combination Unilay-Stranded Copper Conductors for Subsequent InsulationV \?x E}7r
ASTM B788/B788M-00 工厂制造的波纹铝涵洞管和排水管的安装标准惯例 Standard Practice for Installing Factory-Made Corrugated Aluminum Culverts and Storm Sewer PipeU!Sj2?l:~ [-X1ua
ASTM B789/B789M-99 涵洞和下水道用波纹铝结构板材制管道安装标准惯例 Standard Practice for Installing Corrugated Aluminum Structural Plate Pipe for Culverts and Sewers6Ln&K5cy
ASTM B790/B790M-00 涵洞,排水和其它地下管道用波纹铝管,管拱和拱的结构设计 Standard Practice for Structural Design of Corrugated Aluminum Pipe, Pipe-Arches, and Arches for Culverts, Storm Sewers, and Other Buried Conduits;W4yGWH6x9Z&^
ASTM B792-01e1 空壳铸造用铸模中的锌合金锭 Standard Specification for Zinc Alloys in Ingot Form for Slush Casting'F&f^uZ*}
ASTM B793-03 板金成形模和塑料注塑模用锌铸造合金锭的技术规范 Standard Specification for Zinc Casting Alloy Ingot for Sheet Metal Forming Dies and Plastic Injection Molds
L:d$FX{P rq8] ASTM B794-97(2003) 用电阻测量作可拆卸电器插接件的耐耗试验的试验方法 Standard Test Method for Durability Wear Testing of Separable Electrical Connector Systems Using Electrical Resistance Measurements
-@4{!C1sk:g"z,|z ASTM B795-93(2003) 测定粉末锻钢部件中合金铁杂质或非合金铁百分比含量的标准试验方法 Standard Test Method for Determining the Percentage of Alloyed or Unalloyed Iron Contamination Present in Powder Forged (P/F) Steel Parts
O6s;Y$LlU`-[Tyk ASTM B796-02 低合金粉末锻钢部件的非金属杂质含量的测试方法 Standard Test Method for Nonmetallic Inclusion Content of Powders Intended for Powder Forging (P/F) Applications
Mu'\8[8n [h3f\ ASTM B797-93(2002)e1 粉末锻钢部件中表面指状氧化物穿透深度和粒子间氧化物网状组织出现的测试方法 Standard Test Method for Surface Finger Oxide Penetration Depth and Presence of Interparticle Oxide Networks in Powder Forged (P/F) Steel Parts
Z#e~3okr+b"| ASTM B798-95(2000) 用凝胶体电谱法测定金属基物上金或钯涂层孔隙度的测试方法 Standard Test Method for Porosity in Gold or Palladium Coatings on Metal Substrates by Gel-Bulk Electrography2QM.y1xt$PO
ASTM B799-95(2000) 用亚硫酸/SO2蒸汽测试金和钯镀层孔隙度的方法 Standard Test Method for Porosity in Gold and Palladium Coatings by Sulfurous Acid/Sulfur-Dioxide Vapor
s2h$MW)V/i*? ASTM B800-00 电气用退火及中温回火8000系列铝合金导线 Standard Specification for 8000 Series Aluminum Alloy Wire for Electrical Purposes-Annealed and Intermediate Tempers/Cy [qK!M9l3V2l h
ASTM B801-99 次级涂层和绝缘的8000系列铝合金同芯绞捻导线 Standard Specification for Concentric-Lay-Stranded Conductors of 8000 Series Aluminum Alloy for Subsequent Covering or Insulation
f9QS.Urz:B0h ASTM B802/B802M-02 钢芯铝导线用锌5%铝铈合金镀覆的钢芯线标准规范 Standard Specification for Zinc-5% Aluminum-Mischmetal Alloy-Coated Steel Core Wire for Aluminum Conductors, Steel Reinforced (ACSR)#uY*z4dA4`ZB
ASTM B803-02 钢芯铝和铝合金导线用高强度锌5%铝铈合金涂层的钢芯线 Standard Specification for High-Strength Zinc-5% Aluminum-Mischmetal Alloy-Coated Steel Core Wire for Aluminum and Aluminum-Alloy Conductors, Steel Reinforced;Es`)ds/MU}^
