首页 > 标准讨论 培训学习
[标准信息] ASTM-B系列标准目录 [截至2005年]
P:2008-10-07 10:49:26
ASTM B1-01         冷拉铜线        Standard Specification for Hard-Drawn Copper Wire
z:f^DmQ^DM;~d.U ASTM B2-00         中等硬度冷拉铜丝        Standard Specification for Medium-Hard-Drawn Copper Wire
]1|'C.X.~5s| ASTM B3-01         软的或退火的铜线        Standard Specification for Soft or Annealed Copper Wire)@V(nt)A
ASTM B5-00         电解紫铜精炼型材        Standard Specification for High Conductivity Tough-Pitch Copper Refinery Shapes
(_ sF4{8L \k ASTM B6-03         锌        Standard Specification for ZincQ5g8hH4I9R'i
ASTM B8-04         硬的、中等硬的或软的同心绞捻的铜导线        Standard Specification for Concentric-Lay-Stranded Copper Conductors, Hard, Medium-Hard, or SoftpDP7uE5p&b4pCq `
ASTM B9-90(2003)         青铜制电车架空线        Standard Specification for Bronze Trolley Wire5V ?/?^.y9a
ASTM B16/B16M-00         制螺钉机用易切削黄铜条材、棒材和型材        Standard Specification for Free-Cutting Brass Rod, Bar and Shapes for Use in Screw Machines
3l_)\;]Y ASTM B19-01         弹药筒用黄铜片、带、板、棒和圆盘(坯料)        Standard Specification for Cartridge Brass Sheet, Strip, Plate, Bar, and Disks (Blanks) H"i \7mN5w
ASTM B21/B21M-01e1         海军黄铜条材、棒材和型材        Standard Specification for Naval Brass Rod, Bar, and Shapes
o-guJ o+fg'DUwFq ASTM B22-02         桥梁和转车台用青铜铸件        Standard Specification for Bronze Castings for Bridges and TurntablesxI/|b-FP0M-n
ASTM B23-00         白色金属轴承合金(商品名称为"巴氏合金")        Standard Specification for White Metal Bearing Alloys (Known Commercially as Babbitt Metal)
-|-UiM^#r)K ASTM B26/B26M-03         铝合金砂型铸件        Standard Specification for Aluminum-Alloy Sand Castings@,X$a"w&F
ASTM B29-03         精炼铅        Standard Specification for Refined Lead#L1bL$|D&P.T:e
ASTM B30-04         铜基合金锭        Standard Specification for Copper Alloys in Ingot Form0i#s-M)^fKc+d2u
ASTM B32-03         金属焊料        Standard Specification for Solder MetalS!J$r8[ n,WO2{
ASTM B33-00         电气用镀锡软的或退火的铜线        Standard Specification for Tinned Soft or Annealed Copper Wire for Electrical Purposes6K g(n6Dz
ASTM B36/B36M-01         黄铜板、薄板、带材及轧制棒材        Standard Specification for Brass Plate, Sheet, Strip, And Rolled Bar&R;T\e KA#fV
ASTM B37-03         钢铁制造用铝        Standard Specification for Aluminum for Use in Iron and Steel ManufactureK'|MU?G/b?
ASTM B39-79(2004)         镍        Standard Specification for Nickel*Ki6_@z
ASTM B42-02e1         无缝铜管尺寸        Standard Specification for Seamless Copper Pipe, Standard Sizes
(Zt lx,X ASTM B43-98(2004)         无缝红铜管尺寸        Standard Specification for Seamless Red Brass Pipe, Standard Sizes sA8D)Nu-V
ASTM B47-95a(2001)         电车架空线用铜线        Standard Specification for Copper Trolley Wireuz6|^OeH6TR(H
ASTM B48-00         电导线用矩形和正方形软裸铜线        Standard Specification for Soft Rectangular and Square Bare Copper Wire for Electrical ConductorsC*r5Bh?
