[问题求助] CEI 20-20 电源线H03V2V2-F(3X0.5平方,3X0.75平方)的化学成份
P:2008-09-27 10:11:24
各位大虾有知道的请帮帮忙!请看下列表格:
请填写如下种类电源线的化学成份、CTI-VALUE和阻燃等级。
LOCATION
MANUFACTURER
TRADENAME (TYPE)
CHEMICAL NAME
IEC NORM IEC TYPE
CTI-VALUE (IEC 60112)
FLAMMABILITY CATEGORY (IEC 60707)
TEMPERATURE INDEX
H03V2V2-F
3X0,50 3X0,75
H05V2V2-F
3X1,00
 CEI 20-20
 90°C
WV - working voltage工作电压 (0) 投诉
P:2014-08-26 08:26:33
CONDUCTOR  导体:
Flexible cord in plain or metal-coated-----普通软线或者有金属保护层的软线
annealed copper, class 5 (HD 383)-----退火铜,等级 5(HD 383)
INSULATION-----绝缘:
Thermoplastic polyvinyl chloride compound type R2---- R2 热塑性塑料聚氯乙烯复合类型
Electrical insulation of cables for fixed laying even in wet environments and forfire retardant cables.---------绝缘电缆,在潮湿和防火的环境中使用
SHEATH-----护套:
Thermoplastic polyvinyl chloride compound type TM2--------TM2 热塑性塑料聚氯乙烯复合类型
Standard colour: grey 7035-------标准颜色:灰色 7035.
Protective sheath of cables usually used for mobile connections, even in wet environments and for fire retardant cables.------------护套通常用于移动链接,在潮湿和防火的环境中使用
COLOUR-- 颜色:
Core identification in compliance with CENELEC HD 308 in force.---芯识别按照CENELEC HD 308
MARKING---标志:
Blue ink-jet: PECSO MN NOFIRE FROR 450/750V,CEI 20-22 II IEMMEQU (section) CE + (meters).-----蓝色喷墨:PECSO MN 无火制线450/750V,CEI20-22II IEMMEQU(区)CE+(米)
STANDARDS 标准:
CEI 20-22/II ; CEI 20-37 Parte I Capitolato Tec.IMQ CPT-007, RoHS 2002/95/CE.
TECHNICAL DATA  技术数据:
• Rated voltage: 450/750 V -----------额定电压:450/750V
• Maximum temperature on use: +70°C ------最高温度:+70°C
• Minimum temperature of installation: +5°C ---------最低安装温度  +5°C
• Maximum short circuit temperature: +150°C -------最高短路温度:+150°C
• Min. internal bending radius: 6xD--------最小内部弯曲半径:6×D
• Max. mechanical stress: 5 kg/mm2----------最大的机械应力:5KG/mm2
• Max. strain in static duty conditions: 1,5 kg/mm2----------在静止的工作制下 最大的拉力:1.5kg/mm2
SUITABLE FOR PLACES AT RISK------适合用于危险的地方
IN CASE OF FIRE---------防火
REDUCED EMISSION OF CORROSIVE GASSES-------减少排放腐蚀性气体的地方
armouring equipment - 铠装设备 (0) 投诉
P:2026-09-14 16:04:02
threader - 穿线机,穿模机 (0) 投诉