ASTM B804-02 UNS NO8367焊接管 Standard Specification for UNS N08367 and UNS N08926 Welded PipeM8ot ni.Pt
ASTM B805-02 统一编制牌号为NO7716,NO7725,N07773,N07776和N09777沉淀硬化镍合金钢棒和钢丝 Standard Specification for Precipitation Hardening Nickel Alloys UNS N07716, N07725, N07773, N07776, and N09777, Bar and Wire+S~M^z G9G&kn
ASTM B806-04 通用铜合金永久铸模铸件标准规范 Standard Specification for Copper Alloy Permanent Mold Castings for General Applications4C9Zz:Wc{
ASTM B807-02 铝合金用挤压压力溶液的热处理 Standard Practice for Extrusion Press Solution Heat Treatment for Aluminum Alloys
E7MO0t!H H z ASTM B808-97(2003) 用石英晶体微量天平监测室内大气腐蚀的试验方法 Standard Test Method for Monitoring of Atmospheric Corrosion Chambers by Quartz Crystal Microbalances
b\sW_.E$SX;Ik!P*r ASTM B809-95(2003) 用湿硫黄蒸气("硫黄华")作金属涂层中孔隙度测试的测试方法 Standard Test Method for Porosity in Metallic Coatings by Humid Sulfur Vapor (Flowers-of-Sulfur)
ln`1{JTU6}#K ASTM B810-01a 校准大气腐蚀试验箱的标准试验方法 Standard Test Method for Calibration of Atmospheric Corrosion Test Chambers by Change in Mass of Copper Coupons
vt n7T5tv KF%I ASTM B811-02 核反应堆燃料外包覆用锻制锆合金无缝钢管 Standard Specification for Wrought Zirconium Alloy Seamless Tubes for Nuclear Reactor Fuel Cladding@2L s^^9y2q8nk
ASTM B812-96(2002)e1 住宅设备用铝制电压连接件的抗环境退化的试验方法 Standard Test Method for Resistance to Environmental Degradation of Electrical Pressure Connections Involving Aluminum and Intended for Residential Applications
2B}&LvsT hc2t ASTM B813-00e1 铜和铜合金管钎焊用液体和软膏状焊剂 Standard Specification for Liquid and Paste Fluxes for Soldering of Copper and Copper Alloy Tube&j4^s?F}
ASTM B814-02 镍铬铁钼钨合金板,薄板和带材 Standard Specification for Nickel-Chromium-Iron-Molybdenum-Tungsten Alloy (UNS N06920) Plate, Sheet, and Strip
&~Q6b0K#XV ASTM B815-02 钴铬镍钼钨合金杆 Standard Specification for Cobalt-Chromium-Nickel-Molybdenum-Tungsten Alloy (UNS R31233) Rod
^KpQ([N7]:I0Z ASTM B817-03 粉末冶金(P/M)钛合金结构元件 Standard Specification for Powder Metallurgy (P/M) Titanium Alloy Structural Components
fM n7Tm V2zs1N ASTM B818-03 钴铬镍钼钨合金板,薄板和带材 Standard Specification for Cobalt-Chromium-Nickel-Molybdenum-Tungsten Alloy (UNS R31233) Plate, Sheet and Strip/PG1a9R0x$x
ASTM B819-00 医用天然气系统用无缝铜管 Standard Specification for Seamless Copper Tube for Medical Gas Systems*{L6|0Ya
ASTM B820-04 铜合金弹簧材料可成型弯曲试验的试验方法 Standard Test Method for Bend Test for Determining the Formability of Copper and Copper Alloy Stripn"m5sa"_["{5ew
ASTM B821-02 粒度分析用金属粉末和相关混合物液体悬浮液的标准指南 Standard Guide for Liquid Dispersion of Metal Powders and Related Compounds for Particle Size Analysis
