首页 > 国外线缆
[国外型号] ASTM-B系列标准目录 [截至2005年]
P:2008-10-07 10:51:19
z)r4f XeU ASTM B495-01         锆及锆合金铸锭        Standard Specification for Zirconium and Zirconium Alloy Ingots
6G!~3Ex#H-R _'~ ASTM B496-04         紧密的圆形同心绞捻铜导线        Standard Specification for Compact Round Concentric-Lay-Stranded Copper Conductors
\ GS;r:^| ]xc)C ASTM B497-00         闭合电弧接点上电压降的测量        Standard Guide for Measuring Voltage Drop on Closed Arcing Contacts{#Q6t5o#L6] t!s~
ASTM B498/B498M-98(2002)         钢芯加强的铝导线用镀锌钢芯线(ACSR)        Standard Specification for Zinc-Coated (Galvanized) Steel Core Wire for Aluminum Conductors, Steel Reinforced (ACSR)5B"ayrAiOIl
ASTM B499-96(2002)         用磁性法测量磁性基底金属的非磁性镀层厚度的方法        Standard Test Method for Measurement of Coating Thicknesses by the Magnetic Method: Nonmagnetic Coatings on Magnetic Basis Metals
Z qN~+fge l'A3a ASTM B500/B500M-98(2002)         钢芯加强的铝导线用镀金属层的钢芯线(ACSR)        Standard Specification for Metallic Coated Stranded Steel Core for Aluminum Conductors, Steel Reinforced (ACSR)
(g-\(M;S-~"d ASTM B501-99         电气用镀银包铜钢丝        Standard Specification for Silver-Coated, Copper-Clad Steel Wire for Electronic Application"x^sO^)c
ASTM B502-02         包铝钢芯加强的铝导线用包铝钢芯线        Standard Specification for Aluminum-Clad Steel Core Wire for Aluminum Conductors, Aluminum-Clad Steel Reinforced QI7p F6j7Lr
ASTM B504-90(2002)         用库仑法测量金属镀层厚度的试验方法        Standard Test Method for Measurement of Thickness of Metallic Coatings by the Coulometric MethodQ2t!z)@;y:A gO6iU
ASTM B505/B505M-02         连续浇铸的铜基合金铸件        Standard Specification for Copper-Base Alloy Continuous Castings
uZ_|#aO%v ASTM B507-86(2003)         机件在支架上电镀的设计        Standard Practice for Design of Articles To Be Electroplated on Racks*G'v hpCU!_8j b5S~
ASTM B508-97(2003)         柔性金属软管用的铜合金带材规范        Standard Specification for Copper Alloy Strip for Flexible Metal Hose
/[9eNA^,q6S#j4u y.{ ASTM B511-01         镍铁铬硅合金棒材和型材规范        Standard Specification for Nickel-Iron-Chromium-Silicon Alloy Bars and Shapes
o x8R2uQ+Wa,mX:{ ASTM B512-04         镍铬硅合金(UNS N08330)坯锭和棒材规范        Standard Specification for Nickel-Chromium-Silicon Alloy (UNS N08330) Billets and Bars
(zzs/{*ro'mf ASTM B514-95(2002)e1         焊接镍铁铬合金管规范        Standard Specification for Welded Nickel-Iron-Chromium Alloy Pipe"m c:NfyI*u
ASTM B515-95(2002)         统一编制牌号为UNS N08120、NO8800、NO8810和N0811焊接合金管规范        Standard Specification for Welded UNS N08120, UNS N08800, UNS N08810, and UNS N08811 Alloy Tubes
gvm#T,A*eJQ ASTM B516-03         焊接镍铬铁合金(UNS N06600, UNS N06603, UNS N06025, 和UNS N06045)管规范        Standard Specification for Welded Nickel-Chromium-Iron Alloy (UNS N06600, UNS N06603, UNS N06025, and UNS N06045 TubesX@D A,s(~7gT A/j8^
ASTM B517-03         焊接的镍铬铁合金(UNS N06600, UNS N06603, UNS N06025, and UNS N06045)管规范        Standard Specification for Welded Nickel-Chromium-Iron-Alloy (UNS N06600, UNS N06603, UNS N06025, and UNS N06045) Pipe
E*nF&b+G'F ASTM B520-93(2002)e1         电子方面用镀锡包铜钢丝的规范        Standard Specification for Tin-Coated, Copper-Clad Steel Wire for Electronic Application
V9S6R,v$i.amC-M ASTM B521-98(2004)         钽和钽合金无缝和焊接管规范        Standard Specification for Tantalum and Tantalum Alloy Seamless and Welded Tubes
!jN"[7y"e2l,V [ ASTM B522-01         金银铂电接触合金规范        Standard Specification for Gold-Silver-Platinum Electrical Contact Alloy
A(` n3CG d R)c0w ASTM B523/B523M-02         无缝和焊接的锆及锆合金管材技术规范        Standard Specification for Seamless and Welded Zirconium and Zirconium Alloy Tubes
S ^4NhC(k;a(m ASTM B524/B524M-99         铝合金芯增强的同心绞捻铝导线(ACAR,1380/6201)        Standard Specification for Concentric-Lay-Stranded Aluminum Conductors, Aluminum-Alloy Reinforced (ACAR, 1350/6201)
-ZZ5[5{(u;i1e ASTM B527-93(2000)e1         用塔普-帕克(Tap-Pak)容量计测定耐火金属及化合物粉末的塔普(Tap)密度的试验方法        Standard Test Method for Determination of Tap Density of Metallic Powders and CompoundshLr3v7i R*iD2s
ASTM B528-99         烧结金属粉末样品的横向断裂强度的试验方法        Standard Test Method for Transverse Rupture Strength of Metal Powder SpecimensifK%SX1GJN]#N
ASTM B530-02         用磁性法测量磁性和非磁性基底上的电解沉积镀镍层厚度的方法        Standard Test Method for Measurement of Coating Thicknesses by the Magnetic Method: Electrodeposited Nickel Coatings on Magnetic and Nonmagnetic Substrates4^\+u ew2M)\
ASTM B532-85(2002)         电镀塑料表面外观        Standard Specification for Appearance of Electroplated Plastic Surfaces
bT4T3Jps ASTM B533-85(2004)         测量塑料表面金属镀层抗撕裂强度的标准试验方法        Standard Test Method for Peel Strength of Metal Electroplated PlasticsUp-m a9N(n7h4s6I
ASTM B534-01         铜钴铍合金及铜镍铍合金板、薄板、带材和轧制棒材        Standard Specification for Copper-Cobalt-Beryllium Alloy and Copper-Nickel-Beryllium Alloy Plate, Sheet, Strip, and Rolled Bar
$Y)d,e@ w ASTM B535-04         镍铁铬硅合金无缝管        Standard Specification for Nickel-Iron-Chromium-Silicon Alloys (UNS N08330 and N08332) Seamless Pipe and Tube.O9v`.~$k@y8\wD
ASTM B536-02         镍铁铬硅合金板、薄板及带材        Standard Specification for Nickel-Iron-Chromium-Silicon Alloys (UNS N08330 and N08332) Plate, Sheet, and Strip
PIc1|?^r*U ASTM B537-70(2002)         评定电镀板在大气暴露情况下耐腐蚀性能的标准惯例        Standard Practice for Rating of Electroplated Panels Subjected to Atmospheric Exposure
Ha3jojq G2F} ASTM B539-02e1         电气连接的接触电阻的测量方法(静态接触)        Standard Test Methods for Measuring Resistance of Electrical Connections (Static Contacts)
3D}"|k ]5ye'e,m ASTM B540-97(2002)         电接触用钯合金        Standard Specification for Palladium Electrical Contact Alloy^?+OF*qM8U,M
ASTM B541-01         电接触用金合金        Standard Specification for Gold Electrical Contact AlloyT`@;I-G,X
ASTM B542-04         电接点及其应用的相关术语        Standard Termninology Relating to Electrical Contacts and Their Usex5V!a"i2cp2?
