首页 > 标准讨论 培训学习
[标准信息] ASTM-B系列标准目录 [截至2005年]
P:2008-10-07 10:50:34
lQKT&a3\.W ASTM B188-02         汇流无缝铜管        Standard Specification for Seamless Copper Bus Pipe and Tube-gWq^U4MGv(n&C
ASTM B193-02         导电材料电阻率的测试方法        Standard Test Method for Resistivity of Electrical Conductor Materials
/QIs m-o ASTM B194-01e1         铜铍合金中厚板、薄板、带材和轧制棒材        Standard Specification for Copper-Beryllium Alloy Plate, Sheet, Strip, and Rolled Bar
~Z}#v6iw j%l ASTM B196/B196M-03         铜铍合金条及棒        Standard Specification for Copper-Beryllium Alloy Rod and BarW/p jJ~$? j`H;w,n
ASTM B197/B197M-01         铜铍合金线        Standard Specification for Copper-Beryllium Alloy Wire9vT#YL}/A
ASTM B199-99         镁合金永久型铸件        Standard Specification for Magnesium-Alloy Permanent Mold CastingsM7YO4k7Zc*_`K
ASTM B200-85(2004)         钢及铁合金表面铅和铅锡合金的电解沉积镀层        Standard Specification for Electrodeposited Coatings of Lead and Lead-Tin Alloys on Steel and Ferrous Alloys'yz3O3Dt.eI
ASTM B201-80(2000)         锌和镉的表面铬酸盐覆层试验        Standard Practice for Testing Chromate Coatings on Zinc and Cadmium Surfaces
2cc2kj%{` ASTM B206/B206M-97(2002)         铜镍锌合金线(镍银)和铜镍合金线        Standard Specification for Copper-Nickel-Zinc Alloy (Nickel Silver) Wire and Copper-Nickel Alloy Wire
~R|sn],u[ ASTM B208-04         砂型、永久型、离心型和连续铸造铸件用的铜基合金拉伸试验样件制备标准惯例        Standard Practice for Preparing Tension Test Specimens for Copper Alloy Sand, Permanent Mold, Centrifugal, and Continuous Castings
Tg4~#[Ds ASTM B209-04         铝及铝合金薄板和中厚板的技术规范        Standard Specification for Aluminum and Aluminum-Alloy Sheet and Plate
g|8u` ` R ASTM B209M-04         铝及铝合金薄板和中厚板的技术规范(米制)        Standard Specification for Aluminum and Aluminum-Alloy Sheet and Plate [Metric]
Z,P4c5ApiiO ASTM B210-02         拉制无缝铝和铝合金管        Standard Specification for Aluminum and Aluminum-Alloy Drawn Seamless Tubes5oo ]WTf.[HEx
ASTM B210M-02         拉制无缝铝和铝合金管(米制)        Standard Specification for Aluminum and Aluminum-Alloy Drawn Seamless Tubes [Metric]b g.is[Qpf
ASTM B211-03         铝及铝合金棒材、条材和线材        Standard Specification for Aluminum and Aluminum-Alloy Bar, Rod, and Wire
8j"LF4_U3SW ASTM B211M-03         铝及铝合金棒材、条材和线材(米制)        Standard Specification for Aluminum and Aluminum-Alloy Bar, Rod, and Wire [Metric]7U!O^O:y
ASTM B212-99         高流动性金属粉末表观密度的测试方法        Standard Test Method for Apparent Density of Free-Flowing Metal Powders Using the Hall Flowmeter Funnel
6tn"B;C#R ASTM B213-03         金属粉末流速的测试方法        Standard Test Method for Flow Rate of Metal Powders
`8npLGn G#E ASTM B214-99         粒状金属粉末的筛分试验方法        Standard Test Method for Sieve Analysis of Metal Powders&oS Y/{0V)e"I.ILL
ASTM B215-96         金属粉末的最后批量抽样方法        Standard Practices for Sampling Finished Lots of Metal Powders ^3q[[;`*r7yZ
ASTM B216-97(2003)         锻制品及合金用韧性火法精炼铜-精炼型材        Standard Specification for Tough-Pitch Fire-Refined Copper―Refinery Shapes
Khc/e M2s Z ASTM B221-02         铝及铝合金挤压制条、棒、线、管和型材        Standard Specification for Aluminum and Aluminum-Alloy Extruded Bars, Rods, Wire, Profiles, and TubesMTnC%T:[
ASTM B221M-02         铝和铝合金挤压制棒材、条材、线材、型材和管材(米制)        Standard Specification for Aluminum and Aluminum-Alloy Extruded Bars, Rods, Wire, Profiles, and Tubes [Metric]
S*T;u0w })O ASTM B223-03         恒温器用复合金属的弹性模量测试法(悬臂梁法)        Standard Test Method for Modulus of Elasticity of Thermostat Metals (Cantilever Beam Method)`a%N h h$B
ASTM B224-04         铜的分类方法        Standard Classification of Coppers
`uJDC4TN ASTM B226-04         有心的圆形同心绞捻铜导线        Standard Specification for Cored, Annular, Concentric-Lay-Stranded Copper Conductors
;LR(C$CN`P} Aq%H ASTM B227-04         冷拉包铜钢丝        Standard Specification for Hard-Drawn Copper-Clad Steel Wire ^ ^)SdV