(@,R:^0h%`q/I ASTM B822-02 用光散射作金属粉末和相关元件的粒度分布测试的方法 Standard Test Method for Particle Size Distribution of Metal Powders and Related Compounds by Light ScatteringP |.Z-Dj5W0A6i/ta
ASTM B823-01 有色粉末冶金(P/M)结构元件 Standard Specification for Materials for Nonferrous Powder Metallurgy (P/M) Structural PartsW1M2f5^ z E2[)_
ASTM B824-04 铜合金铸件 Standard Specification for General Requirements for Copper Alloy Castings
;s[f,M%l3Sj ASTM B825-02 在金属试样上表面薄膜的电量(库仑)缩减试验法 Standard Test Method for Coulometric Reduction of Surface Films on Metallic Test Samples
F6w0z%A4I7X ASTM B826-03 用电阻试样监测大气腐蚀试验的试验方法 Standard Test Method for Monitoring Atmospheric Corrosion Tests by Electrical Resistance Probes;l2e ~!] _7M+J Y s
ASTM B827-97(2003) 传导混流气的环境试验 Standard Practice for Conducting Mixed Flowing Gas (MFG) Environmental Tests
qk,k"utiC ASTM B828-02 用铜,铜合金管和配件钎焊制作毛细管连接件 Standard Practice for Making Capillary Joints by Soldering of Copper and Copper Alloy Tube and FittingsSt+JT F7uE
ASTM B829-04 镍和镍合金无缝管 Standard Specification for General Requirements for Nickel and Nickel Alloys Seamless Pipe and Tube
i QD"I@ R_ ASTM B830-97(2003) 均匀试验方法和频率 Standard Specification for Uniform Test Methods and Frequency
TEnr'L3m C+J7O ASTM B831-93(1998) 薄铝合金产品剪切试验的试验方法 Standard Test Method for Shear Testing of Thin Aluminum Alloy Products
fbL0K6b:] ASTM B832-93(2003) 镍及铜的电铸成型标准导则 Standard Guide for Electroforming with Nickel and CopperP:oLr/\ [T9` V!x
ASTM B833-01a 热喷镀用锌线(喷镀金属) Standard Specification for Zinc and Zinc Alloy Wire for Thermal Spraying (Metallizing)
]g.Ww RkQ5`[U ASTM B834-95(2003) 压力固结粉末冶金铁镍铬钼和镍铬钼钶(Nb)合金管法兰,管配件,阀门和零件 Standard Specification for Pressure Consolidated Powder Metallurgy Iron-Nickel-Chromium-Molybdenum (UNS N08367) and Nickel-Chromium-Molybdenum-Columbium (Nb) (UNS N06625) Alloy Pipe Flanges, Fittings, Valves, and Parts-R2{(n)c"l.^DG-A
ASTM B835-00 使用单输入线路结构的压缩圆铜绞线标准规范 Standard Specification for Compact Round Stranded Copper Conductors Using Single Input Wire ConstructionHx;?y7A6LRu
ASTM B836-00 使用单输入线路结构的压缩圆铝绞线标准规范 Standard Specification for Compact Round Stranded Aluminum Conductors Using Single Input Wire Construction}U:FQ8g4zm:C"|Z5G*ME
ASTM B837-01 用于天然气和液化石油气燃料分配系统的无缝铜管标准规范 Standard Specification for Seamless Copper Tube for Natural Gas and Liquified Petroleum (LP) Gas Fuel Distribution Systemsd&iqI3MOY
ASTM B839-04 金属镀覆的外螺纹制品,紧固件和棒的残余脆性的标准试验方法.倾斜楔入法 Standard Test Method for Residual Embrittlement in Metallic Coated, Externally Threaded Articles, Fasteners, and Rod―Inclined Wedge Method
?Q y,M]:o ASTM B840-99(2004) 锌钴合金沉积物用电解镀层标准规范 Standard Specification for Electrodeposited Coatings for Zinc Cobalt Alloy Deposits
RD\C F ASTM B841-99(2004) 锌镍合金沉积物用电解镀层标准规范 Standard Specification for Electrodeposited Coatings for Zinc Nickel Alloy Deposits