ASTM B543-96(2003)         焊接的铜及铜合金热交换管        Standard Specification for Welded Copper and Copper-Alloy Heat Exchanger TubeK$@;F E$VR/pS
ASTM B545-97(2004)e1         电解沉积锡镀层        Standard Specification for Electrodeposited Coatings of Tin
?.vYU8gmg&v1r2g ASTM B546-04         电熔焊接镍铬钴钼合金(N06617),镍铁铬硅合金(N08330和N08332)镍铬铁合金(N06025)和镍铬铁硅合金(N06045)管的技术规范        Standard Specification for Electric Fusion-Welded Ni-Cr-Co-Mo Alloy (UNS N06617), Ni-Fe-Cr-Si Alloys (UNS N08330 and UNS N08332), Ni-Cr-Fe-Al Alloy (UNS N06603), Ni-Cr-Fe Alloy (UNS N06025), and Ni-Cr-Fe-Si Alloy (UNS N06045) Pipe
z]Oyt ASTM B547/B547M-02         铝及铝合金成形并用电弧焊焊接的圆管技术规范        Standard Specification for Aluminum and Aluminum-Alloy Formed and Arc-Welded Round Tube_7m6Z(n @D*sd
ASTM B548-03         压力容器用铝合金板的超声波检验        Standard Test Method for Ultrasonic Inspection of Aluminum-Alloy Plate for Pressure Vessels
$D#Ngb8Ix ra*S ASTM B549-00         包铝钢芯加强的同芯绞捻铝导线(ACSR/AW)        Standard Specification for Concentric-Lay-Stranded Aluminum Conductors, Aluminum-Clad Steel Reinforced (ACSR/AW)m6Xv_:K v
ASTM B550/B550M-02         锆及锆合金棒材和丝材技术规范        Standard Specification for Zirconium and Zirconium Alloy Bar and Wire
h[da;\p7ak ASTM B551/B551M-04         锆及锆合金带材、薄板材和厚板材技术规范        Standard Specification for Zirconium and Zirconium Alloy Strip, Sheet, and Plateg+_Z"Z{xiW
ASTM B552-98(2004)         水淡化厂用无缝和焊接铜/镍管        Standard Specification for Seamless and Welded Copper--Nickel Tubes For Water Desalting Plants3DJ7COt1e!Sm-z
ASTM B555-86(2002)         用滴定试验法测量电解沉积金属镀层厚度        Standard Guide for Measurement of Electrodeposited Metallic Coating Thicknesses by the Dropping Test
3Az1t MY ASTM B556-90(2002)         用点滴试验法测量薄镀铬层厚度        Standard Guide for Measurement of Thin Chromium Coatings by Spot Test?H \HlI_
ASTM B557-02a         锻造和铸造的铝及镁合金制品的拉伸试验        Standard Test Methods of Tension Testing Wrought and Cast Aluminum- and Magnesium-Alloy Products0dRf5g;iH
ASTM B557M-02a         锻造及铸造铝和镁合金产品的拉伸试验(米制)        Standard Test Methods of Tension Testing Wrought and Cast Aluminum- and Magnesium-Alloy Products [Metric]
x8s E$Kum ASTM B558-79(2003)         电镀用镍合金的制备        Standard Practice for Preparation of Nickel Alloys for Electroplating
T#| N0g)P ASTM B559-93(2002)e1         电气用镀镍包铜钢丝        Standard Specification for Nickel-Coated, Copper-Clad Steel Wire for Electronic Application'H"IE]A
ASTM B560-00         新锡铅合金        Standard Specification for Modern Pewter Alloys
|@g+RXg ASTM B561-94(1999)e1         精炼铂        Standard Specification for Refined Platinum
n+\iD"u.\&L9sz&r1ixI ASTM B562-95(1999)         精炼金        Standard Specification for Refined Gold
)n3x%Ix|4z1Z ASTM B563-01         电接触用钯银铜合金        Standard Specification for Palladium-Silver-Copper Electrical Contact Alloy R/x Q\ mf.p Mdm
ASTM B564-04         镍合金锻件        Standard Specification for Nickel Alloy Forgings
l#A!fh E ASTM B565-04         铝和铝合金铆钉及冷镦头丝与棒材的剪切试验        Standard Test Method for Shear Testing of Aluminum and Aluminum-Alloy Rivets and Cold-Heading Wire and Rods
yM"U5eYv-?Y ASTM B566-04         包铜铝丝        Standard Specification for Copper-Clad Aluminum Wire
#FEf2F!e-rL ASTM B567-98(2003)         用β射线反向散射法测量镀层厚度的试验方法        Standard Test Method for Measurement of Coating Thickness by the Beta Backscatter MethoddI/|8z^W
ASTM B568-98(2004)         用X射线光度法测量镀层厚度的试验方法        Standard Test Method for Measurement of Coating Thickness by X-Ray Spectrometry
5J5n-vi&g8h j%| ASTM B569-04         热交换管用窄薄型UNS No. C26000黄铜带材        Standard Specification for Brass Strip in Narrow Widths and Light Gage for Heat-Exchanger TubinghVWw` l Z
ASTM B570-01         铜铍合金锻件和挤压件        Standard Specification for Copper-Beryllium Alloy (UNS No. C17000 and C17200) Forgings and Extrusions
'kX;} A7AfC ASTM B571-97(2003)         金属镀层粘附性的试验方法        Standard Practice for Qualitative Adhesion Testing of Metallic Coatings!y2Q&M)Cn
ASTM B572-03         统一编制牌号为NO6002、NO6230、N12160和R30556棒材(盘条)电镀技术规范        Standard Specification for UNS N06002, UNS N06230, UNS N12160, and UNS R30556 Rod
biz X7LO4W6x4ec ASTM B573-00         镍钼铬铁合金棒        Standard Specification for Nickel-Molybdenum-Chromium-Iron Alloy (UNS N10003, N10242)* Rod
^7a] G9fv-Ma0r5m ASTM B574-04         低碳镍钼铬及低碳镍铬钼及低碳镍铬钼钨合金棒材的技术规范        Standard Specification for Low-Carbon Nickel-Chromium-Molybdenum, Low-Carbon Nickel-Molybdenum-Chromium-Tantalum, Low-Carbon Nickel-Chromium-Molybdenum-Copper, and Low-Carbon Nickel-Chromium-Molybdenum-Tungsten Alloy Rod