ASTM B49-98e2         电气用经回火的铜条材        Standard Specification for Copper Rod Drawing Stock for Electrical Purposes
LS g8`eV ASTM B61-02         蒸气或阀门青铜铸件的标准规范        Standard Specification for Steam or Valve Bronze Castingst C*z5aYJ7fH+P6m
ASTM B62-02         混合青铜或少量金属铸件标准规范        Standard Specification for Composition Bronze or Ounce Metal Castings
{*K~ C.gn ASTM B63-90(2001)         金属导体电阻与接触材料的电阻率的测试方法        Standard Test Method for Resistivity of Metallically Conducting Resistance and Contact Materials
7SZ"A5b3tE;a#[P&]\ ASTM B66-95(2003)         蒸汽机车易损零件用青铜铸件        Standard Specification for Bronze Castings for Steam Locomotive Wearing Parts
'Vqs{*DrBbwH ASTM B68-02         光亮退火的无缝铜管        Standard Specification for Seamless Copper Tube, Bright Annealed
;a-F"Xz!vY4N ASTM B68M-99         光亮退火的无缝铜管(米制)        Standard Specification for Seamless Copper Tube, Bright Annealed [Metric]
nnQQ r9ZK\:q ASTM B69-01a         轧制锌        Standard Specification for Rolled Zinc
1Y b+ko&@/}l*Z ASTM B70-90(2001)         电加热用金属材料的电阻随温度而变化的试验方法        Standard Test Method for Change of Resistance With Temperature of Metallic Materials for Electrical HeatingW6E@([ sg
ASTM B75-02         无缝铜管        Standard Specification for Seamless Copper Tube
-J({X |E s ASTM B75M-99         无缝铜管规范(米制)        Standard Specification for Seamless Copper Tube [Metric]
3V,V,e;|vC/lK:X.hob'~ ASTM B76-90(2001)         电加热用镍铬和镍铬铁合金的加速寿命的试验方法        Standard Test Method for Accelerated Life of Nickel-Chromium and Nickel-Chromium-Iron Alloys for Electrical Heating
,f O SY"Z#F Gphu ASTM B77-81(2001)         电阻合金的热电功率的测试方法        Standard Test Method for Thermoelectric Power of Electrical-Resistance Alloys
fu#MJZS%{ ASTM B78-90(2001)         电加热用铁铬铝合金的加速寿命的试验方法        Standard Test Method of Accelerated Life of Iron-Chromium-Aluminum Alloys for Electrical Heating1lt(b&D?|D
ASTM B80-01e1         镁合金砂型铸件        Standard Specification for Magnesium-Alloy Sand Castings
O @J#\*uA ASTM B84-90(2001)         精密电阻器用合金丝的温度-电阻常数的测试方法        Standard Test Method for Temperature-Resistance Constants of Alloy Wires for Precision Resistors-RdB)S{&q#m
ASTM B85-03         铝合金压模铸件        Standard Specification for Aluminum-Alloy Die Castings9aHmH1bVq;PQ
ASTM B86-03         锌合金压模铸件        Standard Specification for Zinc and Zinc-Aluminum (ZA) Alloy Foundry and Die Castings"u4Jl Z I2C4HL"~
ASTM B88-03         无缝铜水管        Standard Specification for Seamless Copper Water TubeUY2P1i1\o,T\1N/VQ
ASTM B88M-03         无缝铜水管(米制)        Standard Specification for Seamless Copper Water Tube [Metric]
;ST.g!d3{r ASTM B90/B90M-98         镁合金薄板和中厚板        Standard Specification for Magnesium-Alloy Sheet and Plate
g(?5\@6W/JtHy ASTM B91-97(2004)         镁合金锻件规范        Standard Specification for Magnesium-Alloy Forgings C/H@jL*]
ASTM B92/B92M-01         回熔用镁锭和镁棒        Standard Specification for Unalloyed Magnesium Ingot and Stick For RemeltingR4psfuq
ASTM B93/B93M-03         砂型铸件、永久型模铸件和压模铸件用镁合金锭        Standard Specification for Magnesium Alloys in Ingot Form for Sand Castings, Permanent Mold Castings, and Die CastingsdR e%_a0F ^t X9B
ASTM B94-94(2000)         镁合金压铸件的技术规范        Standard Specification for Magnesium-Alloy Die Castings