d(o&A+s&L[Q-d ASTM B842-99 锌铁合金沉积物用电解镀层标准规范 Standard Specification for Electrodeposited Coatings for Zinc Iron Alloy Deposits
K)lO+Cb@ ASTM B843-93(2003) 阴极防腐法用镁合金阳极的标准规范 Standard Specification for Magnesium Alloy Anodes for Cathodic Protection`$l"G$GBa]
ASTM B844-98(2004) 银锡氧化物接触材料标准导则 Standard Guide for Silver-Tin Oxide Contact Materialm#ey4m _S
ASTM B845-97(2003) 电触点混流气体试验用标准导则 Standard Guide for Mixed Flowing Gas (MFG) Tests for Electrical Contacts&y+Z f{C9AS8W$_D
ASTM B846-01e1 铜和铜合金标准术语 Standard Terminology for Copper and Copper Alloyst os iF)s/c
ASTM B848-01 粉末锻造的铁素体结构件标准规范 Standard Specification for Powder Forged (P/F) Ferrous Structural PartsF2I3Q/p;m:ImZX1p:I
ASTM B849-02 为减少氢脆变危险对铁或钢进行后镀层处理的技术规范 Standard Specification for Pre-Treatments of Iron or Steel for Reducing Risk of Hydrogen Embrittlement
.U G}UE,T{!Lq ASTM B850-98(2004) 对钢铁镀层后处理以减小氢脆变危险的标准规范 Standard Guide for Post-Coating Treatments of Steel for Reducing the Risk of Hydrogen Embrittlement
"Ohd8G-L b:^ ASTM B851-04 在镍,自动催化镍或铬镀覆或者最后镀层之前金属制品自动控制喷丸硬化的标准规范 Standard Specification for Automated Controlled Shot Peening of Metallic Articles Prior to Nickel, Autocatalytic Nickel, or Chromium Plating, or as Final Finishi s2@5Q#])t
ASTM B852-01 薄钢板连续热浸镀锌用锌合金的标准规范 Standard Specification for Continuous Galvanizing Grade (CGG) Zinc Alloys for Hot-Dip Galvanizing of Sheet SteelrA)r7I"F/O
ASTM B853-02 粉末冶金(P/M)硼不锈钢构件的标准规范 Standard Specification for Powder Metallurgy (P/M) Boron Stainless Steel Structural Components IG QU,M {_G
ASTM B854-98(2004) 测量电接触点间歇性的标准导则 Standard Guide for Measuring Electrical Contact Intermittences
h7V;??)q2PR ASTM B855-94(1999)e1 用阿诺德测量计和霍尔漏斗测定金属粉末体流率的标准试验方法 Standard Test Method for Volumetric Flow Rate of Metal Powders Using Arnold Meter and Hall Funnel9vACwe8a,`8B
ASTM B856-03 包钢加强的(ACSS/TW)同心绞捻铝导线的技术规范 Standard Specification for Concentric-Lay-Stranded Aluminum Conductors, Coated Steel Supported (ACSS)
U#M-H"k:_1OD ASTM B857-02 包钢加强的(ACSS/TW)成型密实同心绞捻铝导线的技术规范 Standard Specification for Shaped Wire Compact Concentric-Lay-Stranded Aluminum Conductors, Coated-Steel Supported (ACSS/TW)?Q$pD.uvv
ASTM B858-01 用氨蒸气试验测定铜合金对应力腐蚀裂纹的敏感性的标准试验方法 Standard Test Method for Ammonia Vapor Test for Determination Susceptibility to Stress Corrosion Cracking in Copper Alloys,emvZ8S7b
ASTM B859-03 粒度分析前耐火金属粉末及其化合物去除结块的标准惯例 Standard Practice for De-Agglomeration of Refractory Metal Powders and Their Compounds Prior to Particle Size Analysis
PMdL+c7j:{,i ASTM B860-02 热浸镀锌用锌母合金的标准规范 Standard Specification for Zinc Master Alloys for Use in Hot Dip Galvanizing