R+Q;`i~,?O7T7b ASTM B575-04         低碳镍钼铬、低碳镍铬钼、低碳镍铬钼铜合金及低碳镍铬钼钽合金板材的技术规范        Standard Specification for Low-Carbon Nickel-Chromium-Molybdenum, Low-Carbon Nickel-Chromium-Molybdenum-Copper, Low-Carbon Nickel-Chromium-Molybdenum-Tantalum, and Low-Carbon Nickel-Chromium-Molybdenum-Tungsten Alloy Plate, Sheet, and Strip
FQ/Z1ey&BFJ%r ASTM B576-94(1999)         电接触材料的电弧侵蚀试验        Standard Guide for Arc Erosion Testing of Electrical Contact Materials
t0B\5A0M&uu ASTM B577-93(2004)         铜的氢脆试验方法        Standard Test Methods for Detection of Cuprous Oxide (Hydrogen Embrittlement Susceptibility) in CopperY)F(V;T{g7kuv
ASTM B578-87(1999)         电镀层显微硬度的测量方法        Standard Test Method for Microhardness of Electroplated Coatings
e'NTJ&d|!\} ASTM B579-73(2004)         锡铅合金的电解沉积镀层(焊接板)        Standard Specification for Electrodeposited Coatings of Tin-Lead Alloy (Solder Plate)
WI|0[!Sa{8t:S ASTM B580-79(2000)         铝阳极氧化镀层        Standard Specification for Anodic Oxide Coatings on Aluminum
;AehFc`B;~(b g ASTM B581-02         镍铬铁钼铜合金条        Standard Specification for Nickel-Chromium-Iron-Molybdenum-Copper Alloy Rod/C,O,v)r9Q
ASTM B582-02         镍铬铁钼铜合金板、薄板及带材        Standard Specification for Nickel-Chromium-Iron-Molybdenum-Copper Alloy Plate, Sheet, and Strip
%H"mx)pg2?%N:F ASTM B584-04         普通用铜合金砂型铸件        Standard Specification for Copper Alloy Sand Castings for General Applications
$J#^*F)Z,{KFo.c ASTM B587-97(2003)         焊接黄铜管        Standard Specification for Welded Brass Tube
i M8| d0|j#h$t ASTM B588-88(2001)         用双束干涉显微技术测量透明涂层或不透明涂层厚度的试验方法        Standard Test Method for Measurement of Thickness of Transparent or Opaque Coatings by Double-Beam Interference Microscope Technique6Gi$}@j7x[)T
ASTM B589-94(1999)e1         精炼钯        Standard Specification for Refined Palladium
`*crqL0_]!a0j ASTM B591-98a         铜锌锡板、薄板、带材及轧制棒材        Standard Specification for Copper-Zinc-Tin and Copper-Zinc-Tin-Iron-Nickel Alloys Plate, Sheet, Strip, and Rolled Bar H-i.mtSX#V
ASTM B592-01         铜锌铝钴板、薄板、带材及轧制棒材        Standard Specification for Copper-Zinc-aluminum-Cobalt Alloy, Copper-Zinc-Tin-Iron Alloy Plate, Sheet, Strip, and Rolled BarT}'AEb
ASTM B593-96(2003)e1         铜合金弹簧材料的弯曲疲劳试验        Standard Test Method for Bending Fatigue Testing for Copper-Alloy Spring Materialsx'{"U0n5t
ASTM B594-02         航空设备用铝合金锻制品的超声波检验        Standard Practice for Ultrasonic Inspection of Aluminum-Alloy Wrought Products for Aerospace Applications8I-m8AS,S}
ASTM B595-95(2000)         铝粉末烧结结构部件标准规范        Standard Specification for Sintered Aluminum Structural Parts xAWC'B;R7KzSy`
ASTM B596-89(1999)         金铜合金电接触材料        Standard Specification for Gold-Copper Alloy Electrical Contact MaterialEgocC;Y)z
ASTM B598-98(2004)         抗拉试验中铜合金偏置屈服强度的测定        Standard Practice for Determining Offset Yield Strength in Tension for Copper AlloysHs;R'KF4Td
ASTM B599-92(2003)e1         稳定的镍铁铬钼钶合金板、薄板及带材        Standard Specification for Nickel-Iron-Chromium-Molybdenum-Columbium Stabilized Alloy (UNS N08700) Plate, Sheet, and Strip
-G` r:@ Xi'te"a ASTM B600-91(2002)         钛及钛合金表面的去垢和清洗        Standard Guide for Descaling and Cleaning Titanium and Titanium Alloy Surfaces!I!l*Cn.CZ{
ASTM B601-02         锻造及铸造的铜和铜合金回火标志        Standard Classification for Temper Designations for Copper and Copper Alloys―Wrought and Cast
;Xm7qpw@0s ASTM B602-88(1999)         金属及无机涂层的计数抽样试验方法        Standard Test Method for Attribute Sampling of Metallic and Inorganic Coatings
%J7j gPp\z ASTM B603-90(2001)         电热元件用拉制或轧制铁铬铝合金        Standard Specification for Drawn or Rolled Iron-Chromium-Aluminum Alloys for Electrical Heating Elements0m4u }%ap;f Az
ASTM B604-91(2003)e1         塑料表面装饰用铜加镍铬镀层        Standard Specification for Decorative Electroplated Coatings of Copper Plus Nickel Plus Chromium on Plastics/T%Y:nh8j&|
ASTM B605-95a(2004)         锡镍合金电解沉积镀层规范        Standard Specification for Electrodeposited Coatings of Tin-Nickel Alloy
E,@E;xrXSI { ASTM B606-02         钢芯加强的铝和铝合金导线用高强度镀锌(电镀)钢芯线        Standard Specification for High-Strength Zinc-Coated (Galvanized) Steel Core Wire for Aluminum and Aluminum-Alloy Conductors, Steel Reinforced+n&xL#y/U5L8KG2Y
ASTM B607-91(2003)         工程用自动催化镍硼铸件        Standard Specification for Autocatalytic Nickel Boron Coatings for Engineering Use
9A \n&iy3u`UDtz ASTM B608-02         焊接铜合金管        Standard Specification for Welded Copper-Alloy Pipe