KSkGv ASTM B96/B96M-01         一般及压力容器用铜硅合金板、薄板、带材及轧制棒材        Standard Specification for Copper-Silicon Alloy Plate, Sheet, Strip, and Rolled Bar for General Purposes and Pressure Vessels
%E t6L ^H!l(z%R ASTM B98/B98M-03         铜硅合金粗、细棒材和型材技术规范        Standard Specification for Copper-Silicon Alloy Rod, Bar and Shapes A.BUS#Yz6c6R] F
ASTM B99/B99M-01         一般用途的铜硅合金线        Standard Specification for Copper-Silicon Alloy Wire for General Applications]1vdak,q
ASTM B100-03a         桥梁和其它结构用锻制铜合金轴承和膨胀中厚板及薄板        Standard Specification for Wrought Copper-Alloy Bearing and Expansion Plates and Sheets for Bridge and Other Structural Use)Ev0LC]V^
ASTM B101-02         建筑结构用包铅铜薄板和带材        Standard Specification for Lead-Coated Copper Sheet and Strip for Building Construction0lucw9`}A7E^%I
ASTM B102-00         铅和锡合金压模铸件        Standard Specification for Lead- and Tin-Alloy Die Castings
@;~:w*uEC^;P ASTM B103/B103M-98e2         磷青铜板、薄板、带材和轧制棒材        Standard Specification for Phosphor Bronze Plate, Sheet, Strip, and Rolled Bar
0\,z;j6f)c6`$e ASTM B105-00         电导线用冷拉制铜合金线        Standard Specification for Hard-Drawn Copper Alloy Wires for Electric Conductors'N$D*thy#e2r
ASTM B106-96(2002)e1         恒温金属挠性的试验方法        Standard Test Methods for Flexivity of Thermostat MetalsM+Y `2LZ,\
ASTM B107/B107M-00         镁合金挤压制棒材、条材、型材、管材和线材        Standard Specification for Magnesium-Alloy Extruded Bars, Rods, Profiles, Tubes, and WireC&cvI)X
ASTM B108-03a         铝合金永久型模铸件        Standard Specification for Aluminum-Alloy Permanent Mold Castings1hY M b!q
ASTM B111-98(2004)         铜和铜合金无缝冷凝器管和套圈坯料        Standard Specification for Copper and Copper-Alloy Seamless Condenser Tubes and Ferrule Stock
KF(h%]L;LY ASTM B111M-98e2         铜和铜合金无缝冷凝器管和套圈坯料(米制)        Standard Specification for Copper and Copper-Alloy Seamless Condenser Tubes and Ferrule Stock [Metric]2i6cD2~2MW
ASTM B114-90(2001)         分流器与精密电阻器用薄板材料的温度-电阻常数的测试方法        Standard Test Method for Temperature-Resistance Constants of Sheet Materials for Shunts and Precision Resistors0H/?Y~(GQ
ASTM B115-00         电解阴极铜        Standard Specification for Electrolytic Copper Cathode
t[[;B\$rWz e9J ASTM B116-95(2001)         工业运输用9号深槽铜及8号铜制电车架空线        Standard Specification for Figure-9 Deep-Grooved and Figure-8 Copper Trolly Wire for Industrial HaulagerP{%^+L(em
ASTM B117-03         盐雾试验设备的使用标准惯例        Standard Practice for Operating Salt Spray (Fog) Apparatus
w*sT0{'Bq-`2S&A] ASTM B121/B121M-01         含铅黄铜中厚板、薄板、带材和轧制棒材        Standard Specification for Leaded Brass Plate, Sheet, Strip, and Rolled Bar
2EcyF/rC'jU ASTM B122/B122M-01         铜镍锡合金、铜镍锌合金(镍银)和铜镍合金板、薄板、带材及轧制棒材        Standard Specification for Copper-Nickel-Tin Alloy, Copper-Nickel-Zinc Alloy (Nickel Silver), and Copper-Nickel Alloy Plate, Sheet, Strip, and Rolled Bar
!M})hJ _h ASTM B124/B124M-00         铜和铜合金锻制条材、棒材和型材        Standard Specification for Copper and Copper Alloy Forging Rod, Bar, and Shapes
6}m+Dk3_Kq?R;f ASTM B127-98         镍铜合金板、薄板和带材        Standard Specification for Nickel-Copper Alloy (UNS N04400) Plate, Sheet, and Strip/Hk|5?[ir:O
ASTM B129-02         弹筒黄铜弹壳火帽壳        Standard Specification for Cartridge Brass Cartridge Case Cups'u*u(x.BR c x2W