&~+u k\ TN ASTM B861-03 钛和钛合金无缝管的标准规范 Standard Specification for Titanium and Titanium Alloy Seamless Pipe``7z'TS;kXp
ASTM B862-02 钛和钛合金焊接管的技术规范 Standard Specification for Titanium and Titanium Alloy Welded Pipe{ }PR8^t g
ASTM B863-03 钛和钛合金线材的标准规范 Standard Specification for Titanium and Titanium Alloy WiretkE0r$G{}'^
ASTM B864/B864M-00 波纹铝箱形电缆管道的技术规范 Standard Specification for Corrugated Aluminum Box Culverts-]eQ l6ff*Y
ASTM B865-04 沉淀硬化镍铜铝合金(UNS N05500)棒,条,丝,锻件和锻坯的标准规范 Standard Specification for Precipitation Hardening Nickel-Copper-Aluminum Alloy (UNS N05500) Bar, Rod, Wire, Forgings, and Forging Stock
y? b#M4E B ASTM B866-95(2003) 用聚硫化物浸入法测试金属涂层中总疵点和机械损坏的标准试验方法 Standard Test Method for Gross Defects and Mechanical Damage in Metallic Coatings by Polysulfide ImmersionbA ~*g;P
ASTM B867-95(2003) 工程用钯-镍电镀层的标准规范 Standard Specification for Electrodeposited Coatings of Palladium-Nickel for Engineering Use
9l[g;f0rF ASTM B868-96(2002)e1 电气连接系统的接触性能分类的标准规程 Standard Practice for Contact Performance Classification of Electrical Connection Systems}6X$bdV6Gf
ASTM B869-04 用于CATV用户引线的包铜钢电导线的技术规范 Standard Specification for Copper-Clad Steel Electrical Conductor for CATV Drop Wire5];qd6S gw~3JN
ASTM B870-02 铜-铍合金锻制和挤制合金C17500和C17510的标准规范 Standard Specification for Copper-Beryllium Alloy Forgings and Extrusions Alloys (UNS Nos. C17500 and C17510)5n`2Ck+d.M/P\M
ASTM B871-01 铝合金产品撕裂测试的标准试验方法 Standard Test Method for Tear Testing of Aluminum Alloy Products
u3X!T BJuA7N ASTM B872-96(2003) 弥散硬化镍铁铬钴(Nb)钛铝合金(UNS N09908)板,薄板及带材的标准规范 Standard Specification for Precipitation-Hardening Nickel-Iron-Chromium- Columbium (Nb)-Titanium-Aluminum Alloy (UNS N09908) Plate, Sheet, and Stripsdy6iy/dr@ JL5M
ASTM B873-01 B212,B329和B417的测试方法中用的表观密度杯的容积测量的标准试验方法 Standard Test Method for Measuring Volume of Apparent Density Cup Used in Test Methods B212, B329, and B417^R*?Uj/lW
ASTM B874-96(2003) 用于固体渗金属处理的铬扩散镀层的标准规范 Standard Specification for Chromium Diffusion Coating Applied by Pack Cementation Process
4wk(ud n"]/nM3ih ASTM B875-96(2003) 用于固体渗金属处理的铝扩散镀层的标准规范 Standard Specification for Aluminum Diffusion Coating Applied by Pack Cementation ProcessmN&I:^I)x i^UH k4D
ASTM B877-96(2003) 用磷钼酸(PMA)测定金属涂层中明显缺陷和机械损坏的标准试验方法 Standard Test Method for Gross Defects and Mechanical Damage in Metallic Coatings by the Phosphomolybdic Acid (PMA) Methodc2?)g,p*Z
ASTM B878-97(2003) 电气接触和连接件毫微秒间隙检测的标准试验方法 Standard Test Method for Nanosecond Event Detection for Electrical Contacts and ConnectorsuS'^}u4Nj&`FI]
ASTM B879-97(2003)e1 镁和镁合金上非电解质转换涂层的标准规范 Standard Practice for Applying Non-Electrolytic Conversion Coatings on Magnesium and Magnesium Alloys