ASTM B228-04         同心绞捻的包铜钢导线        Standard Specification for Concentric-Lay-Stranded Copper-Clad Steel Conductors
tb?#R_$J|(ob ASTM B229-04         同心绞捻的铜与包铜钢丝复合导线        Standard Specification for Concentric-Lay-Stranded Copper and Copper-Clad Steel Composite Conductors
g/\v#h#L7oIh ASTM B230/B230M-99(2004)         电气用1350-H19型铝线        Standard Specification for Aluminum 1350-H19 Wire for Electrical Purposes
t^`/Y} d ASTM B231/B231M-04         同心绞捻铝1350导线        Standard Specification for Concentric-Lay-Stranded Aluminum 1350 Conductors"_yj#Z2M%\x"k
ASTM B232/B232M-01e1         涂覆钢芯加强的同心绞捻铝导线(ACSR)        Standard Specification for Concentric-Lay-Stranded Aluminum Conductors, Coated-Steel Reinforced (ACSR)
M;R'?7He6f ASTM B233-97(2003)e1         电气用1350铝拉制坯料        Standard Specification for Aluminum 1350 Drawing Stock for Electrical Purposes
phU/h }0[ ASTM B234-02         冷凝器及热交换器用拉制铝和铝合金无缝管        Standard Specification for Aluminum and Aluminum-Alloy Drawn Seamless Tubes for Condensers and Heat Exchangers
]GVN4D1V_ ASTM B234M-02         冷凝器及热交换器用拉制铝和铝合金无缝管(米制)        Standard Specification for Aluminum and Aluminum-Alloy Drawn Seamless Tubes for Condensers and Heat Exchangers [Metric] I/j#n^],Ik
ASTM B236-00         电气用铝棒(汇流条)        Standard Specification for Aluminum Bars for Electrical Purposes (Bus Bars)
E)n buv,_8a'W ASTM B236M-00         电气用铝棒(汇流条)(米制)        Standard Specification for Aluminum Bars for Electrical Purposes (Bus Bars) [Metric]et lnx@v
ASTM B237-01         精炼锑标准规范        Standard Specification for Refined Antimony
q1I(^0Y.O({ ASTM B240-03         压模铸造用锌及锌铝合金锭        Standard Specification for Zinc and Zinc-Aluminum (ZA) Alloys in Ingot Form for Foundry and Die CastingsPv\.HMkBo,NZ*P~
ASTM B241/B241M-02         铝及铝合金无缝管和挤压制无缝管        Standard Specification for Aluminum and Aluminum-Alloy Seamless Pipe and Seamless Extruded Tube9y|3s9V`-W"o
ASTM B242-99         电镀用高碳钢的制备        Standard Guide for Preparation of High-Carbon Steel For Electroplating aq$eP J!A0CR*l
ASTM B243-04a         粉末冶金的术语        Standard Terminology of Powder Metallurgy R+V/`E]u|c
ASTM B244-97(2002)         用涡流仪器测量铝阳极镀层及其它非磁性基底金属绝缘体电镀层厚度的方法        Standard Test Method for Measurement of Thickness of Anodic Coatings on Aluminum and of Other Nonconductive Coatings on Nonmagnetic Basis Metals with Eddy-Current Instruments
U.Y ou+D&J6S ASTM B246-00         电工用中硬拉和硬拉镀锡铜线材的标准规范        Standard Specification for Tinned Hard-Drawn and Medium-Hard-Drawn Copper Wire for Electrical Purposes \%|5L F:ck)FR
ASTM B247-02a         铝和铝合金压模锻件、手工锻件和轧制环锻件        Standard Specification for Aluminum and Aluminum-Alloy Die Forgings, Hand Forgings, and Rolled Ring Forgings
th%r;TS ASTM B247M-02a         铝及铝合金压模锻件、手工锻件和轧制环形锻件(米制)        Standard Specification for Aluminum and Aluminum-Alloy Die Forgings, Hand Forgings, and Rolled Ring Forgings [Metric]A@H feh|&]9U^
ASTM B248-01e1         锻造铜及铜合金板、薄板、带及轧制棒材        Standard Specification for General Requirements for Wrought Copper and Copper-Alloy Plate, Sheet, Strip, and Rolled BaruqCsg QnV
ASTM B248M-01e1         锻造铜及铜合金板、薄板、带及轧制棒材(米制)        Standard Specification for General Requirements for Wrought Copper and Copper-Alloy Plate, Sheet, Strip and Rolled Bar [Metric]+x1Oa @7EF(DC`G
ASTM B249/B249M-02         铜和铜合金棒材、型材及锻件        Standard Specification for General Requirements for Wrought Copper and Copper-Alloy Rod, Bar, Shapes and Forgings
Y0S_4rB4[ ASTM B250/B250M-01         锻造铜合金丝        Standard Specification for General Requirements for Wrought Copper Alloy Wire `c{s;S0aT8G
ASTM B251-02e1         锻制无缝铜及铜合金管        Standard Specification for General Requirements for Wrought Seamless Copper and Copper-Alloy Tuber?2V m(n*je
ASTM B251M-97(2003)         锻制无缝铜及铜合金管(米制)        Standard Specification for General Requirements for Wrought Seamless Copper and Copper-Alloy Tube [Metric] j+s1Yk S3LL%Y
