[VGA] VGA 2919 的线要执行什么标准?做测试需要测试什么项目?
P:2008-09-28 09:23:59
die adjuster - 模套调整器 (0) 投诉
P:2008-09-28 11:57:10
你用线是否UL2919规格线,是参考UL标准要求,参考UL758可以了.
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758   Section 2 Page 2919         Issued: March 22, 1978
                       Revised: Feb. 12, 2001
  Style 2919 Low Voltage Computer Cable.
  Rating 80°C, 30 Volts.
         Insulated Conductors :No. 40 AWG minimum. Labeled or complying with Manufacturer’s AWM Procedure having a minimum rating of 80°C, 30 V.
          Assembly  :Consists of two or more conductors, twisted pairs or groups of  twisted conductors twisted together. The conductors or groups of conductors may be laid parallel forming a flat,oval or round cable. The lay of the conductors is not specified. A barrier layer and/or fillers are optional. Manufacturer shall maintain a complete description of each assembly. May use same or mixed AWG size.
            Covering      (Optional) - A 6 mil or heavier PVC covering may be extruded over the conductor assembly.
           *Shield     Optional.
           Jacket PVC - Class 43
           THICKNESS (MILS)
#Dia of cable under jacket               Minimum                 Minimum
 in inches                                          Average                    at any point
_____________ ________ ____________
0.425 or less                                             30                                  24
0.426 - 0.700                                             45                                    36
0.701 - 1.000                                              60                                   48
1.000 - 1.500                                             80                                      64
1.501 - 2.500                                             110                                 88
2.501 and larger                                        140                              112
# - Major dia if cable is flat or oval.
*Standard                               Appliance Wiring Material UL 758.
production flow-through time - 生产流通时间 (0) 投诉
P:2008-09-28 13:55:52
应该是RGB同轴电缆,阻抗75欧姆,
high-conductivity copper hollow conductor - 高导电空心铜导线 (0) 投诉
P:2008-09-28 22:49:15
2919  VGA现在已被HDMI取代了,没有多少工厂在做此线了。
ADSL - analog-to-digital simulation langauge模拟-数字模拟语言 (0) 投诉
P:2008-11-10 15:05:09
我廠在生產,測試項目參照UL758&1581&2556
cotton-insulated wire - 纱包线 (0) 投诉
P:2008-11-10 15:30:43
做的热还有呢,国外市场还有人要的毕竟这中借口最普及的。
STW - surface transverse wave表面横(向)波,浅体波 (0) 投诉
P:2010-05-13 15:56:27
学习了!
intelligent communication system - 智能通信系统 (0) 投诉