_"v%_/T@A ASTM B880-03 镍、镍合金及钴合金化学检查分析极限值的通用要求 Standard Specification for General Requirements for Chemical Check Analysis Limits for Nickel, Nickel Alloys, and Cobalt Alloyst#ghY0k"AH0C
ASTM B881-98a(2004) 铝及镁合金产品有关的术语 Standard Terminology Relating to Aluminum- and Magnesium- Alloy Products
B$\*]]0I_OE5[ ASTM B882-00 建筑用预生锈铜规范 Specification for Pre-Patinated Copper for Architectural Applicationsv7KA!Ya
ASTM B883-97 黑色金属结构件用金属注射模造成型(MIM)技术规范 Standard Specification for Metal Injection Molding (MIM), Ferrous Structural Parts&Pj$z/GzL
ASTM B884-01 超导用钛铌合金方坯,棒材和盘条技术规范 Standard Specification for Niobium-Titanium Alloy Billets, Bar and Rod for Superconducting Applications
ED4_(jK"HLE_h ASTM B885-97(2003) 印刷线路板接点上外来物存在情况检测试验方法 Standard Test Method for Presence of Foreign Matter on Printed Wiring Board Contacts
f)\ ^U}-q:^#l'w;`s ASTM B886-03 (烧结)硬制合金磁饱和测定的标准试验方法 Standard Test Methods for Determination of Magnetic Saturation (Ms) of Cemented Carbides
!z4f&x ik ASTM B887-03 烧结硬制质合金矫顽力(HCS)测定的标准试验方法 Standard Test Method for Determination of Coercivity (Hcs) of Cemented Carbides
`(c,B!h~C ASTM B888-04 制造电气连接器或弹簧触点时采用的铜合金带材技术规范 Standard Specification for Copper Alloy Strip for Use in the Manufacture of Electrical Connectors or Spring Contacts%zPmG/o"|
ASTM B890-02 X光射线荧光光谱仪确定钨合金和硬性钨合金的金属组成试验方法 Standard Test Method for Determination of Metallic Constituents of Tungsten Alloys and Tungsten Hardmetals by X-Ray Fluorescence Spectrometry+m[mUE3N'^k5`'}
ASTM B891-98(2004) 装整体散热片的无缝和焊接钛钛合金冷凝器和热交换器规范 Standard Specification for Seamless and Welded Titanium and Titanium Alloy Condenser and Heat Exchanger Tubes With Integral Fins
]V nTuZ1O ASTM B892-03 压力铸件用锌铜铝锭技术规范 Standard Specification for ACuZinc5 (Zinc-Copper-Aluminum) Alloy in Ingot Form for Die CastingsJw;PsR
ASTM B893-98(2003) 工程上应用的镁硬涂层阳极化处理规范 Specification for Hard-Coat Anodizing of Magnesium for Engineering Applications
*[,gY y)Tw ASTM B894-03 锌铜铝合金压铸件规范 Standard Specification for ACuZinc5 (Zinc-Copper-Aluminum) Alloy Die Castingsw3ZWa\%H
ASTM B895-99 用浸入氯化钠溶液方法评价粉末冶金(P/M)不锈钢零件/样件耐蚀性试验方法 Standard Test Methods for Evaluating the Corrosion Resistance of Powder Metallurgy (P/M) Stainless Steel Parts/Specimens by Immersion in a Sodium Chloride Solution
/yuwmb%e2qhU0h*D ASTM B896-99 评价电导体材料连通性特点试验方法 Standard Test Methods for Evaluating Connectability Characteristics of Electrical Conductor Materials3Zw o+de7{WL
ASTM B897-03 锌和锌合金大型坯料结构规范 Standard Specification for Configuration of Zinc and Zinc Alloy Jumbo and Block Ingot
2a:c M9WC-B ASTM B898-99 活性和耐熔金属包层板规范 Standard Specification for Reactive and Refractory Metal Clad Plate
\xyS)K ASTM B899-04 与有色金属和合金相关术语 Standard Termninology Relating to Non-ferrous Metals and Alloys%Fs#Wpha9| \