ASTM B252-92(2004)         电镀层和转化涂层用锌合金压模铸件的制备        Standard Guide for Preparation of Zinc Alloy Die Castings for Electroplating and Conversion Coatings
$C@ jX cPh tL ASTM B253-87(1999)e1         电镀用铝合金的制备        Standard Guide for Preparation of Aluminum Alloys for Electroplatingu%nx6Kr^&W$B8q
ASTM B254-92(2004)e1         不锈钢上各类金属电镀的标准惯例        Standard Practice for Preparation of and Electroplating on Stainless Steel
$@1uXU9^+M T5|\ ASTM B258-02         作电导体的实心圆导线的美国线规的标准公称直径和横截面积的技术规范        Standard Specification for Standard Nominal Diameters and Cross-Sectional Areas of AWG Sizes of Solid Round Wires Used as Electrical Conductors
m_ G"@J? p!Vn ASTM B263-04         多股绞合导线横截面积的测试方法        Standard Test Method for Determination of Cross-Sectional Area of Stranded Conductors
OCw@ A!Yt ASTM B265-03         钛及钛合金板、薄板及带材        Standard Specification for Titanium and Titanium Alloy Strip, Sheet, and Plate
Wm0{a v9] ASTM B267-90(2001)         绕线电阻器用电阻丝        Standard Specification for Wire for Use In Wire-Wound Resistors
Cs4z CjQLo ASTM B271-96(2003)         铜基合金离心铸件的技术规范        Standard Specification for Copper-Base Alloy Centrifugal Castings F AhzAC5`
ASTM B272-02         有精制边缘的(轧制或拉制的)扁铜制品(扁丝或带)        Standard Specification for Copper Flat Products with Finished (Rolled or Drawn) Edges (Flat Wire and Strip)
vjvH2^y8y ASTM B275-04         某些锻造和锻造有色金属及合金统一牌号编制标准惯例        Standard Practice for Codification of Certain Nonferrous Metals and Alloys, Cast and Wrought&DRFPj'x
ASTM B276-91(2000)         硬质合金表观孔隙率的测试方法        Standard Test Method for Apparent Porosity in Cemented Carbideso~9GS&ZF-s"NA$M
ASTM B277-95(2001)         电接触材料硬度的测试方法        Standard Test Method for Hardness of Electrical Contact MaterialsM-Rv"FKKJ6AE
ASTM B279-04         制造磁导线用方形和矩形软裸铜线及铝线硬度的测试方法        Standard Test Method for Stiffness of Bare Soft Square and Rectangular Copper and Aluminum Wire for Magnet Wire Fabrication
l7P}0_C.Th ASTM B280-03         空气调节及制冷设备用无缝铜管        Standard Specification for Seamless Copper Tube for Air Conditioning and Refrigeration Field Service
k8~/c HD!ha^O ASTM B281-88(2001)         电镀层和转化镀层用铜和铜基合金的制备        Standard Practice for Preparation of Copper and Copper-Base Alloys for Electroplating and Conversion Coatings
&a#SK!W+|t3h;v ASTM B283-04         铜及铜合金压模锻件(热压)        Standard Specification for Copper and Copper-Alloy Die Forgings (Hot-Pressed)[d{PU[.`
ASTM B286-02         电气设备用铜连接线        Standard Specification for Copper Conductors for Use in Hookup Wire for Electronic Equipment&RY bczqA9eaH
ASTM B294-92(2001)         硬质合金硬度的测试方法        Standard Test Method for Hardness Testing of Cemented Carbides.p'D{X&UQ
ASTM B296-03         铸造和锻造镁合金的回火标志        Standard Practice for Temper Designations of Magnesium Alloys, Cast and Wrought
O ?O nqz ASTM B298-99e1         镀银的软的或退火的铜线        Standard Specification for Silver-Coated Soft or Annealed Copper Wire
f[4{R9k7p^]0\P ASTM B299-01         海绵钛        Standard Specification for Titanium SpongeG-i"s Fw&b
ASTM B301/B301M-04         易切削铜条及铜棒        Standard Specification for Free-Cutting Copper Rod, Bar, Wire and ShapesL.BIoS2I.x$y!z
ASTM B302-02         无螺纹铜管        Standard Specification for Threadless Copper Pipe, Standard Sizes
3hf6a-DfLb ASTM B306-02         铜排水管(DWV)        Standard Specification for Copper Drainage Tube (DWV)
:KfiCX+U IB ASTM B308/B308M-02         6061-T6型铝合金结构型材        Standard Specification for Aluminum-Alloy 6061-T6 Standard Structural Profiles
`;L%H,x3BbbTQ ASTM B311-93(2002)e1         孔隙度小于2%的粉末冶金材料密度的标准测试方法        Test Method for Density Determination for Powder Metallurgy (P/M) Materials Containing Less Than Two Percent Porosity&}Vn1i$P1ag