hd"y_#C qb4L+Q VL ASTM B609/B609M-99(2004)         电气用退火及中温回火的1350型铝圆线        Standard Specification for Aluminum 1350 Round Wire, Annealed and Intermediate Tempers, for Electrical Purposes
tV0je-k*| ASTM B610-00e1         测量金属粉末样品因烧结产生尺寸变化的试验方法        Standard Test Method for Measuring Dimensional Changes of Metal Powder Specimens/j*Mj^!r}
ASTM B611-85(2000)e1         硬质合金的耐磨性的试验方法        Standard Test Method for Abrasive Wear Resistance of Cemented Carbides(w7rAyU
ASTM B612-00         铁青铜烧结轴承(油浸的)        Standard Specification for Iron Bronze Sintered Bearings (Oil-Impregnated)
H n'O!A2C z'o ASTM B613-76(2000)         滑动电触点用复合材料的微型电刷制备规范        Standard Guide for Preparing Specifications for Miniature Brushes of Composite Materials for Sliding Electric Contacts
{g xd:yP7G9cv^ ASTM B614-95(2000)         锆及锆合金表面的去垢与清洗        Standard Practice for Descaling and Cleaning Zirconium and Zirconium Alloy Surfaces
x er4@(ug2{l4UI ASTM B615-79(2000)         测定滑动电触点电接触噪音        Standard Practice for Measuring Electrical Contact Noise in Sliding Electrical ContactsI mN7I)z~|,c
ASTM B616-96(2000)         精炼铑        Standard Specification for Refined Rhodium{X#IvSW2T7]#nx
ASTM B617-98(2004)         电气接点用银币合金        Standard Specification for Coin Silver Electrical Contact AlloyG/Vyy!p8T`c
ASTM B618-03         铝合金熔模铸件技术规范        Standard Specification for Aluminum-Alloy Investment Castings'Xo8_x3j@T%pe6Y3B
ASTM B619-04         焊接的镍和镍钴合金管        Standard Specification for Welded Nickel and Nickel-Cobalt Alloy Pipe
Wz'V9G?N pI ASTM B620-03         镍铁铬钼合金板、薄板及带材        Standard Specification for Nickel-Iron-Chromium-Molybdenum Alloy (UNS N08320) Plate, Sheet, and Strip4l T{ t!SG8Q\y)V
ASTM B621-02         镍铁铬钼合金条        Standard Specification for Nickel-Iron-Chromium-Molybdenum Alloy (UNS N08320) Rode&W|9W0{
ASTM B622-04         无缝镍和镍钴合金管        Standard Specification for Seamless Nickel and Nickel-Cobalt Alloy Pipe and Tube@M0N.t.R3L*x
ASTM B624-99         电子设备用高强度高传导率铜合金线        Standard Specification for High-Strength, High-Conductivity Copper-Alloy Wire for Electronic Application2BF_V,@
ASTM B625-04         UNS NO8904、UNS NO8925、UNS NO8031、UNS NO8932和UNS NO8926板、薄板及带材        Standard Specification for UNS N08904, UNS N08925, UNS N08031, UNS N08932, UNS N08926, and UNS R20033 Plate, Sheet, and Strip
|8|+\V L~I5g*V IF ASTM B626-04         焊接的镍和镍钴合金管        Standard Specification for Welded Nickel and Nickel-Cobalt Alloy Tube
.L7h v$R y0^ML5k ASTM B628-98(2004)         电接触用银铜共晶合金        Standard Specification for Silver-Copper Eutectic Electrical Contact Alloy/A9N mkV w.W#v
ASTM B629-77(2003)         电镀用钼和钼合金的制备        Standard Practice for Preparation of Molybdenum and Molybdenum Alloys for Electroplating,Z0@I M*TC!Yr@nI`
ASTM B630-88(2001)         电镀用铬的制备        Standard Practice for Preparation of Chromium for Electroplating with Chromium
,C8QrJ] B ASTM B631-93(2004)         银钨电接触材料        Standard Specification for Silver-Tungsten Electrical Contact Materialshb6MH"nC0jJE@ O
ASTM B632/B632M-02         铝合金轧制支撑板        Standard Specification for Aluminum-Alloy Rolled Tread Plate
p"K$Ta[p"n ASTM B633-98e1         钢铁表面的电沉积锌镀层        Standard Specification for Electrodeposited Coatings of Zinc on Iron and Steelb XvBP{
ASTM B634-88(2004)e1         工程用铑电解沉积镀层        Standard Specification for Electrodeposited Coatings of Rhodium for Engineering Use:r$\.y'u4t&HsF~]
ASTM B635-00(2004)e1         镉锡机械沉积镀层        Standard Specification for Coatings of Cadmium-Tin Mechanically Depositedi5_8t }^t:r0\:a!D
ASTM B636-84(2001)         用螺旋收缩仪测量电镀金属镀层内应力的方法        Standard Test Method for Measurement of Internal Stress of Plated Metallic Coatings with the Spiral Contractometer+]$k6M5{u"qy7|
ASTM B637-03         高温设备用沉淀淬火镍合金棒、锻件及锻造坯料的制备        Standard Specification for Precipitation-Hardening Nickel Alloy Bars, Forgings, and Forging Stock for High-Temperature Service
2Qv \/u:m4DxKH.` ASTM B639-02         高温用沉积硬化钴合金(UNS R30155 and UNS R30816)条材、棒材、锻件和锻造坯料        Standard Specification for Precipitation Hardening Cobalt-Containing Alloys (UNS R30155 and UNS R30816) Rod, Bar, Forgings, and Forging Stock for High-Temperature Service
SL)?+ZJ,Dx1r5`M ASTM B640-00         空调及制冷设备用焊接铜及铜合金管        Standard Specification for Welded Copper Tube for Air Conditioning and Refrigeration Service"s}9yO {*NPt}
