首页 > 产品认证
[UL认证] ul 3386认证!
P:2008-12-09 12:34:56
Color | PANTONE Code | Chromatic aberration(│ΔE│) | Test method |
Red | PANTONE | ≤4.0 | DKBA 4023-2007.10 |
Yellow | PANTONE | ≤4.0 | |
Blue | PANTONE | ≤4.0 | |
Green | PANTONE | ≤4.0 | |
Black | PANTONE | ≤4.0 | |
Brown | PANTONE | ≤4.0 | DKBA 4023-2007.10 |
Gray | PANTONE | ≤4.0 |
4.2 Insulation
Tensile Strength: ≥10.3MPa
Elongation: ≥150%
Tensile Strength: ≥10MPa
Tensile Strength Variation: ≤30%
Elongation: ≥125%
Elongation Variation: ≤30%
4.3 Cold Bending
Condition:
No Crack
4.4 Cold Impact Test
Condition:
No Crack
4.5 Heat Shock
Condition: 136±
No Crack
4.6 Deformation Resistance
Condition:
Result:≤50%
4.7 Flammability
IEC 60332-1 IEC 60332
4.8 Temperature
Rated temperature:
Minimum installation temperature:
Minimum Operation Temperature :
Minimum Storage Temperature:
5 Electrical Characteristics
5.1 Dielectric Strength
Condition:AC,2.5 kV,15min
Result: no break
5.2 Other Electric parameter
See Table 1
6 Environment Requirements
6.1Burning occur gas acidity PH≥4.3 (IEC 60754-2)
6.2Acid gas release mounts ≤5 mg/g (IEC 60754-1)
6.3Burning release gas photic rate ≥60% (IEC 61034-2)
6.4 Burning occur the conductivity value≤10μS/mm(IEC 61034-2)
6.5Meet the standard of RoHS
我上传了该材料的性能,哪个厂家的料可以达到这个性能,最小截面要做到16AWG 请留下联系方式
pair-to-shield capacitance unbalance - 线对对屏蔽电容不平衡 (0) 投诉