ASTM B312-96(2002)         金属粉末生压坯强度的测试方法        Standard Test Method for Green Strength for Compacted Metal Powder Specimens
|0I:Q@.O ASTM B313/B313M-02e1         焊接铝和铝合金圆管        Standard Specification for Aluminum and Aluminum-Alloy Round Welded Tubes1Y@1u?sm7_
ASTM B315-99         无缝铜合金管        Standard Specification for Seamless Copper Alloy Pipe and TubeD$\IiFf P
ASTM B316/B316M-02         铝及铝合金铆钉和冷镦头线材与棒材的技术规范        Standard Specification for Aluminum and Aluminum-Alloy Rivet and Cold-Heading Wire and Rods
.aO?"LS7b ASTM B317-02         电气用挤压铝和铝合金棒、条、管及结构型材(汇流导体)        Standard Specification for Aluminum-Alloy Extruded Bar, Rod, Tube, Pipe, and Structural Profiles for Electrical Purposes (Bus Conductor)qxP+~'?X
ASTM B319-91(2004)         电镀用铅和铅合金的制备        Standard Guide for Preparation of Lead and Lead Alloys for Electroplating"q/re0SD/G+}WGT
ASTM B320-60(2003)e1         电镀用铁铸件的制备        Standard Practice for Preparation of Iron Castings for Electroplating[$m`o4z
ASTM B322-99         电镀前的金属清洗        Standard Guide for Cleaning Metals Prior to Electroplating~8R9Fe*ttZ QFE
ASTM B324-01         电气用矩形和方形铝线        Standard Specification for Aluminum Rectangular and Square Wire for Electrical Purposes
sZe~ e(u ASTM B327-01e2         压铸模合金用母合金的技术规范        Standard Specification for Master Alloys Used in Making Zinc Die Casting AlloysO @P j&T `R&t lm
ASTM B328-96(2003)         烧结金属结构零件和油浸轴承密度与互连多孔性的试验方法        Standard Test Method for Density, Oil Content, and Interconnected Porosity of Sintered Metal Structural Parts and Oil-Impregnated Bearings
%G6a |z*@^{ ASTM B329-98(2003)e1         用斯科特(Scott)容积计测定耐火金属粉末及化合物表观密度的试验方法        Standard Test Method for Apparent Density of Metal Powders and Compounds Using the Scott Volumeter
_}r#AX\ ASTM B330-02         用费歇尔亚筛分粒器测定耐火金属粉末及化合物的平均粒度的试验方法        Standard Test Method for Fisher Number of Metal Powders and Related Compounds
_xGoa/R Aeoz ASTM B331-95(2002)         单轴压缩中金属粉末的可压缩性试验方法        Standard Test Method for Compressibility of Metal Powders in Uniaxial Compaction*q;Y8gk _KU#g s
ASTM B333-03         镍钼合金板、薄板和带材        Standard Specification for Nickel-Molybdenum Alloy Plate, Sheet, and Stripy-n}+c^3U4iV1`'}t
ASTM B335-03         镍钼合金条材技术规范        Standard Specification for Nickel-Molybdenum Alloy Rodq;CPY]O~
ASTM B338-03         冷凝器和热交换器用无缝及焊接钛与钛合金管        Standard Specification for Seamless and Welded Titanium and Titanium Alloy Tubes for Condensers and Heat Exchangers
8f/S0U%M/iJ0r5FUV ASTM B339-00         锡锭        Standard Specification for Pig Tin,U A@ O+_3D(`!D
ASTM B341/B341M-02         钢筋加强铝导线(ACSR/AZ)用包铝钢芯线        Standard Specification for Aluminum-Coated (Aluminized) Steel Core Wire for Aluminum Conductors, Steel Reinforced (ACSR/AZ)
;wk:J v4L:_ f.a ASTM B343-92a(2004)e1         镍电镀用镍的制备        Standard Practice for Preparation of Nickel for Electroplating with Nickel
_5rL ^s6E%D9Sq ASTM B344-01         拉制或轧制的镍铬和镍铬铁合金电热元件规范        Standard Specification for Drawn or Rolled Nickel-Chromium and Nickel-Chromium-Iron Alloys for Electrical Heating ElementsDg }uId
ASTM B345/B345M-02         铝和铝合金无缝管和气体和石油传输和分配管道系统的无缝挤压成型管的标准规范        Standard Specification for Aluminum and Aluminum-Alloy Seamless Pipe and Seamless Extruded Tube for Gas and Oil Transmission and Distribution Piping Systems
Qy p-o0k c@+cT Le ASTM B348-03         钛及钛合金棒和坯锭        Standard Specification for Titanium and Titanium Alloy Bars and Billets
r4sQIboqJLM ASTM B349/B349M-03         核设施用海绵锆和其它形状的纯金属锆        Standard Specification for Zirconium Sponge and Other Forms of Virgin Metal for Nuclear Application`5r1q3uQD9D@
ASTM B350/B350M-02         核设施用锌和锌合金铸锭        Standard Specification for Zirconium and Zirconium Alloy Ingots for Nuclear Application