ASTM B643-00e1         铜铍合金无缝管        Standard Specification for Copper-Beryllium Alloy Seamless TubeL'?+L m:h x n3TLqx
ASTM B644-95(2003)         铜合金添加剂        Standard Specification for Copper Alloy Addition Agents
qU~Mo]"v ASTM B645-02         铝合金的平面应变断裂韧性试验        Standard Practice for Plane-Strain Fracture Toughness Testing of Aluminum Alloys2W*l3]2` xl"u8?r
ASTM B646-04         铝合金断裂韧性试验        Standard Practice for Fracture Toughness Testing of Aluminum Alloys!R}/LP2^CgUn(v:_x
ASTM B647-84(2000)         用维氏硬度仪测定铝合金压痕硬度的试验方法        Standard Test Method for Indentation Hardness of Aluminum Alloys by Means of a Webster Hardness Gage
X7B [ [l'Q8ew| ASTM B648-78(2000)         用巴氏压痕仪测定铝合金压痕硬度的试验方法        Standard Test Method for Indentation Hardness of Aluminum Alloys by Means of a Barcol Impressor
)h/t@ `-l^#? ASTM B649-02         镍铁铬钼铜低碳合金和镍铁铬钼铜氮低碳合金棒材及线材        Standard Specification for Ni-Fe-Cr-Mo-Cu Low-Carbon Alloy (UNS N08904), Ni-Fe-Cr-Mo-Cu-N Low-Carbon Alloys (UNS N08925, UNS N08031, and UNS N08926), and Cr-Ni-Fe-N Low-Carbon Alloy (UNS R20033) Bar and Wire7aMK nt(D3E(|&`
ASTM B650-95(2002)         铁基物上电沉积工程镀铬层        Standard Specification for Electrodeposited Engineering Chromium Coatings on Ferrous SubstratesiA5x2h!OQ
ASTM B651-83(2001)         用双束干涉显微镜测量镍+铬或铜+镍+铬电镀表面腐蚀部位的试验方法        Standard Test Method for Measurement of Corrosion Sites in Nickel Plus Chromium or Copper Plus Nickel Plus Chromium Electroplated Surfaces with the Double-Beam Interference Microscope
?9_ Imd ~O"{ ASTM B652/B652M-04         铌铪合金铸锭        Standard Specification for Niobium-Hafnium Alloy IngotsO!{0wCb1UwWV
ASTM B653/B653M-02         无缝和焊接锆及锆合金焊接管配件技术规范        Standard Specification for Seamless and Welded Zirconium and Zirconium Alloy Welding Fittings
1C6V$b,Z|| ASTM B654/B654M-04         铌-铪合金箔、薄板、带材和中厚板        Standard Specification for Niobium-Hafnium Alloy Foil, Sheet, Strip, and Plate;gq2x s_K
ASTM B655/B655M-04         铌铪合金棒材,棍材和线        Standard Specification for Niobium-Hafnium Alloy Bar, Rod, and Wire
D|N#q6H8z;c9E ASTM B657-92(2000)         硬质钨金微观结构的金相测定方法        Standard Test Method for Metallographic Determination of Microstructure in Cemented Tungsten Carbides
9{V(zLe'j ASTM B658/B658M-02         无缝和焊接锆及锆合金管道技术规范        Standard Specification for Seamless and Welded Zirconium and Zirconium Alloy Pipe
|1d in,i4b:yL ASTM B659-90(2003)         金属和无机物镀层厚度的测量方法        Standard Guide for Measuring Thickness of Metallic and Inorganic CoatingsL8Ir { RB
ASTM B660-02         铝及镁制品的包装/装箱        Standard Practices for Packaging/Packing of Aluminum and Magnesium Products
Nl7{\#{ ]-{ pz ASTM B661-03         镁合金的热处理        Standard Practice for Heat Treatment of Magnesium Alloys
/?%w S2b^!v ASTM B662-94(2000)         银钼电接触材料        Standard Specification for Silver-Molybdenum Electrical Contact Material
$}CQ'A9a9lnA"z ASTM B663-94(2000)         银钨硬质合金电接触材料        Standard Specification for Silver-Tungsten Carbide Electrical Contact Material
5X h^cA @P ASTM B664-90(2000)         含80%银20%石墨的滑动电接触材料        Standard Specification for 80% Silver-20% Graphite Sliding Contact Material
d9\1OTOmRJ ASTM B665-03         硫化钨硬质合金金相样品的制备        Standard Guide for Metallographic Sample Preparation of Cemented Tungsten Carbides
7H&hXP@} CY ASTM B666/B666M-01         铝和镁合金制品识别标记的标准惯例        Standard Practice for Identification Marking of Aluminum and Magnesium Products
U f%C9H z){ ASTM B667-97(2003)e1         测量电接触电阻用探测器的结构及使用        Standard Practice for Construction and Use of a Probe for Measuring Electrical Contact Resistance
F'J bJ%f!`b ASTM B668-00         UNS NO8028无缝管        Standard Specification for UNS N08028 Seamless Pipe and Tube,^3E%b)z@v&N(j K
ASTM B670-02         高温用沉淀硬化镍合金板、薄板及带材        Standard Specification for Precipitation-Hardening Nickel Alloy (UNS N07718) Plate, Sheet, and Strip for High-Temperature Service-eKLq|Jp\c7_
ASTM B671-81(1999)e1         精炼铱        Standard Specification for Refined Iridium'aMsX#F#_'x
ASTM B672-02         稳定的镍铁铬钼钶合金棒及线材        Standard Specification for Nickel-Iron-Chromium-Molybdenum-Columbium Stabilized Alloy (UNS N08700) Bar and Wire
2sY"LA6O1z`2f ASTM B673-96(2002)e1         UNS NO8904、UNS NO8925及UNS NO8926焊接管        Standard Specification for UNS N08904, UNS N08925, and UNS N08926 Welded Pipep:D2Y4x!]'`p
ASTM B674-96(2002)e1         UNS NO8904、UNS NO8925和UNS NO8926焊接管        Standard Specification for UNS N08904, UNS N08925, and UNS N08926 Welded TubeYhD4s5{S