ASTM B900-99 美国政府机构用铜和铜合金工厂产品包装标准惯例 Standard Practice for Packaging of Copper and Copper-Alloy Mill-Products for U.S. Government Agencies
4_7|Bb!L4eXr ASTM B901-04 具有单输入端金属线结构的压缩圆股铝导线规范 Standard Specification for Compressed Round Stranded Aluminum Conductors Using Single Input Wire Construction w V+Zg.s
ASTM B902-04 具有单输入端金属线结构的硬的、半硬的或软的压缩圆股铜导线的标准规范 Standard Specification for Compressed Round Stranded Copper Conductors, Hard, Medium-Hard, or Soft Using Single Input Wire Construction
h!a*kf8hK8N qI6A8XNo ASTM B903-00 热交换器用内部增强型无缝铜管规范 Standard Specification for Seamless Copper Heat Exchanger Tubes With Internal Enhancement4n6V9B*v:m/~/alR
ASTM B904-00 电磁干扰屏蔽用自催化铜上的自催化镍的标准规范 Standard Specification for Autocatalytic Nickel over Autocatalytic Copper for Electromagnetic Interference Shielding
#j,PO ?&w*T ASTM B905-00 用机械带试验测量金属无机涂料附着力 Standard Test Methods for Assessing the Adhesion of Metallic and Inorganic Coatings by the Mechanized Tape Test
%o`%@(m(_ \ A ASTM B906-02 辊压镍及镍合金板材,薄板材和带材通用要求 Standard Specification for General Requirements for Flat-Rolled Nickel and Nickel Alloys Plate, Sheet, and Strip1DP4w*C(Xy&@mA
ASTM B907-01e1 锌,锡和镉基焊料规范 Standard Specification for Zinc, Tin and Cadmium Base Solders
-Q)ZZV/z5K U ASTM B908-03 锌铸造合金彩色编码使用惯例 Standard Practice for the Use of Color Codes for Zinc Casting Alloy Ingot
:X&o!LB?vZ$u0E ASTM B909-00 无预应力铝制品平面应变断裂测试指南 Standard Guide for Plane Strain Fracture Toughness Testing of Non-Stress Relieved Aluminum Products.WJ{'R+b~]*dj
ASTM B910/B910M-04 退火铜包覆钢丝电线规范 Standard Specification for Annealed Copper-Clad Steel WireX'F's#UG:h:l
ASTM B911/B911M-00 ACSR双绞线规范 Standard Specification for ACSR Twisted Pair Conductor (ACSR/TP)+mn0? MYYi
ASTM B912-02 用电解抛光法对不锈钢进行钝化处理规范 Standard Specification for Passivation of Stainless Steels Using ElectropolishingnpKH Ne#B q}
ASTM B913-00e1 16口径波纹电连接器和小直径丝束和实心导体评价试验方法 Standard Test Method for Evaluation of Crimped Electrical Connections to 16-Gauge and Smaller Diameter Stranded and Solid Conductors!Wr)AVK9B]O6A
ASTM B914-03e1 用于钢铁热浸镀锌的锌和锌合金锭的彩色编码惯例 Standard Practice for Color Codes on Zinc and Zinc Alloy Ingot for Use in Hot-Dip Galvanizing of Steel
vp,b1Sf~:\1X7W ASTM B915-01 自洁式烘箱涂层的静态隔热能力测量试验方法 Standard Test Method for Measuring the Static Heat Resistance of a Self-Cleaning Oven Coating)Zlue,i
ASTM B916-01 金属片表面搪瓷附着力测试方法 Standard Test Method for Adherence of Porcelain Enamel Coatings to Sheet Metal
"O:Y8RtV}O ASTM B917/B917M-01 加工后铝铸件热处理惯例 Standard Practice for Heat Treatment of Aluminum-Alloy Castings from All Processes7Gz;F6xXzQi!n
ASTM B918-01 精制铝合金热处理惯例 Standard Practice for Heat Treatment of Wrought Aluminum Alloys3A[#U)E:kx