:|}O+[W'c ub ASTM B351/B351M-02         核设施用热轧和冷加工锆及锆合金棒、条和线材        Standard Specification for Hot-Rolled and Cold-Finished Zirconium and Zirconium Alloy Bars, Rod, and Wire for Nuclear Application
r/f(W8[%M.})y ASTM B352/B352M-02         核设施用锆及锆合金板、薄板和带材        Standard Specification for Zirconium and Zirconium Alloy Sheet, Strip, and Plate for Nuclear Application+}drl8h\
ASTM B353-02         核设备用锻制的无缝与焊接锆及锆合金管        Standard Specification for Wrought Zirconium and Zirconium Alloy Seamless and Welded Tubes for Nuclear Service (Except Nuclear Fuel Cladding)(w*E:WF#NLt]
ASTM B354-98         不绝缘的金属电导体的相关术语        Standard Terminology Relating to Uninsulated Metallic Electrical Conductors
Zg-h'BF_Y5@0D7I%|#Y ASTM B355-95(2003)         软的或退火的镀镍铜丝        Standard Specification for Nickel-Coated Soft or Annealed Copper Wire ~;H\G+db$`A P
ASTM B359/B359M-02         具有整体散热叶片的冷凝器及热交换器用无缝铜和铜合金管        Standard Specification for Copper and Copper-Alloy Seamless Condenser and Heat Exchanger Tubes With Integral Finsl M0Yz5K
ASTM B360-01         限流器用冷拉铜毛细管        Standard Specification for Hard-Drawn Copper Capillary Tube for Restrictor Applications2u? k R r^1Z k
ASTM B361-02         工厂加工的锻制铝及铝合金焊接配件        Standard Specification for Factory-Made Wrought Aluminum and Aluminum-Alloy Welding FittingsXWMOq7N.^
ASTM B362-91(2003)         恒温双金属制螺旋线圈的机械扭转率的试验方法        Standard Test Method for Mechanical Torque Rate of Spiral Coils of Thermostat Metal N&xm&}5B%O
ASTM B363-03a         无缝和焊接纯钛及钛合金焊接配件        Standard Specification for Seamless and Welded Unalloyed Titanium and Titanium Alloy Welding Fittings
|@k-},PK3wT ASTM B364-96(2002)         钽及钽合金铸锭        Standard Specification for Tantalum and Tantalum Alloy Ingots7D S}4w:Xe N
ASTM B365-98(2004)         钽及钽合金条和线材        Standard Specification for Tantalum and Tantalum Alloy Rod and Wire
r2N TE8`0\^;^'E ASTM B366-04a         工厂加工的锻制镍和镍合金焊接配件        Standard Specification for Factory-Made Wrought Nickel and Nickel Alloy Fittings
F E{%Dd| P ASTM B367-93(2004)         钛和钛合金铸件        Standard Specification for Titanium and Titanium Alloy Castings
}6tvm$h!ZE?2A} ASTM B368-97(2003)e1         加速铜氧化的醋酸盐喷雾试验(CASS试验)        Standard Method for Copper-Accelerated Acetic Acid-Salt Spray (Fog) Testing (CASS Test)+j5@+cHt,v5\@
ASTM B369-96(2003)         铜镍合金铸件        Standard Specification for Copper-Nickel Alloy Castings+Zd0C7d|{0i mi
ASTM B370-03         建筑结构用铜薄板和带材        Standard Specification for Copper Sheet and Strip for Building Construction{i@H L*c W3Ui[#j
ASTM B371/B371M-02         铜锌硅合金条规范        Standard Specification for Copper-Zinc-Silicon Alloy Rod"SU`-`(so)EH
ASTM B372-97(2003)         无缝铜及铜合金矩形波导管        Standard Specification for Seamless Copper and Copper-Alloy Rectangular Waveguide TubeGicvP5n
ASTM B373-00         电容器用铝箔        Standard Specification for Aluminum Foil for Capacitors6J;s4m/u [
ASTM B374-96(2003)         电镀的相关术语        Standard Terminology Relating to ElectroplatingE.]2bBO^4Pb;Y a
ASTM B379-04         增磷铜精炼型材        Standard Specification for Phosphorized Coppers―Refinery Shapes%G"anG;Y0d,`D
ASTM B380-97(2002)         装饰电镀层的涂膏密室耐腐蚀试验方法        Standard Test Method of Corrosion Testing of Decorative Electrodeposited Coatings by the Corrodkote Procedure7LUJ7|K f
ASTM B381-03         钛及钛合金锻件        Standard Specification for Titanium and Titanium Alloy Forgings [YD#m5QA#U7Shgu
ASTM B386-03         钼和钼合金板、薄板、带材和箔        Standard Specification for Molybdenum and Molybdenum Alloy Plate, Sheet, Strip, and Foil
l^WZ%klMV ASTM B387-90(2001)         钼及钼合金棒、条和线材        Standard Specification for Molybdenum and Molybdenum Alloy Bar, Rod, and Wire$iy W1xl
ASTM B388-00         恒温双金属薄板和带材        Standard Specification for Thermostat Metal Sheet and Strip
.K`j:z8{6g.Nx ASTM B389-81(2004)         恒温双金属螺旋形线圈的热偏转率的测试方法        Standard Test Method for Thermal Deflection Rate of Spiral and Helical Coils of Thermostat MetalX8];y3Ur I