ASTM B675-02         UNS NO8366及UNS NO8367焊接管        Standard Specification for UNS N08367 Welded Pipe_6U8z8c$n!D5v(Nh
ASTM B676-03         UNS NO8366及UNS NO8367焊接管        Standard Specification for UNS N08367 Welded Tubev}G"if
ASTM B677-04         UNS NO8904、UNS NO8925及UNS NO8926无缝管        Standard Specification for UNS N08904, UNS N08925, and UNS N08926 Seamless Pipe and Tube0`A%D-f c{R
ASTM B678-86(2001)         金属涂覆产品的软钎焊性试验方法        Standard Test Method for Solderability of Metallic-Coated Products
;K,y+}!R5}2l ASTM B679-98(2004)e1         工程用电沉积钯镀层        Standard Specification for Electrodeposited Coatings of Palladium for Engineering Use.d(w4B'J-BVI
ASTM B680-80(2000)         用酸溶解法测定铝的阳极镀层封闭质量的试验方法        Standard Test Method for Seal Quality of Anodic Coatings on Aluminum by Acid Dissolution7_8lOHn&u
ASTM B682-01         电导体的米制尺寸        Standard Specification for Standard Metric Sizes of Electrical Conductorsl ~3cH*^!|%v5~n
ASTM B683-01         纯钯电接触材料        Standard Specification for Pure Palladium Electrical Contact Material z6@4{~Y8r~ W
ASTM B684-97(2002)         铂铱电接触材料        Standard Specification for Platinum-Iridium Electrical Contact Materials~X+\"j{w
ASTM B685-01         钯铜电接触材料        Standard Specification for Palladium-Copper Electrical Contact Material
%\PE;e9DK8J:l ASTM B686-03         高强度铝合金铸件        Standard Specification for Aluminum Alloy Castings, High-Strength
2]E,^Lr2bh? ASTM B687-99         镀黄铜、镀铜和镀铬管接头        Standard Specification for Brass, Copper, and Chromium-Plated Pipe Nipples
,d%r(A w&l~0bM ASTM B688-96(2004)         铬镍钼铁板、薄板及带材        Standard Specification for Chromium-Nickel-Molybdenum-Iron (UNS N08366 and UNS N08367) Plate, Sheet, and Strip
'm:QANl S#]H?Q ASTM B689-97(2003)         电镀工程镀镍层        Standard Specification for Electroplated Engineering Nickel Coatings
[l r:Ow ASTM B690-02         铁镍铬钼合金无缝管        Standard Specification for Iron-Nickel-Chromium-Molybdenum Alloys (UNS N08366 and UNS N08367) Seamless Pipe and Tube
{g.I;OlI5m/E7H2C6U ASTM B691-02         铁镍铬钼合金条、棒及线材        Standard Specification for Iron-Nickel-Chromium-Molybdenum Alloys (UNS N08366 and UNS N08367) Rod, Bar, and Wire)T j0iW&WY!su8E
ASTM B692-90(2000)         含75%银25%石墨的滑动接触材料        Standard Specification for 75% Silver-25% Graphite Sliding Contact Material
(r;B0[?I9p ASTM B693-91(2001)         银镍电接触材料        Standard Specificationfor Silver-Nickel Electrical Contact Materials X.HFp#Byw
ASTM B694-03         电缆屏蔽用铜、铜合金、包铜青铜、包铜不锈钢和包铜合金钢薄板和带材        Standard Specification for Copper, Copper-Alloy, Copper-Clad Bronze (CCB), Copper-Clad Stainless Steel (CCS), and Copper-Clad Alloy Steel (CAS) Sheet and Strip for Electrical Cable Shielding
D H&@KLoI ASTM B695-04         钢铁表面的锌机械沉积镀层        Standard Specification for Coatings of Zinc Mechanically Deposited on Iron and Steel
B:A"bgRJ.SW ASTM B696-00         镉机械沉积镀层        Standard Specification for Coatings of Cadmium Mechanically Deposited|:o/Is'B-z
ASTM B697-88(1999)         电沉积金属镀层和无机镀层检验用抽样方案选择的标准导则        Standard Guide for Selection of Sampling Plans for Inspection of Electrodeposited Metallic and Inorganic Coatings;hi`b(rF]k3^B:Q
ASTM B698-02         无缝和焊接铜及铜合金铅管波导管的分类        Standard Classification for Seamless Copper and Copper Alloy Plumbing Pipe and Tube#T+c&R#CC
ASTM B699-86(2003)         钢铁表面镉真空沉积镀层        Standard Specification for Coatings of Cadmium Vacuum-Deposited on Iron and Steel ?,nix\
ASTM B700-97(2002)         工程用银电沉积镀层        Standard Specification for Electrodeposited Coatings of Silver for Engineering Use&dte&w*z/`Vir
ASTM B701/B701M-00         同芯绞捻自阻钢芯加强铝导线(ACSR/SD)        Standard Specification for Concentric-Lay-Stranded Self-Damping Aluminum Conductors, Steel Reinforced (ACSR/SD)S,vIeX4b m4K
ASTM B702-93(2004)         铜钨电触点材料        Standard Specification for Copper-Tungsten Electrical Contact Materialq%e`A#{P5@
ASTM B703-94(1999)e1         用阿诺德仪表测定金属粉末表观密度的试验方法        Standard Test Method for Apparent Density of Powders Using Arnold Meter
o4PWX p3i*Bh$g W.W ASTM B704-03         焊接UNS NO6625和UNS NO8825合金管        Standard Specification for Welded UNS N06625, UNS N06219 and UNS N08825 Alloy Tubes
r)NF&Z2yy ASTM B705-03         镍合金焊接管        Standard Specification for Nickel-Alloy (UNS N06625, N06219 and N08825) Welded Pipe K^}@] iT5i
ASTM B706-00         无缝铜合金管材规范(UNS No. C69100)        Standard Specification for Seamless Copper Alloy (UNS No. C69100) Pipe and Tube5T,j4oT4eX&fY _z