ASTM B919-01 内部增强型焊接铜热交换器规范 Standard Specification for Welded Copper Heat Exchanger Tubes With Internal Enhancementqp!f~4p$}*p(o1o
ASTM B920-01 次氯酸钠溶液蒸汽检测金属基材上金与钯合金镀层孔隙度的规范 Standard Practice for Porosity in Gold and Palladium Alloy Coatings on Metal Substrates by Vapors of Sodium Hypochlorite Solution
Z^Z5uFMsE3i ASTM B921-02 铝和铝合金上非六价铬转换涂料规范 Standard Specification for Non-hexavalent Chromium Conversion Coatings on Aluminum and Aluminum Alloys
R_8C(e~#l ASTM B922-02 物理吸附法得定金属粉末特定表面积试验方法 Standard Test Method for Metal Powder Specific Surface Area by Physical Adsorption
,`2e |lP6x!R2^V ASTM B923-02 用氦或者氮测比重法测定金属粉末骨密度试验方法 Standard Test Method for Metal Powder Skeletal Density by Helium or Nitrogen Pycnometry
T-{7M t3a4@G b i_ ASTM B924-02 带有整体散热片的无缝及焊接的镍合金冷凝器和热交换器管规范 Standard Specification for Seamless and Welded Nickel Alloy Condenser and Heat Exchanger Tubes With Integral Fins'Zd8yto.x#HU-DW
ASTM B925-03 粉末冶金测试样品制备标准惯例 Standard Practices for Production and Preparation of Powder Metallurgy (P/M) Test Specimens
A x2_ w FL ASTM B926-03 用灯标表测定铝及铝合金平箔中气泡的标准方法 Standard Method for Pinhole Determination in Aluminum and Aluminum Alloy Plain Foil by Means of a Light TableZGW9Rh+rxm#~Z
ASTM B927-03 黄铜棒材、条材和型材的标准规范 Standard Specification for Brass Rod, Bar, and Shapes-i-P${7KB w
ASTM B928-04 舰船用高镁铝合金板和薄板的标准规范 Standard Specification for High Magnesium Aluminum-Alloy Sheet and Plate for Marine Service
d;V9Zwg#BG!^n ASTM B930-03 硬质钨金(硬性金属)额定粒度和反常大颗粒出现频率的测试方法 Standard Test Method for Rating Grain Size and Frequency of Abnormally Large Grains in Cemented Tungsten Carbides (Hardmetals)(}.Ehh+hsK
ASTM B931-03 铁粉末冶金(P/M)部件金相估计的观测外层深度的测试方法 Standard Test Method for Metallographically Estimating the Observed Case Depth of Ferrous Powder Metallurgy (P/M) Parts5ZzRb4k6cpo
ASTM B932-04 低碳镍铬钼钆合金板、薄板和带材的标准规范 Standard Specification for Low-Carbon Nickel-Chromium-Molybdenum-Gadolinium Alloy Plate, Sheet, and Strip U"` m%u:W-K%J
ASTM B933-04 粉末冶金(P/M)材料显微硬度的测试方法 Standard Test Method for Microindentation Hardness of Powder Metallurgy (P/M) MaterialsoF5O+oI~a
ASTM B934-04 用显微硬度测量铁粉末冶金(P/M)部件有效层厚度的试验方法 Standard Test Method for Effective Case Depth of Ferrous Powder Metallurgy (P/M) Parts Using Microindentation Hardness Measurements c%r]Lr,lA Cfm i
ASTM B937-04 铜铍无缝管规范(NUS Nos.C17500和C17510) Standard Specification for Copper-Beryllium Seamless Tube (UNS Nos. C17500 and C17510)MM9{w cTN}D
ASTM B938-04 铜铍合金锻件和挤压件C17500和C17510的标准规范 Standard Specification for Copper-Beryllium Alloy Forgings and Extrusions (UNS Nos. C17500 and C17510)
CUPP - pair-to-pair capacitance unbalance线对对线对电容不平衡 (0) 投诉