ASTM B390-92(2000)         钨硬质合金表观晶粒度及其分布的评定        Standard Practice for Evaluating Apparent Grain Size and Distribution of Cemented Tungsten Carbides5G~aV`
ASTM B391-03         铌和铌合金铸锭        Standard Specification for Niobium and Niobium Alloy Ingots
L\|.Q-wv5dL ASTM B392-03         铌和铌合金棒、条及线材        Standard Specification for Niobium and Niobium Alloy Bar, Rod, and Wire
1ZD$u4jM/N.l ASTM B393-03         铌和铌合金带材、薄板及中厚板        Standard Specification for Niobium and Niobium Alloy Strip, Sheet, and Plate
3q4m'x}f a] ASTM B394-03         铌和铌合金无缝及焊接管        Standard Specification for Niobium and Niobium Alloy Seamless and Welded Tubes6z?9D9C,_7e)T
ASTM B395/B395M-02         热交换器及冷凝器用U型无缝铜和铜合金管        Standard Specification for U-Bend Seamless Copper and Copper Alloy Heat Exchanger and Condenser Tubes
"V[P4KJt ASTM B398/B398M-02         电气用6201-T81型铝合金线        Standard Specification for Aluminum-Alloy 6201-T81 Wire for Electrical Purposes$Z"t,MG$z
ASTM B399/B399M-99         同心绞捻的6201-T81型铝合金导线        Standard Specification for Concentric-Lay-Stranded Aluminum-Alloy 6201-T81 ConductorsW:uJW,}h
ASTM B400-04         紧密的圆形同芯绞捻1350型铝导线        Standard Specification for Compact Round Concentric-Lay-Stranded Aluminum 1350 ConductorsPZ&Y'z0}%kZ
ASTM B401-99         紧密的圆形钢芯加强同心绞捻铝导线(ACSR/COMP)        Standard Specification for Compact Round Concentric-Lay-Stranded Aluminum Conductors, Steel-Reinforced (ACSR/COMP)L6}"X:Ng1vW
ASTM B403-02         镁合金熔模铸件规范        Standard Specification for Magnesium-Alloy Investment Castings^ @6@E yS Gw&DTs
ASTM B404/B404M-02         带有整体散热片的冷凝器与热交换器用铝和铝合金无缝管        Standard Specification for Aluminum and Aluminum-Alloy Seamless Condenser and Heat-Exchanger Tubes with Integral Fins
J%k,p E.d-L+S/i6T/X ASTM B406-96(2000)         硬质合金横向断裂强度的测试方法        Standard Test Method for Transverse Rupture Strength of Cemented CarbidesX4^ dJ2tR
ASTM B407-01         镍铁铬合金无缝管        Standard Specification for Nickel-Iron-Chromium Alloy Seamless Pipe and Tube
&M'W7B;~:f!QANZ7~3I] ASTM B408-01         镍铁铬合金条和棒        Standard Specification for Nickel-Iron-Chromium Alloy Rod and Bar g W:mK9|KF5WU@
ASTM B409-01         镍铁铬合金板、薄板和带材        Standard Specification for Nickel-Iron-Chromium Alloy Plate, Sheet, and Strip
Hw%a8R:QQ%AZ ASTM B411/B411M-01         铜镍硅合金条及棒        Standard Specification for Copper-Nickel-Silicon Alloy Rod and Bar!Z'Fm7ih(Z.vI
ASTM B413-97a(2003)         精炼银规范        Standard Specification for Refined Silver s+@x:M_B~ jY
ASTM B415-98(2002)         冷拉制包铝钢丝        Standard Specification for Hard-Drawn Aluminum-Clad Steel Wire
k~'m(d%w*W ASTM B416-98(2002)         同心绞捻包铝钢导线        Standard Specification for Concentric-Lay-Stranded Aluminum-Clad Steel Conductors
3d_yb$^"zL@-B ASTM B417-00         流动性不好的金属粉末的表观密度测试方法        Standard Test Method for Apparent Density of Non-Free-Flowing Metal Powders Using the Carney FunnelgHJ+z4e
ASTM B418-01         铸造和锻造镀锌阳极        Standard Specification for Cast and Wrought Galvanic Zinc Anodes4AF,E8KPL
ASTM B422-04         铜铝硅钴合金、铜镍硅镁合金及铜镍铝镁合金薄板和带材        Standard Specification for Copper-Aluminum-Silicon-Cobalt Alloy, Copper-Nickel-Silicon-Magnesium Alloy, Copper-Nickel-Silicon Alloy, Copper-Nickel-Aluminum-Magnesium Alloy, and Copper-Nickel-Tin Alloy Sheet and Strip K:^C JM9I;V
ASTM B423-03         镍铁铬钼铜合金无缝管        Standard Specification for Nickel-Iron-Chromium-Molybdenum-Copper Alloy (UNS N08825 and N08221)* Seamless Pipe and Tube
.H:y$gnj5S ?4C ASTM B424-98a         镍铁铬钼铜合金板、薄板及带材        Standard Specification for Ni-Fe-Cr-Mo-Cu Alloy (UNS N08825 and UNS N08221)* Plate, Sheet, and Strip
5T6l+sn#r#e?#@ ASTM B425-99         镍铁铬钼铜合金条及棒        Standard Specification for Ni-Fe-Cr-Mo-Cu Alloy (UNS N08825 and UNS N08221) Rod and Bar