ASTM B130-02         商用弹头壳青铜带材        Standard Specification for Commercial Bronze Strip for Bullet JacketsAW'~*HO z
ASTM B131-02         铜合金弹头火帽壳        Standard Specification for Copper Alloy Bullet Jacket Cups
of9f#pXJv'J-} T ASTM B134/B134M-01         黄铜丝        Standard Specification for Brass Wire
!u }y'O,C7K ASTM B135-02         无缝黄铜管        Standard Specification for Seamless Brass Tube
E#{_*M1j!C S8zN ASTM B135M-00e1         无缝黄铜管(米制)        Standard Specification for Seamless Brass Tube [Metric]"]`l+m+Hl/R\ k
ASTM B136-84(2003)         铝表面阳极镀层的着色阻力的测定方法        Standard Method for Measurement of Stain Resistance of Anodic Coatings on Aluminum
.q8MgT.B)N~ pj ASTM B137-95(2000)         单位面积阳极铝镀层重量的测定方法        Standard Test Method for Measurement of Coating Mass Per Unit Area on Anodically Coated Aluminum
[3{_)K~^0R ASTM B138/B138M-01         锰青铜条材、棒材和型材        Standard Specification for Manganese Bronze Rod, Bar, and Shapes
8|!l7G&Z i"hPb`,O ASTM B139/B139M-01         磷青铜条材、棒材和型材        Standard Specification for Phosphor Bronze Rod, Bar, and Shapes
IduG,H[ YkM ASTM B140/B140M-01         铜锌铅棒(铅红黄铜或硬青铜).棒材和成型材        Standard Specification for Copper-Zinc-Lead (Red Brass or Hardware Bronze) Rod, Bar, and Shapes5O+hEX$[8B)@ |nB
ASTM B148-97(2003)         铝青铜砂型铸件        Standard Specification for Aluminum-Bronze Sand Castingst@%aN2v D2cK
ASTM B150/B150M-03         铝青铜条材、棒材和型材        Standard Specification for Aluminum Bronze Rod, Bar, and Shapes
ysop8G ASTM B151/B151M-00         铜镍锌合金(镍银)及铜镍条和棒材        Standard Specification for Copper-Nickel-Zinc Alloy (Nickel Silver) and Copper-Nickel Rod and Bar
-J)n(G bO:P+FY+q0g ASTM B152/B152M-00         铜薄板、带材、中厚板及轧制棒材技术规范        Standard Specification for Copper Sheet, Strip, Plate, and Rolled Bar Xm2LG.x1zF n
ASTM B153-91(2003)e1         铜和铜合金管的膨胀试验法(针试验)        Standard Test Method for Expansion (Pin Test) of Copper and Copper-Alloy Pipe and Tubing
+vA;Qt/W/BY g U ASTM B154-01         铜和铜合金的硝酸亚汞试验法        Standard Test Method for Mercurous Nitrate Test for Copper and Copper Alloys
&f&_t*[ ^X_ ASTM B159/B159M-01         磷青铜丝技术规范        Standard Specification for Phosphor Bronze Wire
O$r_!@,?#p\Hz j U.J ASTM B160-99         镍条和镍棒技术规范        Standard Specification for Nickel Rod and Bar
p G/r9M:`oK&rk_ ASTM B161-03         无缝镍管        Standard Specification for Nickel Seamless Pipe and Tube
}'Xx3d!Uc:_t ASTM B162-99         镍板、薄板及带材        Standard Specification for Nickel Plate, Sheet, and Strip
g&?wgy ASTM B163-04         冷凝器及热交换器用无缝镍和镍合金管        Standard Specification for Seamless Nickel and Nickel Alloy Condenser and Heat-Exchanger Tubes)w B p:ii?2~
ASTM B164-03         镍铜合金条材、棒材和线材        Standard Specification for Nickel-Copper Alloy Rod, Bar, and Wire#^2l8[ Q%G O GFe,qB
ASTM B165-93(2003)e1         无缝镍铜合金管规范        Standard Specification for Nickel-Copper Alloy (UNS N04400)* Seamless Pipe and Tube
;K:L(e{FemU ASTM B166-04         镍铬铁合金及镍铬钴钼合金条材、棒材及线材        Standard Specification for Nickel-Chromium-Iron Alloys (UNS N06600, N06601, N06603, N06690, N06693, N06025, and N06045)* and Nickel-Chromium-Cobalt-Molybdenum Alloy (UNS N06617) Rod, Bar, and Wire]*zn4kQwi ?