ASTM B708-01         钽和钽合金板,薄板和带材        Standard Specification for Tantalum and Tantalum Alloy Plate, Sheet, and Strip
;qOAh$]2PY7v j ASTM B709-04         铁镍铬钼合金板材,薄板和带材        Standard Specification for Iron-Nickel-Chromium-Molybdenum Alloy (UNS N08028)* Plate, Sheet, and Strip
Q6e `2i/L.Wy ASTM B710-04         镍铁铬硅合金焊接管        Standard Specification for Nickel-Iron-Chromium-Silicon Alloy Welded Pipe
.b{ Yk E,A,T ASTM B711-99         钢芯加强同芯绞捻铝合金导线        Standard Specification for Concentric-Lay-Stranded Aluminum-Alloy Conductors, Steel Reinforced (AACSR) (6201)
0Z0Rd#O%O?9i ASTM B712-93(1999)         氧化银镉接触材料用钠和钾含量的测定        Standard Guide for Determination of Sodium and Potassium Content For Silver-Cadmium Oxide Contact Materials l/}-x4iU:q
ASTM B715-96(2001)         导电用烧结铜结构零件        Standard Specification for Sintered Copper Structural Parts for Electrical Conductivity Applications
2@;k P9lL"vK#L!Yb ASTM B717-96(2000)         精炼钌        Standard Specification for Refined Ruthenium
BindK:m'| ASTM B718-00         镍铬钼钴钨铁硅合金板,薄板和带材        Standard Specification for Nickel-Chromium-Molybdenum-Cobalt-Tungsten-Iron-Silicon Alloy (UNS N06333) Plate, Sheet, and Strip
pN Sf;P)`K3r ASTM B719-00         镍铬钼钴钨铁硅合金棒材        Standard Specification for Nickel-Chromium-Molybdenum-Cobalt-Tungsten-Iron-Silicon Alloy (UNS N06333) Bar
9j Ip u2TW.}ISt A ASTM B721-91(1999)         粉末冶金(P/M)零件的显微硬度和外层厚度的测试方法        Standard Test Method for Microhardness and Case Depth of Powder Metallurgy (P/M) Parts7w*{jG \
ASTM B722-02         镍铬钼钴钨铁硅合金无缝管        Standard Specification for Nickel-Chromium-Molybdenum-Cobalt-Tungsten-Iron-Silicon Alloy (UNS N06333) Seamless Pipe and Tube
H Y {mZjk ASTM B723-00         镍铬钼钴钨铁硅合金焊接管        Standard Specification for Nickel-Chromium-Molybdenum-Cobalt-Tungsten-Iron-Silicon Alloy (UNS N06333) Welded Pipe
p;a(b-@q9S ASTM B724-00         用新式轻便非卡尺型仪器测量铝合金压痕硬度的试验方法        Standard Test Method for Indentation Hardness of Aluminum Alloys by Means of a Newage, Portable, Non-Caliper-Type InstrumentG Y8L_A
ASTM B725-93(2003)e1         焊接镍和镍铜合金管        Standard Specification for Welded Nickel (UNS N02200/UNS N02201) and Nickel Copper Alloy (UNS N04400) Pipeg`?"n cZw
ASTM B726-02         镍铬钼钴钨铁硅合金焊接管        Standard Specification for Nickel-Chromium-Molybdenum-Cobalt-Tungsten-Iron-Silicon Alloy (UNS N06333) Welded Tube
1O+k.Eo4o&Q+cA;t;i_ ASTM B727-04         电镀用塑料材料制备        Standard Practice for Preparation of Plastics Materials for Electroplating
0tU$j"n$}vj:G6Z kR ASTM B729-00         统一编制牌号为N0820,NO8026和NO8024无缝镍合金管的技术规范        Standard Specification for Seamless UNS N08020, UNS N08026, and UNS N08024 Nickel-Alloy Pipe and Tubec!^ e rFpi3HKg
ASTM B731-96(2001)         60%钯40%银电触点材料        Standard Specification for 60% Palladium-40% Silver Electrical Contact Materialz9q)`{4S7D[
ASTM B733-04         金属表面自动催化镍磷涂层        Standard Specification for Autocatalytic (Electroless) Nickel-Phosphorus Coatings on Metal
NOq9@9W!IHL-r"| ASTM B734-97(2003)e1         工程用电沉积镀铜        Standard Specification for Electrodeposited Copper for Engineering Uses
n2UN^&b4tco ASTM B735-95(2000)         用硝酸蒸汽测试金属基体上金涂层孔隙度的方法        Standard Test Method for Porosity in Gold Coatings on Metal Substrates by Nitric Acid Vapor){&J|$Z:P9Si
ASTM B736-00         铝,铝合金和铝包层钢电缆屏蔽坯料        Standard Specification for Aluminum, Aluminum Alloy and Aluminum-Clad Steel Cable Shielding Stock
4DS7I$}y+^H ASTM B737-01         热轧或/和冷加工成形的铪条和线材        Standard Specification for Hot-Rolled and/or Cold-Finished Hafnium Rod and Wire
'e;po$KvXl ASTM B738-03         电导线用成束细线和成束绞捻绳索铜导线        Standard Specification for Fine-Wire Bunch-Stranded and Rope-Lay Bunch-Stranded Copper Conductors for Use as Electrical Conductors
k;xH4r7_g7P ASTM B739-03         钼铁铬硅合金焊接管        Standard Specification for Nickel-Iron-Chromium-Silicon Alloy Welded Tube
_e Ns+mP(N ASTM B740-02         铜镍锡旋节合金带材        Standard Specification for Copper-Nickel-Tin Spinodal Alloy Strip
J2r*Q7kY4pq2p9T ASTM B741-95(2000)         通过纸电谱法测量金属基物上金涂层孔隙度的测试法        Standard Test Method for Porosity In Gold Coatings On Metal Substrates By Paper Electrography;O:l;g&U1^gS+H
ASTM B742-90(2000)         电接触用已加工优质银材料        Standard Specification for Fine Silver Electrical Contact Fabricated Material)s8n1[fCbg:B){(t6r5W
ASTM B743-00         无缝铜螺旋管        Standard Specification for Seamless Copper Tube in Coils