gg/Ky)ZNw ASTM B427-02         齿轮青铜合金铸件规范        Standard Specification for Gear Bronze Alloy Castings
L xOiCZ } ASTM B428-93(2004)         矩形和正方形铜和铜合金管扭转角的测试方法        Standard Test Method for Angle of Twist in Rectangular and Square Copper and Copper Alloy Tube3e5Up oj)V _j
ASTM B429-02         挤压制铝合金结构管        Standard Specification for Aluminum-Alloy Extruded Structural Pipe and Tube @d1j%l$Zj'~b*d
ASTM B430-97(2001)         用比浊法测定耐火金属粉末粒度分布的试验方法        Standard Test Method for Particle Size Distribution of Refractory Metal Powders and Related Compounds by Turbidimetry
cEP3I#PFZ!h/z#? ASTM B432-04         包铜及包铜合金的钢板        Standard Specification for Copper and Copper Alloy Clad Steel Plate/K+Ug!F"\)^ F1p
ASTM B434-00         镍钼铬铁合金板、薄板和带材        Standard Specification for Nickel-Molybdenum-Chromium-Iron Alloys (UNS N10003, UNS N10242)* Plate, Sheet, and StripG].C-{2F
ASTM B435-03         统一编制牌号为NO6002、NO6230、N12160和R30556的板材和带材及牌号为N06002、N06230和R30556的带材        Standard Specification for UNS N06002, UNS N06230, UNS N12160, and UNS R30556 Plate, Sheet, and StripPLGJ:}5B%h
ASTM B438/B438M-04         青铜烧结轴承(油浸的)        Standard Specification for Sintered Bronze Bearings (Oil-Impregnated)
`wpc.Y ASTM B439-00e1         铁基烧结轴承(油浸的)        Standard Specification for Iron-Base Sintered Bearings (Oil-Impregnated)
9E!B|4xH:T*o+J ASTM B440-00         镉        Standard Specification for Cadmium
2yw9c3{w/Gp;I ASTM B441-04         铜钴铍及铜镍铍条和棒        Standard Specification for Copper-Cobalt-Beryllium and Copper-Nickel-Beryllium Rod and Bar (UNS Nos. C17500 and C17510)#];C#\ e;M`
ASTM B443-00e1         镍铬钼钶合金板、薄板和带材        Standard Specification for Nickel-Chromium-Molybdenum-Columbium Alloy (UNS N06625) and Nickel-Chromium-Molybdenum-Silicon Alloy (UNS N06219)* Plate, Sheet, and Strippn9gdH8}%v
ASTM B444-03         镍铬钼钶合金管        Standard Specification for Nickel-Chromium-Molybdenum-Columbium Alloys (UNS N06625) and Nickel-Chromium-Molybdenum-Silicon Alloy (UNS N06219) Pipe and Tube"i}~ v4\8v`$f]
ASTM B446-03         镍铬钼钶合金条和棒        Standard Specification for Nickel-Chromium-Molybdenum-Columbium Alloy (UNS N06625), Nickel-Chromium-Molybdenum-Silicon Alloy (UNS N06219), and Nickel-Chromium-Molybdenum-Tungsten Alloy (UNS N06650)* Rod and Bart9iv(T4P3u7C:h#I*J
ASTM B447-02         焊接铜管        Standard Specification for Welded Copper Tube6@ [)buU
ASTM B449-93(2004)         铝的铬酸盐处理        Standard Specification for Chromates on Aluminum6h YF4dK
ASTM B452-02         电子设备用包铜钢导线        Standard Specification for Copper-Clad Steel Wire for Electronic Application3E#I`z+Q%u
ASTM B453/B453M-01         铜锌铅合金(含铅黄铜)条材        Standard Specification for Copper-Zinc-Lead Alloy (Leaded-Brass) Rod, Bar, and Shapes*J:uc~ x%k'K#O2z
ASTM B455-01         铜锌铅合金(含铅黄铜)挤压型材技术规范        Standard Specification for Copper-Zinc-Lead Alloy (Leaded-Brass) Extruded Shapes
z'||2F3l!AY)Z cw ASTM B456-03         铜+镍+铬及镍+铬的电解沉积镀层        Standard Specification for Electrodeposited Coatings of Copper Plus Nickel Plus Chromium and Nickel Plus Chromium
q1^3}Pv~_'q ASTM B457-67(2003)         铝表面阳极镀层阻抗的测量方法        Standard Test Method for Measurement of Impedance of Anodic Coatings on AluminumYQC yunw9h5@ Bo
ASTM B462-04         腐蚀高温作业用锻制或轧制的UNS NO8020、UNS NO8024、UNS NO8026和UNS NO8367型合金管法兰、锻制配件、阀门及零件        Standard Specification for Forged or Rolled UNS N06030,N06022,N06035,N06200,N06059,N06686,N08020,N08024,N08026,N08367,N10276,N10665, N10675,N10629, N08031,N06045, N06025, & R20033 Alloy Pipe Flanges, Forged Fitting, & Values & Parts for Corrosive High-Tem K|d"Ot@
ASTM B463-04         UNS NO8020、UNS NO8024和UNS NO8026合金板、薄板及带材        Standard Specification for UNS N08020, UNS N08026, and UNS N08024 Alloy Plate, Sheet, and Strip:Uk` |0u A#i4Y+w