ASTM B167-01         无缝镍铬铁合金管        Standard Specification for Nickel-Chromium-Iron Alloys (UNS N06600, N06601, N06603, N06690, N06693, N06025, and N06045)* and Nickel-Chromium-Cobalt-Molybdenum Alloy (UNS N06617) Seamless Pipe and Tube*d)rK8h/{4X
ASTM B168-01         镍铬铁合金及镍铬钴钼合金板、薄板和带材        Standard Specification for Nickel-Chromium-Iron Alloys (UNS N06600, N06601, N06603, N06690, N06693, N06025, and N06045) and Nickel-Chromium-Cobalt-Molybdenum Alloy (UNS N06617) Plate, Sheet, and Strip VG7mtx]x6n
ASTM B169/B169M-01         铝青铜中厚板、薄板、带材和轧制棒材        Standard Specification for Aluminum Bronze Sheet, Strip, and Rolled Bar
|&?.lXa } ASTM B170-99(2004)         无氧电解铜精炼型材        Standard Specification for Oxygen-Free Electrolytic Copper―Refinery Shapes
Ti'Kb"rC zk@ ASTM B171/B171M-04e1         压力容器、冷凝器及热交换器用铜合金中厚板和薄板        Standard Specification for Copper-Alloy Plate and Sheet for Pressure Vessels, Condensers, and Heat Exchangers
h*q,Gb2l ASTM B172-01a         电导线用成束绞绳铜导线        Standard Specification for Rope-Lay-Stranded Copper Conductors Having Bunch-Stranded Members, for Electrical Conductors5p(c`*i5nNH'K6D
ASTM B173-01a         导线用同芯多股绞绳铜导线        Standard Specification for Rope-Lay-Stranded Copper Conductors Having Concentric-Stranded Members, for Electrical Conductors
:D0~Tz ~+fug ASTM B174-02         电导线用成束绞捻的铜导线        Standard Specification for Bunch-Stranded Copper Conductors for Electrical Conductors
s7l]2u c z ASTM B176-04         压铸件铜合金压模铸件        Standard Specification for Copper-Alloy Die Castings
AE#k NGeN2YX sg ASTM B177-01         工程用钢表面镀铬        Standard Guide for Engineering Chromium Electroplating)qp*vNM |
ASTM B179-03         砂型铸件、永久型模铸件和压模铸件用铝合金锭及其熔化成形方式        Standard Specification for Aluminum Alloys in Ingot and Molten Forms for Castings from All Casting Processeso2QZ*m C*qk
ASTM B183-79(2004)e1         电镀用低碳钢的制备        Standard Practice for Preparation of Low-Carbon Steel for ElectroplatingC8AsB;N'K&C
ASTM B187/B187M-03         铜汇流棒、条和型材        Standard Specification for Copper, Bus Bar, Rod, and Shapes and General Purpose Rod, Bar, and Shapes
aluminium-Mylar laminated tape - 铝-聚酯薄膜带 (0) 投诉