Gs4Jcz#h-Oc7} ASTM B744/B744M-99         波纹铝管用铝合金薄板        Standard Specification for Aluminum Alloy Sheet for Corrugated Aluminum Pipe
u(SP%Ie Z7O+[ PB ASTM B745/B745M-97         下水道和排水系统用波纹铝管        Standard Specification for Corrugated Aluminum Pipe for Sewers and Drains
cco O zv[ h ASTM B746/B746M-02         现场栓接管,管拱和拱用波纹铝合金结构板        Standard Specification for Corrugated Aluminum Alloy Structural Plate for Field-Bolted Pipe, Pipe-Arches, and Arches
mW0B [K I3e+q ASTM B747-02         铜锆合金板材和带材        Standard Specification for Copper-Zirconium Alloy Sheet and Strip
\6N-sNH#R ASTM B748-90(2001)         用扫描电子显微镜测量横截面测定金属涂层厚度的方法        Standard Test Method for Measurement of Thickness of Metallic Coatings by Measurement of Cross Section with a Scanning Electron Microscope
z*G1L+C1vr d ASTM B749-03         铅和铅合金带材,薄板和中厚板产品        Standard Specification for Lead and Lead Alloy Strip, Sheet, and Plate Products
JLHe` ASTM B750-03         热浸涂层用锌5%铝铈合金锭        Standard Specification for GALFAN (Zinc-5 % Aluminum-Mischmetal) Alloy in Ingot Form for Hot-Dip Coatings D^J8IDxm$Z
ASTM B751-03         镍和镍合金无缝和焊接管        Standard Specification for General Requirements for Nickel and Nickel Alloy Welded Tube
HJ e$AF ASTM B752-01         通用耐腐蚀锆基铸件        Standard Specification for Castings, Zirconium-Base, Corrosion Resistant, for General Application
,?K+}'s d$V[ ASTM B753-01         恒温器组件用合金        Standard Specification for Thermostat Component Alloys
V-Y3|n[!j3@B{7w7s#P ASTM B754-89(1999)e1         铜及铜合金带材平面偏差的测量和记录的测试方法        Standard Test Method for Measuring and Recording the Deviations from Flatness in Copper and Copper Alloy Strip
'HB4v/We2Lc,q/p ASTM B755-00         镍铬钼钨合金板,薄板和带材        Standard Specification for Nickel-Chromium-Molybdenum-Tungsten Alloys (UNS N06110) Plate, Sheet, and Strip/]:KITJ
ASTM B756-00         镍铬钼钨合金条和棒        Standard Specification for Nickel-Chromium-Molybdenum-Tungsten Alloy (UNS N06110) Rod and Bar Ed;O$_,A"QpM nQ6o
ASTM B757-00         镍铬钼钨合金焊接管        Standard Specification for Nickel-Chromium-Molybdenum-Tungsten-Alloys (UNS N06110) Welded Pipe N4WE:a(wpX]#{
ASTM B758-00         镍铬钼钨合金焊接管        Standard Specification for Nickel-Chromium-Molybdenum-Tungsten Alloys (UNS N06110) Welded Tube _(hA'oY-]+|F*J Z
ASTM B759-00         镍铬钼钨合金管        Standard Specification for Nickel-Chromium-Molybdenum-Tungsten Alloys (UNS N06110) Pipe and Tube~[ yr6a4H6CsU
ASTM B760-86(1999)         钨板,薄板和箔        Standard Specification for Tungsten Plate, Sheet, and Foil
oxl l0J HN ASTM B761-02         通过X射线重力沉积监测的高温溶点金属及其化合物粒度的测试方法        Standard Test Method for Particle Size Distribution of Metal Powders and Related Compounds by X-Ray Monitoring of Gravity SedimentationJ&d"^$ZU-IX
ASTM B762-90(1999)         金属涂层和无机物涂层的计量抽样        Standard Test Method of Variables Sampling of Metallic and Inorganic Coatings
.zXH Av? st ASTM B763-98         阀门用铜合金砂型铸件        Standard Specification for Copper Alloy Sand Castings for Valve Applicationb7v)]"y SA e ^*zl
ASTM B764-04         多层镍镀层中单层的同步厚度和电化学电势测定方法(STEP试验)        Standard Test Method for Simultaneous Thickness and Electrode Potential Determination of Individual Layers in Multilayer Nickel Deposit (STEP Test)
l U8eN8V?X@ ASTM B765-03         电沉积镀层和相关金属镀层孔隙度试验的选择        Standard Guide for Selection of Porosity and Gross Defect Tests for Electrodeposits and Related Metallic Coatings
m0w;w$[8c6U:vy Kk ASTM B766-86(2003)         镉电沉积涂层        Standard Specification for Electrodeposited Coatings of Cadmium
!L QI,eN(}0Z1Y(d7F d ASTM B767-88(2001)         用重量分析法和其它化学分析法测定电沉积涂层及相关涂层单位面积的质量        Standard Guide for Determining Mass Per Unit Area of Electrodeposited and Related Coatings by Gravimetric and Other Chemical Analysis Procedures
J\8i+?9G ASTM B768-99(2004)         铜钴铍合金带材和板材        Standard Specification for Copper-Cobalt-Beryllium Alloy and Copper-Nickel-Beryllium Alloy Strip and Sheet
u`L!pV |-N ASTM B769-94(2000)         铝合金的剪切试验        Standard Test Method for Shear Testing of Aluminum AlloysQ M WJ4r"M
[xie 在 2009-10-17 10:27:39 编辑过]
inching motor - 渐进马达,点动马达 (0) 投诉
P:2008-10-15 11:51:29
看的头晕,不过还是谢谢,起码不用金币 呵呵
night shift - 夜班 (0) 投诉
P:2010-08-27 15:36:54
这样的前辈就是好,不要我们的金币。想得周到
water station - 给水站 (0) 投诉
P:2011-06-24 23:24:51
多谢分享
Zellon - 泽龙塑料(一种四氯乙烯商品名) (0) 投诉
P:2011-12-08 08:38:01
非常感谢拿出来学习
near field pattern - 近场图(在靠近光纤出射端观察到的光功率分布图形) (0) 投诉
P:2012-02-21 10:04:01
求标准ASTM B 498
conveyer - 传送器,运输机 (0) 投诉
P:2013-12-10 08:25:05
不错
unidirectional lay - 同向绞合,同方向绞合 (0) 投诉