ASTM B464-04         焊接的UNS NO8020、NO8024和NO8026合金管        Standard Specification for Welded UNS N08020, N08024, and N08026 Alloy PipeHv^b`YG;Mi
ASTM B465-04         铜铁合金板、薄板、带材和轧制棒材        Standard Specification for Copper-Iron Alloy Plate, Sheet, Strip, and Rolled Bar
3?S,GNT@ ASTM B466/B466M-03         无缝铜镍合金管        Standard Specification for Seamless Copper-Nickel Pipe and TubeR2JVV1PA
ASTM B467-88(2003)         焊接铜镍管        Standard Specification for Welded Copper-Nickel Pipe
f b4RP,O6D0rJ1s ASTM B468-04         焊接的UNS NO8020、NO8024和NO8026合金管        Standard Specification for Welded UNS N08020, N08024, and N08026 Alloy Tubes9Gk f9L1rjE7G
ASTM B470-02         电子设备布线用连接铜导线        Standard Specification for Bonded Copper Conductors for Use in Hookup Wires for Electronic Equipmentq#[9{l6B@#T
ASTM B472-04         再锻用UNS NO8020、UNS NO8026、UNS NO8024、UNS NO8926和UNS NO8367镍合金坯段和棒材        Standard Specification for Nickel Alloy Billets and Bars for Reforging
:g(h2S MDR ASTM B473-96(2002)e1         UNS NO8020、UNS NO8026及UNS NO8024镍合金棒和线        Standard Specification for UNS N08020, UNS N08024, and UNS N08026 Nickel Alloy Bar and Wire,T;GMT)P6a
ASTM B474-03         电熔焊的UNS NO8020、UNS NO8026和UNS NO8024镍合金管        Standard Specification for Electric Fusion Welded Nickel and Nickel Alloy Pipe
(q5L`D;G| ASTM B475-96(2002)e1         UNS NO8020、UNS NO8026及UNS NO8024镍合金圆编织线        Standard Specification for UNS N08020, UNS N08024, and UNS N08026 Nickel Alloy Round Weaving Wire
R#E3lDFJ/A ASTM B476-01         锻制贵金属电接触材料        Standard Specification for General Requirements for Wrought Precious Metal Electrical Contact MaterialsNZ }r XT
ASTM B477-97(2002)         金银镍电接触合金        Standard Specification for Gold-Silver-Nickel Electrical Contact Alloy
N2Szt7bh(L'U ?!U ASTM B478-85(2003)         恒温双金属横向弯曲率的测试方法        Standard Test Method for Cross Curvature of Thermostat Metals
J1S5?nB0yCI5_5ER ASTM B479-00         挠性栅栏用退火铝及铝合金箔        Standard Specification for Annealed Aluminum and Aluminum-Alloy Foil for Flexible Barrier, Food Contact, and Other Applicationsk{3o,uE \
ASTM B480-88(2001)         电镀用镁和镁合金的制备        Standard Guide for Preparation of Magnesium and Magnesium Alloys for Electroplating!?6ge8Wlq?g0B
ASTM B481-68(2003)e1         电镀用钛和钛合金的制备        Standard Practice for Preparation of Titanium and Titanium Alloys for Electroplatingbi Gq-G(` N;` y#`
ASTM B482-85(2003)         电镀用钨和钨合金的制备        Standard Practice for Preparation of Tungsten and Tungsten Alloys for Electroplating
6G~6K-PD GGQ`)Y ASTM B483/B483M-03         普通拉制铝及铝合金管        Standard Specification for Aluminum and Aluminum-Alloy Drawn Tubes for General Purpose Applications
T4~5p L#l9{T ASTM B487-85(2002)         用横断面显微观察法测定金属及氧化物涂层厚度的方法        Standard Test Method for Measurement of Metal and Oxide Coating Thickness by Microscopical Examination of a Cross Section|`wH1ZY
ASTM B488-01         工程用电解沉积镀金层        Standard Specification for Electrodeposited Coatings of Gold for Engineering Uses2c6JNy3bUn
ASTM B489-85(2003)         金属表面电解沉积和自动催化沉积金属镀层延展性的弯曲试验        Standard Practice for Bend Test for Ductility of Electrodeposited and Autocatalytically Deposited Metal Coatings on Metals v#^JZx7Y*j
ASTM B490-92(2003)         用测微计弯曲试验法测定电解沉积物的延展性        Standard Practice for Micrometer Bend Test for Ductility of Electrodeposits?/v2V]"u!fl
ASTM B491/B491M-00         普通挤压铝和铝合金圆管        Standard Specification for Aluminum and Aluminum-Alloy Extruded Round Tubes for General-Purpose Applications
cP]{NJ5{/G s1Fg ASTM B493-01(2003)         锆及锆合金锻件        Standard Specification for Zirconium and Zirconium Alloy Forgings xA6qdO,r6sYI-b^}
ASTM B494/B494M-03         原生锆        Standard Specification for Primary Zirconium
density - 密度;浓度,比重 (0) 投诉
